[resolved] Array to string conversion in AllConfig.php on line 164
Hello
hope everybody are good
i have in my log and cron log the error message :
Array to string conversion in /var/www/nextcloud/lib/private/AllConfig.php on line 164
all seems running well but …
seems something wrong in my config file (config.php) if i understand good the file name : AllConfig.php
line 164 =
163        public function getSystemValueString(string $key, string $default = ''): string {
164               return (string) $this->getSystemValue($key, $default);
165        }
system information :
Operating system: Linux 6.1.0-7-amd64 #1 SMP PREEMPT_DYNAMIC Debian 6.1.20-2 (2023-04-08) x86_64
Webserver: Apache/2.4.57 (Debian) (fpm-fcgi)
Database: pgsql PostgreSQL 14.5 (Debian 14.5-3) on x86_64-pc-linux-gnu, compiled by gcc (Debian 12.2.0-7) 12.2.0, 64-bit
PHP version: 8.2.7
Modules loaded: Core, date, libxml, openssl, pcre, zlib, filter, hash, json, random, Reflection, SPL, session, standard, sodium, cgi-fcgi, PDO, xml, apcu, bcmath, bz2, calendar, ctype, curl, dom, mbstring, FFI, fileinfo, ftp, gd, gettext, gmp, iconv, igbinary, imagick, imap, intl, exif, memcache, msgpack, pdo_pgsql, pgsql, Phar, posix, pspell, readline, redis, shmop, SimpleXML, sockets, sysvmsg, sysvsem, sysvshm, tokenizer, xmlreader, xmlwriter, xsl, zip, memcached, Zend OPcache
Nextcloud version: 27.1.1 - 27.1.1.0
Updated from an older Nextcloud/ownCloud or fresh install: fresh
apps :
  • activity: 2.19.0
  • admin_audit: 1.17.0
  • bookmarks: 13.1.1
  • breezedark: 27.0.0
  • bruteforcesettings: 2.7.0
  • calendar: 4.5.1
  • checksum: 1.2.2
  • circles: 27.0.1
  • cloud_federation_api: 1.10.0
  • comments: 1.17.0
  • contacts: 5.4.2
  • contactsinteraction: 1.8.0
  • dashboard: 7.7.0
  • dav: 1.27.0
  • federatedfilesharing: 1.17.0
  • federation: 1.17.0
  • files: 1.22.0
  • files_external: 1.19.0
  • files_pdfviewer: 2.8.0
  • files_reminders: 1.0.0
  • files_rightclick: 1.6.0
  • files_sharing: 1.19.0
  • files_trashbin: 1.17.0
  • files_versions: 1.20.0
  • firstrunwizard: 2.16.0
  • logreader: 2.12.0
  • lookup_server_connector: 1.15.0
  • mail: 3.4.0
  • nextcloud_announcements: 1.16.0
  • notes: 4.8.1
  • notifications: 2.15.0
  • oauth2: 1.15.1
  • password_policy: 1.17.0
  • photos: 2.3.0
  • privacy: 1.11.0
  • provisioning_api: 1.17.0
  • qownnotesapi: 23.6.0
  • recommendations: 1.6.0
  • related_resources: 1.2.0
  • richdocuments: 8.2.0
  • richdocumentscode: 23.5.402
  • serverinfo: 1.17.0
  • settings: 1.9.0
  • sharebymail: 1.17.0
  • side_menu: 3.10.3
  • spreed: 17.1.1
  • support: 1.10.0
  • survey_client: 1.15.0
  • suspicious_login: 5.0.0
  • systemtags: 1.17.0
  • text: 3.8.0
  • theming: 2.2.0
  • twofactor_backupcodes: 1.16.0
  • updatenotification: 1.17.0
  • user_status: 1.7.0
  • viewer: 2.1.0
  • weather_status: 1.7.0
  • workflowengine: 2.9.0
  • encryption
  • twofactor_totp
  • user_ldap
config file : config.php :
       0 => 'tls.pra.rip',
       1 => 'reverse.tech.pra.rip',
       2 => 'reverse.pra.rip',
       3 => '192.168.123.125',
       4 => '2a01:e0a:1ef:7591::203',
       5 => '192.168.125.0/24',
       6 => '2a01:e0a:db9:10f1::/64',
    "overwritehost": "tls.pra.rip",
    "overwritewebroot": "\/",
    "overwritecondaddr": [
        "^192\\.168\\.123\\.125$",
        "^2a01:e0a:1ef:7591::203$"
    "dbtype": "pgsql",
    "version": "27.1.1.0",
    "overwrite.cli.url": "https:\/\/tls.pra.rip\/",
    "dbport": "",
    "force_language": "fr",
    "mail_smtpmode": "smtp",
    "mail_sendmailmode": "smtp",
    "mail_smtpport": "587",
    "mail_smtpauth": 1,
    "filelocking.enabled": true,
    "redis": {
        "port": 6379,
        "timeout": 0
    "default_phone_region": "FR",
    "diagnostics.logging": true,
    "diagnostics.logging.threshold": 5,
    "log_type": "file",
    "log_type_audit": "file",
    "loglevel_frontend": 2,
    "loglevel": 2,
    "log.backtrace": false,
    "logfile": "\/var\/www\/nextcloudData\/logs\/nextcloud.log",
    "logfile_audit": "\/var\/www\/nextcloudData\/logs\/audit.log",
    "log_query": false,
    "query_log_file": "\/var\/www\/nextcloudData\/logs\/sql.log",
    "redis_log_file": "\/var\/www\/nextcloudData\/logs\/redis.log",
    "log_rotate_size": 104857600,
    "logdateformat": "d F, Y H:i:s",
    "logtimezone": "UTC",
    "tempdirectory": "\/tmp\/nextcloudtemp",
    "trashbin_retention_obligation": "auto",
    "htaccess.RewriteBase": "\/",
    "integrity.check.disabled": false,
    "forwarded_for_headers": [
        "HTTP_X_FORWARDED",
        "HTTP_FORWARDED_FOR"
    "enabledPreviewProviders": [
        "OC\\Preview\\Image",
        "OC\\Preview\\MP3",
        "OC\\Preview\\TXT",
        "OC\\Preview\\MarkDown",
        "OC\\Preview\\Epub",
        "OC\\Preview\\PDF",
        "OC\\Preview\\OpenDocument",
        "OC\\Preview\\StarOffice",
        "OC\\Preview\\MSOfficeDoc",
        "OC\\Preview\\MSOffice2003",
        "OC\\Preview\\MSOffice2007",
        "OC\\Preview\\FB2"
    "preview_max_x": 1080,
    "preview_max_y": 1920,
    "app_install_overwrite": [
        "files_downloadactivity",
        "admin_notifications",
        "defaultlinkopen",
        "files_reader"
    "has_rebuilt_cache": true,
    "theme": "",
    "enforce_theme": ""
what is wrong? ^^
Cron Configuration: Array
[backgroundjobs_mode] => cron
[lastcron] => 1695795317
for trusted_proxies it the same format than trusted_domains, means it s an array :
  0 => '<one_IPv4>',
  1 => '<one_IPv6>',
thank you for your help
pra
no idea ?
need to open a bug ?
One reason you may not have gotten any responses is because your config isn’t formatted using code / preformatted mode so it’s very difficult to read.
oh ok
thank you
corrected
I think at least part of what you have going on is here:
The overwritecondaddr is only meant to be a string containing a single value (a regular expression). The way you have it listed it’s an array.
I think if you want to match multiple possible addresses in that field you would need to do something like this (note: untested):
"overwritecondaddr" => "^192\\.168\\.123\\.125$|^2a01:e0a:1ef:7591::203$",
Hello
thank you for your reply
for info :
doesn t work but
working fine ; thank you again
