example
longer
example
here
Nextcloud version (eg, 12.0.2): 17.0.2
Operating system and version (eg, Ubuntu 17.04): Ubuntu 18.04 LTD
Apache or nginx version (eg, Apache 2.4.25): Apache 2
PHP version (eg, 7.1): 7.2
When uploading large files via Cyberduck WebDav, Windows / MacOS WebDAV, Nextcloud Client, or the Web Interface, the following happens:
With WebDav > It uploads a file / then restarts the upload or completely timesout partial way.
With Nextcloud Client > It uploads to 100% and gets stuck at 0 seconds.
With Web UI > It uploads to 100% and then throws a Exception error about the wrong size.
- Setup S3 Primary or External Storage
- Upload large file via WebUI / WebDav or Nextcloud Client
Sabre\DAV\Exception: An exception occurred while uploading parts to a multipart upload. The following parts had errors: - Part 2: Error executing "UploadPart" on "https://server32113123.s3.us-east-1.amazonaws.com/urn%3Aoid%3A5232?partNumber=2&uploadId=AWbri3n6QoRtojFjskE8Ze9zORR8KSMwvv5UQphEsYIzkrqnKd.EX6pOi0kGGK_pFLfYkZab7iehIA3xRi9b5BVgorxBcU4CcolILg9Iw3aQIWQ1Q8D4iO0vSUTb9yOJ"; AWS HTTP error: Client error: `PUT https://server32113123.s3.us-east-1.amazonaws.com/urn%3Aoid%3A5232?partNumber=2&uploadId=AWbri3n6QoRtojFjskE8Ze9zORR8KSMwvv5UQphEsYIzkrqnKd.EX6pOi0kGGK_pFLfYkZab7iehIA3xRi9b5BVgorxBcU4CcolILg9Iw3aQIWQ1Q8D4iO0vSUTb9yOJ` resulted in a `400 Bad Request` response: <?xml version="1.0" encoding="UTF-8"?> <Error><Code>RequestTimeout</Code><Message>Your socket connection to the server w (truncated...) RequestTimeout (client): Your socket connection to the server was not read from or written to within the timeout period. Idle connections will be closed. - <?xml version="1.0" encoding="UTF-8"?> <Error><Code>RequestTimeout</Code><Message>Your socket connection to the server was not read from or written to within the timeout period. Idle connections will be closed.</Message><RequestId>BE8141ACAF59BFF1</RequestId><HostId>TuWxrANb6UjQHgYYqJQd6MB3Wct/a2uik7QuxR/Xz62+tzPwaT8QrbE1KpnEvK3G7R9T3JlZugk=</HostId></Error>
Error continues for additional Parts
PASTE HERE
PASTE HERE
