Hi all,
after reinstalling my Raspberry Pi 4 with NextcloudPi RPi_03-02-22 I am not able anymore to access the Admin panel after activation. I can access the non admin panel - but not the admin panel to do some adjustments.
If I want to access the admin panel through the IP Adress - it says that this page is not available, if I use https://nextcloudpi:4443 it tells me Forbidden 403 - you don’t have access to this resource.
Here is the log file of my nextcloudpi which I could access:
"id": "ocbl8r0xpy2t",
"items": [
"server",
"version",
"23.0.2.1"
"server",
"code",
"other"
"server",
"enable_avatars",
"yes"
"server",
"enable_previews",
"yes"
"server",
"memcache.local",
"\\OC\\Memcache\\Redis"
"server",
"memcache.distributed",
"none"
"server",
"asset-pipeline.enabled",
"no"
"server",
"filelocking.enabled",
"yes"
"server",
"memcache.locking",
"server",
"debug",
"no"
"server",
"cron",
"cron"
"php",
"version",
"7.4.28"
"php",
"memory_limit",
2984524800
"php",
"max_execution_time",
3600
"php",
"upload_max_filesize",
10737418240
"database",
"type",
"mysql"
"database",
"version",
"10.5.12"
"database",
"size",
2310144
"apps",
"accessibility",
"1.9.0"
"apps",
"activity",
"2.15.0"
"apps",
"calendar",
"3.1.0"
"apps",
"circles",
"23.0.1"
"apps",
"cloud_federation_api",
"1.6.0"
"apps",
"comments",
"1.13.0"
"apps",
"contacts",
"4.0.8"
"apps",
"contactsinteraction",
"1.4.0"
"apps",
"dashboard",
"7.3.0"
"apps",
"dav",
"1.21.0"
"apps",
"federatedfilesharing",
"1.13.0"
"apps",
"federation",
"1.13.0"
"apps",
"files",
"1.18.0"
"apps",
"files_pdfviewer",
"2.4.0"
"apps",
"files_rightclick",
"1.2.0"
"apps",
"files_sharing",
"1.15.0"
"apps",
"files_trashbin",
"1.13.0"
"apps",
"files_versions",
"1.16.0"
"apps",
"files_videoplayer",
"1.12.0"
"apps",
"firstrunwizard",
"2.12.0"
"apps",
"logreader",
"2.8.0"
"apps",
"lookup_server_connector",
"1.11.0"
"apps",
"news",
"18.0.0"
"apps",
"nextcloud_announcements",
"1.12.0"
"apps",
"nextcloudpi",
"0.0.1"
"apps",
"notes",
"4.3.1"
"apps",
"notifications",
"2.11.1"
"apps",
"notify_push",
"0.3.0"
"apps",
"oauth2",
"1.11.0"
"apps",
"password_policy",
"1.13.0"
"apps",
"photos",
"1.5.0"
"apps",
"previewgenerator",
"99.99.99"
"apps",
"privacy",
"1.7.0"
"apps",
"provisioning_api",
"1.13.0"
"apps",
"recommendations",
"1.2.0"
"apps",
"serverinfo",
"1.13.0"
"apps",
"settings",
"1.5.0"
"apps",
"sharebymail",
"1.13.0"
"apps",
"support",
"1.6.0"
"apps",
"survey_client",
"1.11.0"
"apps",
"systemtags",
"1.13.0"
"apps",
"tasks",
"0.14.2"
"apps",
"text",
"3.4.0"
"apps",
"theming",
"1.14.0"
"apps",
"twofactor_backupcodes",
"1.12.0"
"apps",
"updatenotification",
"disabled"
"apps",
"user_status",
"1.3.1"
"apps",
"viewer",
"1.7.0"
"apps",
"weather_status",
"1.3.0"
"apps",
"workflowengine",
"2.5.0"
"stats",
"num_files",
172
"stats",
"num_users",
1
"stats",
"num_storages",
2
"stats",
"num_storages_local",
1
"stats",
"num_storages_home",
1
"stats",
"num_storages_other",
0
"stats",
"num_comments",
0
"stats",
"num_comment_markers",
0
"stats",
"num_systemtags",
0
"stats",
"num_systemtags_mappings",
0
"files_sharing",
"num_shares",
0
"files_sharing",
"num_shares_user",
0
"files_sharing",
"num_shares_groups",
0
"files_sharing",
"num_shares_link",
0
"files_sharing",
"num_shares_link_no_password",
0
"files_sharing",
"num_fed_shares_sent",
0
"files_sharing",
"num_fed_shares_received",
0
"encryption",
"enabled",
"no"
"encryption",
"default_module",
"no"
