example
longer
example
here
Nextcloud version (eg, 12.0.2): 15.05
Operating system and version (eg, Ubuntu 17.04): Ubuntu 18.04
Apache or nginx version (eg, Apache 2.4.25): 2.4.29
PHP version (eg, 7.1): 7.2.15
The issue you are facing: I have used hosted Nextcloud and decided to host my own. On the hosted, the correct storage space was showing in Explorer when the webdav is mounted. I can’t seem to get that to happen on my self-hosted Nextcloud. Is there a setting that I am missing. Thank you for your time.
- Mount WebDav
'instanceid' => '*************',
'passwordsalt' => '****************',
'secret' => '****************',
0 => 'shrtswrd.dnsfor.me',
'datadirectory' => '/ocdata',
'version' => '15.0.5.3',
'overwrite.cli.url' => 'https://shrtswrd.dnsfor.me/nextcloud',
'dbname' => 'nextcloud',
'dbhost' => 'localhost',
'dbuser' => 'nextcloud',
'dbpassword' => '************',
'htaccess.RewriteBase' => '/nextcloud',
'redis' =>
'port' => 0,
'timeout' => 0.0,
'mail_smtpmode' => 'smtp',
'mail_smtpsecure' => 'ssl',
'mail_from_address' => '********',
'mail_domain' => '*********',
'mail_smtpauth' => 1,
'mail_smtphost' => '*************',
'mail_smtpport' => '465',
'mail_smtpname' => '*************',
'mail_smtppassword' => '**********',
[Fri Mar 22 07:20:27.569583 2019] [mpm_prefork:notice] [pid 7431] AH00163: Apache/2.4.29 (Ubuntu) OpenSSL/1.1.0g configured -- resuming normal operations
[Fri Mar 22 07:20:27.569726 2019] [core:notice] [pid 7431] AH00094: Command line: '/usr/sbin/apache2'
[Fri Mar 22 07:21:43.910338 2019] [php7:error] [pid 7614] [client 71.236.0.243:56420] script '/var/www/html/nextcloud/apps/files/cron.php' not found or unable to stat
[Fri Mar 22 07:21:58.021611 2019] [php7:error] [pid 7593] [client 71.236.0.243:56444] script '/var/www/html/nextcloud/apps/files/cron.php' not found or unable to stat
[Fri Mar 22 07:27:33.633977 2019] [mpm_prefork:notice] [pid 7431] AH00169: caught SIGTERM, shutting down
[Fri Mar 22 07:27:33.837937 2019] [mpm_prefork:notice] [pid 7902] AH00163: Apache/2.4.29 (Ubuntu) OpenSSL/1.1.0g configured -- resuming normal operations
[Fri Mar 22 07:27:33.838079 2019] [core:notice] [pid 7902] AH00094: Command line: '/usr/sbin/apache2'
[Fri Mar 22 07:30:30.674620 2019] [mpm_prefork:notice] [pid 7902] AH00171: Graceful restart requested, doing restart
AH00558: apache2: Could not reliably determine the server's fully qualified domain name, using 127.0.1.1. Set the 'ServerName' directive globally to suppress this message
[Fri Mar 22 07:30:30.849348 2019] [mpm_prefork:notice] [pid 7902] AH00163: Apache/2.4.29 (Ubuntu) OpenSSL/1.1.0g configured -- resuming normal operations
[Fri Mar 22 07:30:30.849390 2019] [core:notice] [pid 7902] AH00094: Command line: '/usr/sbin/apache2'
[Fri Mar 22 07:32:54.466306 2019] [mpm_prefork:notice] [pid 7902] AH00169: caught SIGTERM, shutting down
[Fri Mar 22 07:34:02.179430 2019] [mpm_prefork:notice] [pid 1415] AH00163: Apache/2.4.29 (Ubuntu) OpenSSL/1.1.0g configured -- resuming normal operations
[Fri Mar 22 07:34:02.417922 2019] [core:notice] [pid 1415] AH00094: Command line: '/usr/sbin/apache2'
[Fri Mar 22 08:36:31.850221 2019] [mpm_prefork:notice] [pid 1415] AH00169: caught SIGTERM, shutting down
[Fri Mar 22 08:36:33.200645 2019] [mpm_prefork:notice] [pid 4969] AH00163: Apache/2.4.29 (Ubuntu) OpenSSL/1.1.0g configured -- resuming normal operations
[Fri
