Reverse Proxy display issue
I’m trying to install Owncloud 13.04 behind my reverse proxy.
I already have several web services behind this server that work without any problem
**Direct access to the Ownlcoud is also done without any problem, but when I access it through the reverse proxy this is what I have:
No css, js… is applied.
So I looked at the doc to see if anything has to be done to make reverse proxied owncloud Ok, then I modifed my config.php to this :
  'overwritehost' => 'www.mysite.com',
  'trustedproxies' => '10.44.0.191',
  'overwriteprotocol' => 'http',
  'overwritewebroot' => '/',
  'overwritecondaddr' => '^10\.44\.0\.191$', (tried wihtout backslashes too)
  'instanceid' => 'oca16toul8qg',
This is the VirtualHost Apache config :
<VirtualHost *:80>
        ServerAdmin webmaster@localhost
        DocumentRoot /var/www/nextcloud
        ServerName www.mysite.com
        Options +FollowSymlinks
</VirtualHost>
and here the reverse proxy config (ip 10.44.0.191) :
<VirtualHost *:80>
    RewriteEngine On
    ProxyPass / http://10.44.0.150
    ProxyPassReverse / http://10.44.0.150
    ProxyRequests Off
    ProxyPreserveHost On
</VirtualHost>
I really don’t know what’s wrong with my config.
Any help would be really appreciated,
Proc.
I would change the data folder out of /var/www, e.g. to /da/ta/
Thank you but I don’t think it’s related to my problem.
So I made it works, but it still very strange.
I strictly respected these steps:
  1. Activate reverse proxy only for HTTP (https disabled)
  2. Unzip in /var/www
  3. chown to www:data
  4. Launch Install
  5. Login with admin account
  6. Activate HTTPS on reverse proxy
    tune config.php to match reverse proxy settings.
Now everything works.
