Room capacity in calendar_resource_management
I set up some resources via the calendar_resource_management.
One room has two workspaces, and my initial idea was that two people can actually book this room at the same. That does not seem to work. So what is the functionality of a room’s capacity?
capacity allows you to find the appropriate room e.g. if you plan a meeting with 5 persons a room with capacity of 2 is not sufficient.
