What does this error mean?
[root@moorfield003 nextcloud]# sudo -u nginx php --define apc.enable_cli=1 occ files:scan rob.nicholson
Starting scan for user 1 out of 1 (rob.nicholson)
Exception during scan: "files/6574aa9652cde089cc67b9b5ef8a8853"("local::/usr/share/nginx/nextcloud/data/::__groupfolders/1/scanner::") is locked
#0 /data/nextcloud/lib/private/Files/Storage/Common.php(765): OC\Lock\DBLockingProvider->acquireLock()
#1 /data/nextcloud/lib/private/Files/Storage/Wrapper/Wrapper.php(607): OC\Files\Storage\Common->acquireLock()
#2 /data/nextcloud/lib/private/Files/Storage/Wrapper/Wrapper.php(607): OC\Files\Storage\Wrapper\Wrapper->acquireLock()
#3 /data/nextcloud/lib/private/Files/Storage/Wrapper/Jail.php(451): OC\Files\Storage\Wrapper\Wrapper->acquireLock()
#4 /data/nextcloud/lib/private/Files/Storage/Wrapper/Wrapper.php(607): OC\Files\Storage\Wrapper\Jail->acquireLock()
#5 /data/nextcloud/lib/private/Files/Storage/Wrapper/Wrapper.php(607): OC\Files\Storage\Wrapper\Wrapper->acquireLock()
#6 /data/nextcloud/lib/private/Files/Storage/Wrapper/Wrapper.php(607): OC\Files\Storage\Wrapper\Wrapper->acquireLock()
#7 /data/nextcloud/lib/private/Files/Cache/Scanner.php(326): OC\Files\Storage\Wrapper\Wrapper->acquireLock()
#8 /data/nextcloud/lib/private/Files/Utils/Scanner.php(256): OC\Files\Cache\Scanner->scan()
#9 /data/nextcloud/apps/files/lib/Command/Scan.php(164): OC\Files\Utils\Scanner->scan()
#10 /data/nextcloud/apps/files/lib/Command/Scan.php(218): OCA\Files\Command\Scan->scanFiles()
#11 /data/nextcloud/3rdparty/symfony/console/Command/Command.php(255): OCA\Files\Command\Scan->execute()
#12 /data/nextcloud/core/Command/Base.php(177): Symfony\Component\Console\Command\Command->run()
#13 /data/nextcloud/3rdparty/symfony/console/Application.php(1009): OC\Core\Command\Base->run()
#14 /data/nextcloud/3rdparty/symfony/console/Application.php(273): Symfony\Component\Console\Application->doRunCommand()
#15 /data/nextcloud/3rdparty/symfony/console/Application.php(149): Symfony\Component\Console\Application->doRun()
#16 /data/nextcloud/lib/private/Console/Application.php(211): Symfony\Component\Console\Application->run()
#17 /data/nextcloud/console.php(100): OC\Console\Application->run()
#18 /data/nextcloud/occ(11): require_once('/data/nextcloud...')
#19 {main}
| Folders | Files | Errors | Elapsed time |
| 25 | 178 | 1 | 00:00:01 |
