I’m trying to implement a workflow with an external script which should resize an uploaded image by a given factor. For this I use the “worfklow external script”-extension.
Short information about my system:
I am using the latest nextcloud-aio images using a docker-compose setup.
I’ve set up the flow using the following:
When: “File created”
and “FILE MIME Type” matches “Images”
Path and argument for external script: /var/www/html/CUSTOM_DATA/scale_image.sh %f
%f based on the documentation, it is the locally available file.
The script is correctly called (I think per default there is a cron job every 5min which searches for new files) and it also creates the needed picture, but for any reason it is not showing in my file using the Nextcloud UI.
SSHing into my nextcloud host, the file is created in the passed locally available directory, but Nextcloud does not consider those files.
Is there anyting I miss in regard the file-directories?
Thanks
Last but non least, here is my script:
#!/bin/bash
SCALE_PERCENT=80
# Log-Datei definieren
LOG_FILE="nextcloud_image_resize.log"
# passed argument
FILE="$1"
# Log-function
log() {
echo "$(date '+%Y-%m-%d %H:%M:%S') - $1" >> "$LOG_FILE"
log "----- FILE WAS UPLOADED: $FILE -----"
# check for passed file
if [[ ! -f "$FILE" ]]; then
log "Error: File not found - $FILE"
exit 1
fi
# get needed information
DIR=$(dirname "$FILE")
BASENAME=$(basename "$FILE")
EXTENSION="${BASENAME##*.}"
FILENAME="${BASENAME%.*}"
log "Filename: $BASENAME | Directory: $DIR | File-Extension: $EXTENSION"
# just in case; probably not neeed as we are checking for MIME type using the extenal script definition
case "$EXTENSION" in
png|PNG|jpg|JPG|jpeg|JPEG)
log "File is supported."
log "Error: Unsupported file - $EXTENSION"
exit 2
esac
# create new file suffixed with "resized"
NEW_FILE="${DIR}/${FILENAME}_resized.${EXTENSION}"
log "New file: $NEW_FILE"
# Resize original FILE and save it as NEW_FILE
convert "$FILE" -resize "${SCALE_PERCENT}%" "$NEW_FILE"
# Check for processing
if [[ -f "$NEW_FILE" ]]; then
log "Success: File exists: $NEW_FILE"
exit 0
else
log "Error: File does not exis"
exit 3
fi
occ files:scan --help
Description:
rescan filesystem
Usage:
files:scan [options] [--] [<user_id>...]
Arguments:
user_id will rescan all files of the given user(s)
Options:
--output[=OUTPUT] Output format (plain, json or json_pretty, default is plain) [default: "plain"]
-p, --path=PATH limit rescan to this path, eg. --path="/alice/files/Music", the user_id is determined by the path and the user_id parameter and --all are ignored
--generate-metadata[=GENERATE-METADATA] Generate metadata for all scanned files; if specified only generate for named value [default: ""]
--all will rescan all files of all known users
--unscanned only scan files which are marked as not fully scanned
--shallow do not scan folders recursively
--home-only only scan the home storage, ignoring any mounted external storage or share
-h, --help Display help for the given command. When no command is given display help for the list command
-q, --quiet Do not output any message
-V, --version Display this application version
--ansi|--no-ansi Force (or disable --no-ansi) ANSI output
-n, --no-interaction Do not ask any interactive question
--no-warnings Skip global warnings, show command output only
-v|vv|vvv, --verbose Increase the verbosity of messages: 1 for normal output, 2 for more verbose output and 3 for debug
Thanks for the additional information.
With the following adjustments to my script, everything is working as expected
log "Rescan files for: $USER"
# ATTENTION: We need to call the occ tool directly
# if you would like to call the tool from the system, the following needs to be used; otherwise you will get an error like
# --- DIRECT CALL ---
# sudo -u www-data php /var/www/html/occ files:scan "$USER" --all >> "$LOG_FILE"
# --- ERROR ---
# Console has to be executed with the user that owns the file
# config/config.php
# Current user id: 0
# Owner id of config.php: 33
# Try adding 'sudo -u #33' to the beginning of the command (without the single quotes)
# If running with 'docker exec' try adding the option '-u 33' to the docker command (without the single quotes)
exit 0
else
exit 3
fi
Good point. I’ve added the --path Param and now only the passed directory is re-scanned
For everyone who is interested for the full script, find it below. Some short notices
Script rescales the picture to 60% resolution
Script minimized the quality to 60%
Script overwrites original file ($NEW_FILE is not used anymore)
scale images script
#!/bin/bash
SCALE_PERCENT=60
IMAGE_QUALITY=60
# Define log file
# passed argument
FILE="$1"
USER="$2"
FILE_REL="$3"
# Log-function
log() {
exit 1
fi
DIR_REL=$(dirname "$FILE_REL")
log "Filename: $BASENAME | Directory: $DIR | File-Extension: $EXTENSION | User: $USER"
exit 2
esac
log "New file: $NEW_FILE to path $DIR_REL with quality $IMAGE_QUALITY %"
# Resize original FILE and save it as NEW_FILE with Quality: $IMAGE_QUALITY
convert "$FILE" -resize "${SCALE_PERCENT}%" -quality "$IMAGE_QUALITY" -strip -interlace JPEG "$FILE"
if [[ -f "$FILE" ]]; then
log "Success: File exists: $NEW_FILE; delete old file"
log "START - Rescan files for user: $USER"
php /var/www/html/occ files:scan "$USER" --path="$DIR_REL" >> "$LOG_FILE"
log "END - Rescan files for user: $USER"
# --- ERROR ---
# config/config.php
exit 0
else
exit 3
fi
It’s called using the the external workflow script using the following command line: /var/www/html/CUSTOM_DATA/scale_image.sh %f %o %n
