I have a problem if someone have any idea to solve it, it will be nice ^^
Iām trying to install nextcloudpi on openmediavault using docker.
I have change the port to be fine with OMV
I have this error on the container initialisation : mysqladmin: connect to server at ālocalhostā failed
error: āCanāt connect to local MySQL server through socket ā/var/run/mysqld/mysqld.sockā (2 āNo such file or directoryā)ā
Check that mysqld is running and that the socket: ā/var/run/mysqld/mysqld.sockā exists!
I think i must change the localhost with the RaspberryPi ip adress but iām not sure.
Any idea ?
Thanks
