running cronjob and shell commands after moving config directory outside web root
    • 34.0.3
    • Linux 6.12.47+rpt-rpi-v8 aarch64
    • Apache 2.4.68
    • n.a.
    • 8.3.17
    • yes
    • after I moved config directory outside of web root
    • manual
    • no
I’m currently implementing server hardening steps and, following Hardening and security guidance — Nextcloud 35 Administration Manual , I’ve placed my config directory outside of the web root in /etc/nextcloud. Site is up and running, but I can’t set the config dir in the shell environment. The documentation gives this command:
export NEXTCLOUD_CONFIG_DIR=/etc/nextcloud
I have tried to run it as superuser (sudo -i) before running sudo -u www-data php occ commands.
I have added it to ~/.bashrc
I have added NEXTCLOUD_CONFIG_DIR=/etc/nextcloud to /etc/environment
All to no avail - I keep getting the error Cannot write into "config" directory!
I set folder permissions for /etc/nextcloud to 0750 and to 0640 for the files in it.
  1. Move config folder from web root to /etc/nextcloud
  2. Add SetEnv NEXTCLOUD_CONFIG_DIR /etc/nextcloud to virtual host and reload apache2 service
  3. run export NEXTCLOUD_CONFIG_DIR=/etc/nextcloud in shell
  4. run sudo -u www-data php /var/www/html/nextcloud/occ status
  5. Recieve error Cannot write into "config" directory!
n.a.
n.a.
n.a.
n.a.
sudo clears the environment unless you use -E option - e.g.
sudo -E -u www-data php occ
That was it! Thank you so much!
