I use Nextcloud 27 and the Mail app in version 3.2.0. I have imported my certificate from Actalis and can open old already encrypted emails. But I can not create encrypted emails, is that correct or should encrypting and signing with S/MIME also work?
Thanks in advance for your answers
Encryption and signing should work. But it can only work if the certificate can do it. I am not sure if this is the case for Actalis certs.
Since the certificate works in Outlook, Thunderbird, Apple Mail (iOS / macOS) and SOGo, I assume that the necessary properties are available. Previously encrypted emails with other clients can also be opened in the Mail App. I just canβt do any signing or encryption in the Nextcloud Mail app.
The certificate is available from Actalis for free:
https://extrassl.actalis.it/portal/uapub/doProcess?reqid=&lang=en
Here the properties of the certificate without my private data:
Certificate:
Data:
Version: 3 (0x2)
Serial Number:
Signature Algorithm: sha256WithRSAEncryption
Issuer: C = IT, ST = Bergamo, L = Ponte San Pietro, O = Actalis S.p.A., CN = Actalis Client Authentication CA G3
Validity
Not Before: May 15 16:59:43 2023 GMT
Not After : May 15 16:59:42 2024 GMT
Subject Public Key Info:
Public Key Algorithm: rsaEncryption
Public-Key: (2048 bit)
X509v3 extensions:
X509v3 Basic Constraints: critical
CA:FALSE
X509v3 Authority Key Identifier:
BE:97:A9:AA:84:BF:80:BF:10:53:7D:09:32:F9:E1:2E:32:1B:CF:77
Authority Information Access:
CA Issuers - URI:http://cacert.actalis.it/certs/actalis-autclig3
OCSP - URI:http://ocsp09.actalis.it/VA/AUTHCL-G3
X509v3 Certificate Policies:
Policy: 1.3.159.1.24.1
CPS: https://www.actalis.it/area-download
X509v3 Extended Key Usage:
TLS Web Client Authentication, E-mail Protection
X509v3 CRL Distribution Points:
Full Name:
URI:http://crl09.actalis.it/Repository/AUTHCL-G3/getLastCRL
X509v3 Key Usage: critical
Digital Signature, Key Encipherment
That sounds like a bug then. Please report it at Sign in to GitHub Β· GitHub.
Hello! Are you getting any closer to solving the problem? I am asking because 7 weeks have already passed. We are currently evaluating whether to switch to Nextcloud and it is very unfortunate that one of the most important tools has an issue.
I see version 3.3.1 is out now.
