NextcloudPi latest version (1.32.1) on Raspberry Pi 4 4GB (arm64).
Running nc-previews from ncp-config gives following errors:
Running nc-previews
In Application.php line 652:
[Symfony\Component\Console\Exception\CommandNotFoundException]
Command “preview:generate-all” is not defined.
Did you mean one of these?
migrations:generate
notification:generate
preview:repair
Exception trace:
at /var/www/nextcloud/apps/mail/vendor/symfony/console/Application.php:652
Symfony\Component\Console\Application->find() at /var/www/nextcloud/apps/mail/vendor/symfony/console/Application.php:231
Symfony\Component\Console\Application->doRun() at /var/www/nextcloud/apps/mail/vendor/symfony/console/Application.php:143
Symfony\Component\Console\Application->run() at /var/www/nextcloud/lib/private/Console/Application.php:215
OC\Console\Application->run() at /var/www/nextcloud/console.php:100
require_once() at /var/www/nextcloud/occ:11
php-imagick is not installed. The app NCP Preview Generator is installed.
