example
longer
example
here
NextCloudPi 17.0.2
I am getting this error since a few days when trying to sync files from my Windows 7 PC. The Client is updated to the latest version 2.6.2.
any help to solve this would be highly appreciated.
I am a Newbie and I followed step by step instructions and used a nextcloudpi image. I can connect via Telnet but would need very detailed advice what to do.
Thanx alot.
- not sure
Fatal webdav Sabre\DAV\Exception\BadRequest: Expected filesize of 3066419 bytes but read (from Nextcloud client) and wrote (to Nextcloud storage) 40960 bytes. Could either be a network problem on the sending side or a problem writing to the storage on the server side.
/var/www/nextcloud/apps/dav/lib/Connector/Sabre/Directory.php - line 156:
OCA\DAV\Connector\Sabre\File->put(null)
/var/www/nextcloud/3rdparty/sabre/dav/lib/DAV/Server.php - line 1096:
OCA\DAV\Connector\Sabre\Directory->createFile(".IMG_0870.MP4.~41c9", null)
/var/www/nextcloud/3rdparty/sabre/dav/lib/DAV/CorePlugin.php - line 525:
Sabre\DAV\Server->createFile("files/cherb ... 9", null, null)
<<closure>>
Sabre\DAV\CorePlugin->httpPut(Sabre\HTTP\R ... "}, Sabre\HTTP\Response {})
/var/www/nextcloud/3rdparty/sabre/event/lib/EventEmitterTrait.php - line 105:
call_user_func_array([ Sabre\DAV\ ... "], [ Sabre\HTTP ... }])
/var/www/nextcloud/3rdparty/sabre/dav/lib/DAV/Server.php - line 479:
Sabre\Event\EventEmitter->emit("method:PUT", [ Sabre\HTTP ... }])
/var/www/nextcloud/3rdparty/sabre/dav/lib/DAV/Server.php - line 254:
Sabre\DAV\Server->invokeMethod(Sabre\HTTP\R ... "}, Sabre\HTTP\Response {})
/var/www/nextcloud/apps/dav/lib/Server.php - line 317:
Sabre\DAV\Server->exec()
/var/www/nextcloud/apps/dav/appinfo/v2/remote.php - line 35:
OCA\DAV\Server->exec()
/var/www/nextcloud/remote.php - line 163:
require_once("/var/www/ne ... p")
2019-12-28T23:03:53+0100
Error no app in context Sabre\DAV\Exception\BadRequest: Expected filesize of 3066419 bytes but read (from Nextcloud client) and wrote (to Nextcloud storage) 40960 bytes. Could either be a network problem on the sending side or a problem writing to the storage on the server side.
Fatal webdav Sabre\DAV\Exception\BadRequest: Expected filesize of 1425264 bytes but read (from Nextcloud client) and wrote (to Nextcloud storage) 385024 bytes. Could either be a network problem on the sending side or a problem writing to the storage on the server side.
2019-12-28T22:58:12+0100
Error no app in context Sabre\DAV\Exception\BadRequest: Expected filesize of 1425264 bytes but read (from Nextcloud client) and wrote (to Nextcloud storage) 385024 bytes. Could either be a network problem on the sending side or a problem writing to the storage on the server side.
Fatal webdav Sabre\DAV\Exception\BadRequest: Expected filesize of 1425264 bytes but read (from Nextcloud client) and wrote (to Nextcloud storage) 532480 bytes. Could either be a network problem on the sending side or a problem writing to the storage on the server side.
2019-12-28T22:52:25+0100
Error no app in context Sabre\DAV\Exception\BadRequest: Expected filesize of 1425264 bytes but read (from Nextcloud client) and wrote (to Nextcloud storage) 532480 bytes. Could either be a network problem on the sending side or a problem writing to the storage on the server side.
Fatal webdav Sabre\DAV\Exception\BadRequest: Expected filesize of 646791 bytes but read (from Nextcloud client) and wrote (to Nextcloud storage) 434176 bytes. Could either be a network problem on the sending side or a problem writing to the storage on the server side.
2019-12-28T22:46:44+0100
Error no app in context Sabre\DAV\Exception\BadRequest: Expected filesize of 646791 bytes but read (from Nextcloud client) and wrote (to Nextcloud storage) 434176 bytes. Could either be a network problem on the sending side or a problem writing to the storage on the server side.
Fatal webdav Sabre\DAV\Exception\BadRequest: Expected filesize of 646791 bytes but read (from Nextcloud client) and wrote (to Nextcloud storage) 40960 bytes. Could either be a network problem on the sending side or a problem writing to the storage on the server side.
2019-12-28T22:40:58+0100
Error no app in context Sabre\DAV\Exception\BadRequest: Expected filesize of 646791 bytes but read (from Nextcloud client) and wrote (to Nextcloud storage) 40960 bytes. Could either be a network problem on the sending side or a problem writing to the storage on the server side.
Fatal webdav Sabre\DAV\Exception\BadRequest: Expected filesize of 646791 bytes but read (from Nextcloud client) and wrote (to Nextcloud storage) 352256 bytes. Could either be a network problem on the sending side or a problem writing to the storage on the server side.
2019-12-28T22:35:13+0100
Error no app in context Sabre\DAV\Exception\BadRequest: Expected filesize of 646791 bytes but read (from Nextcloud client) and wrote (to Nextcloud storage) 352256 bytes. Could either be a network problem on the sending side or a problem writing to the storage on the server side.
2019-12-28T22:29:27+0100
I am sorry I do not know how to get this information. I am pasting the system report that I can generate from the admin / upport panel:
Server configuration detail
Operating system: Linux 4.19.66-v7+ #1253 SMP Thu Aug 15 11:49:46 BST 2019 armv7l
Webserver: Apache (fpm-fcgi)
Database: mysql 10.1.37
PHP version: 7.2.26-1+0~20191218.33+debian9~1.gbpb5a34b
Modules loaded: Core, date, libxml, openssl, pcre, zlib, filter, hash, Reflection, SPL, sodium, session, standard, cgi-fcgi, mysqlnd, PDO, xml, bz2, calendar, ctype, curl, dom, mbstring, fileinfo, ftp, gd, gettext, gmp, iconv, igbinary, imagick, intl, json, ldap, exif, mysqli, pdo_mysql, Phar, posix, readline, redis, shmop, SimpleXML, smbclient, sockets, sysvmsg, sysvsem, sysvshm, tokenizer, wddx, xmlreader, xmlwriter, xsl, zip, libsmbclient, Zend OPcache
Nextcloud version: 17.0.2 - 17.0.2.1
Updated from an older Nextcloud/ownCloud or fresh install:
Where did you install Nextcloud from: unknown
<details><summary>Signing status</summary>
Array ( )
</details>
<details><summary>List of activated apps</summary>
- accessibility: 1.3.0
- activity: 2.10.1
- cloud_federation_api: 1.0.0
- comments: 1.7.0
- contacts: 3.1.6
- dav: 1.13.0
- federatedfilesharing: 1.7.0
- federation: 1.7.0
- files: 1.12.0
- files_pdfviewer: 1.6.0
- files_rightclick: 0.15.1
- files_sharing: 1.9.0
- files_trashbin: 1.7.0
- files_versions: 1.10.0
- files_videoplayer: 1.6.0
- firstrunwizard: 2.6.0
- gallery: 18.4.0
- logreader: 2.2.0
- lookup_server_connector: 1.5.0
- news: 14.1.0
- nextcloud_announcements: 1.6.0
- nextcloudpi: 0.0.1
- notes: 3.1.0
- notifications: 2.5.0
- oauth2: 1.5.0
- password_policy: 1.7.0
- previewgenerator: 2.2.0
- privacy: 1.1.0
- provisioning_api: 1.7.0
- recommendations: 0.5.0
- serverinfo: 1.7.0
- sharebymail: 1.7.0
- support: 1.0.1
- survey_client: 1.5.0
- systemtags: 1.7.0
- tasks: 0.11.3
- text: 1.1.1
- theming: 1.8.0
- twofactor_backupcodes: 1.6.0
- updatenotification: 1.7.0
- viewer: 1.2.0
- workflowengine: 1.7.0
- admin_audit
- calendar
- encryption
- files_external
- files_texteditor
- previewgenerator.orig
- user_ldap
</details>
<details><summary>Configuration (config/config.php)</summary>
"trusted_domains": {
"0": "localhost",
"5": "nextcloudpi.local",
"7": "nextcloudpi",
"8": "nextcloudpi.lan",
"11": "92.200.93.6",
"1": "192.168.178.53",
"4": "cherberg.de"
"dbtype": "mysql",
"version": "17.0.2.1",
"overwrite.cli.url": "https:\/\/cherberg.de\/",
"dbport": "",
"mysql.utf8mb4": true,
"redis": {
"port": 0,
"timeout": 0,
"tempdirectory": "\/media\/USBdrive\/ncdata\/tmp",
"mail_smtpmode": "sendmail",
"mail_smtpauthtype": "LOGIN",
"overwriteprotocol": "https",
"logfile": "\/media\/USBdrive\/ncdata\/nextcloud.log",
"loglevel": "2",
"log_type": "file",
"jpeg_quality": "60",
"theme": ""
</details>
External storages: files_external is disabled
Encryption: no
User-backends:
OC\User\Database
Browser: Mozilla/5.0 (Windows NT 6.1; rv:71.0) Gecko/20100101 Firefox/71.0
PASTE HERE
