Search engine with differents tags of photo
Hi there!
I’m using Nextcloud til some years now, i have my photos synced with the app souvenir. To find them back easly i usually add some tags. For exemple “Invoice” and “Car” in a picture of an invoice. I’ve just beeing surprised that when i typed “Invoice Car” on the general search of my nextcloud there is no result, and i expected to find this invoice photo!
Thanks for all the job done here and thanks for the community to make nextcloud alive.
Fred.
mmh, that sounds very much like something I once implemented for nc 25 (see Files: Extend search to also cover tags by marcelklehr · Pull Request #26813 · nextcloud/server · GitHub ) not sure if it was thrown out again :thinking:
Hello @Frederiiiic,
you started a topic in development category. This category is intended for active developers of the core or apps in the Nextcloud ecosystem.
From the description in your topic, it is not clear if you are seeking help and advice about a concrete problem you have or you want to actually develop the corresponding solution.
Please specify explicitly the required information to help you best. These are:
  1. What you want to achieve
  2. What you have done so far
  3. What is failing
  4. What you expect from the forum community
Without additional information the community members cannot help you in an efficient manner. Please keep in mind that the help here in the forum are mostly based on work of volunteers and thus it is just fair to reduce the burden on them.
If you accidentally posted in the category, just give a hint and a moderator can move the corresponding category.
Especially, if you want to report an issue (like a found bug) for the corresponding developers to address, this is unfortunately not the right location: most devs will not likely stumble upon the issues in the forum. Such issues are better tracked on GitHub in the appropriate issue tracker. Probably, this is the issue tracker of the server but could be another one as well.
Regards,
christianlupus
@marcelklehr I’m actually in NC 26, but searching for “invoice car” just give me no results actually. but if i put only “invoice” or only “car” the search engine find the tag. But ideally when i type “invoice car” i expected to find in first exactly the photos that is tagged in “invoice” and “car”.
@christianlupus the objective of my message was just to suggest to developpers here that something act wiredly for me. And i don’t really get how to be more precise.
  1. This is not really a issue, just a tool not working as expected, but i hope this suggestion might prove useful.
  2. hum… Just tested it.
  3. Search engine don’t find tags, as i explained.
  4. I expected to know if this point is actually known, and I hope to help move this issue forward.
Regards,
Fred.
Then, this is a bug report. It does not work as the user (you) expect it. Either it is a UI/UX issue (user just expects the wrong behavior) or simply a discrepancy between spec and implemented behavior.
But, I would hoghly advice to upgrade as you are quite a few versions behind the current release. I hope, you have an enterprise license, as otherwise your instance would be End-of-Life for quite some time now…
Before filing a bug report, I would suggest to check a more recent version of the server if it has the problem still.
