Saml uer not able to logout
We are going to setup a new environment of nextcloud and using saml to authenticate from MS AD,
When a domain user login, he/she cannot able to see logout button.
logout
We are using both “Direct and SSO/SAML login” options,
Following are SAML settings
s1
s2
I have changed different browsers, but same results.
Thanks
Well, for one, you will need to provide the SLO (Single logout) URL. IFRC that will then “Enable” the logout button.
Thanks it works
Please mark as solved for future users.
I have the same problem, but neither I know where I can configure a SLO nor do I know how this URL has to look like.
For me, even with the SLO URL set to what Authentik shows me to be the URL: https://auth.example.com/application/saml/nextcloud/slo/binding/post/ I get a bad gateway from Cloudflare.
