I’ve just installed a NextCloud instance on my online server - everything works well.
My main datas I want to sync with NC are on an external drive. I want to sync the entire external drive content (so, let’s say, the D:\ drive). The drive is not empty at all ![]()
Before making any mistake, I want to be sure I have understood what I need to do, so that I activate this synchronization without losing any data:
- to install the desktop synchronisation app [done - Win 10]
- to connect the app to my server [works well]
- to choose what folder to sync and how - and this is where I am confused
- should I choose both options:
- sync data from server
AND - the local folder is not empty. Keep all datas
or should I do another way?
Thanks for your help!
