Rsync: Software caused connection abort (103)
Nextcloud version (eg, 20.0.5): 28.0.1
Operating system and version (eg, Ubuntu 20.04): Linux 6.1.0-rpi8-rpi-v8 aarch64
Apache or nginx version (eg, Apache 2.4.25): Apache/2.4.58
PHP version (eg, 7.4): 8.1.27
I think my mount-point fails during rsync. The output from rsync is this:
sending incremental file list
rsync: [sender] opendir "/tmp/borg/20240111_181442-nextcloud-aio" failed: Software caused connection abort (103)
rsync: [sender] opendir "/tmp/borg/20240128_040059-nextcloud-aio" failed: Transport endpoint is not connected (107)
rsync: [sender] opendir "/tmp/borg/20240131_040111-nextcloud-aio" failed: Transport endpoint is not connected (107)
rsync: [sender] opendir "/tmp/borg/20240204_040119-nextcloud-aio" failed: Transport endpoint is not connected (107)
rsync: [sender] opendir "/tmp/borg/20240211_040117-nextcloud-aio" failed: Transport endpoint is not connected (107)
rsync: [sender] opendir "/tmp/borg/20240218_040101-nextcloud-aio" failed: Transport endpoint is not connected (107)
rsync: [sender] opendir "/tmp/borg/20240219_040102-nextcloud-aio" failed: Transport endpoint is not connected (107)
rsync: [sender] opendir "/tmp/borg/20240220_040103-nextcloud-aio" failed: Transport endpoint is not connected (107)
rsync: [sender] opendir "/tmp/borg/20240221_040106-nextcloud-aio" failed: Transport endpoint is not connected (107)
rsync: [sender] opendir "/tmp/borg/20240222_040107-nextcloud-aio" failed: Transport endpoint is not connected (107)
rsync: [sender] opendir "/tmp/borg/20240223_040106-nextcloud-aio" failed: Transport endpoint is not connected (107)
rsync: [sender] opendir "/tmp/borg/20240224_040104-nextcloud-aio" failed: Transport endpoint is not connected (107)
rsync: [sender] opendir "/tmp/borg/20240225_040053-nextcloud-aio" failed: Transport endpoint is not connected (107)
borg/
borg/20240225_040053-nextcloud-aio/
sent 651 bytes  received 36 bytes  274,80 bytes/sec
total size is 0  speedup is 0,00 (DRY RUN)
rsync error: some files/attrs were not transferred (see previous errors) (code 23) at main.c(1338) [sender=3.2.7]
And then when I
ls -l /tmp/
My mount-point seems to have really crashed
d????????? ? ?    ?       ?            ? borg
Rsync works fine as I already successfully rsync files to this other raspberry pi (192.168.1.119) on a regular basis.
  1. Follow this guide: GitHub - nextcloud/all-in-one: The official Nextcloud installation method. Provides easy deployment and maintenance with most features included in this one Nextcloud instance.
  2. Run this command: sudo borg mount “/mnt/backup/borg” /tmp/borg/
  3. Supply password to the encrypted backup
  4. Run: sudo rsync -anvhP -e “ssh -i /home/username/.ssh/id_rsa -p nnnn” /tmp/borg username@192.168.1.119:~/nextcloud_borg_mirror/
I solved this issue. It was my locales settings that were messed up. Switched them to some utf-8 and now it works.
Thread where I found the solution: rsync from a borg mount throws "Transport endpoint is not connected" · Issue #2595 · borgbackup/borg · GitHub
I think I have this same issue - on linux (redhat 7.x). When you say switching your locals to utf-8 - are you talking about system locales? python locales? I’m still fairly new to borg - and I’m trying to work with a large dataset and some sets rsync fine and some are doing this (sometimes almost immediately) so I no longer think this is a resources issues (I’ve increased ram from 8gb → 32gb → 64gb) to test. Thanks in advance for any tips you can give!
