in a university course we got the task to setup a multi node system using Kubernetes. We got the free choice on what to use the system for. So I got the idea to setup Nextcloud, as I’m interested in the topic anyways.
In a presentation we need to show some of the features and advantages of using a multi node system. Are there any compute intensive features in Nextcloud, that could be used for demonstration purposes? Simply uploading some files won’t do the trick I guess
BTW I have a 3700x and 16GB of ram available on a separate system, that will be used for the project.
Thank you very much for your input!
