I’m trying to set up NextCloud server on a VM using the image managed by T&M Hansson IT. This is my firs time running it and I tried executing the start script, exactly to their instructions, but it fails.
Nextcloud version :18.0.0
Operating system and version: Windows 10 Latest update
The issue you are facing: Failing to get past the initial step of running the startup script on VMware
Is this the first time you’ve seen this error? I’ve repeated this error on multiple different VMWare instances and also I tried it on VirtualBox but it didn’t work on there either.
- Install VMWare and the NextCloud Image that is managed by T&M Hansson IT]
- Follow the instructions to install it. The error will happen just as I start executing the startup-script
- It’ll fail after doing a Network check (and saying the connection is fine)
Here is what I saw before the screen says to report it on GitHub. I figured I should try and ask the community before reporting it as an official bug. It’ll be a screenshot of the VMWare window
Also, just to be clear, I didn’t change any settings, and I made sure my network connection was Bridged instead of NAT. I simply imported the .ova file that was provided and followed the instructions.
Thanks for reading
