Some or all of the below information will be requested if it isn’t supplied; for fastest response please provide as much as you can. ![]()
31.0.2
Ubuntu 24.04
- `Apache 2.4.62
traefik v3.3
- PHP version (e.g, 8.3):
8.3.19
- Collabora version:
24.04.13.2.1
Yes
When I configured collabora
docker image: nextcloud:31.0.2-apache with separate redis, mariadb, and traefik
no
I set up nextcloud and it’s working great, nice and fast all around. I want to use collabora, so I set up a collabora server and that works well too. The only issue I have is that it takes a long time for new documents to be made.
Specifically, when I click New and choose any of the files that have templates as options, the request to /ocs/v2.php/apps/files/api/v1/templates takes 30s or more to return, but it returns with an HTTP 200. This request provides the info for the templates in the dialog window, so I need to wait for this each time I want to make a new document, which is very annoying.
If I change NC to use the built in CODE server this goes away, and that request finishes in a second or so.
My challenge is, I can’t see any errors in the logs, so I really don’t know how to go about debugging this. Please help?
- Install nextcloud
- Install collabora
- Configure nextcloud to use collabora
None relating to this, but I’m happy to share anyway if needed. It’s likely I’m missing something
The only error that shows in my logs is
{"reqId":"HFmOd771rpeBWuuTmd3g","level":3,"time":"2025-04-03T05:47:44+00:00","remoteAddr":"10.10.11.2","user":"admin","app":"jsresourceloader","method":"GET","url":"/index.php/apps/files/","message":"Could not find resource text/js/.js to load","userAgent":"Mozilla/5.0 (Macintosh; Intel Mac OS X 10_15_7) AppleWebKit/605.1.15 (KHTML, like Gecko) Version/18.3.1 Safari/605.1.15","version":"31.0.2.1","data":{"app":"jsresourceloader"},"id":"67ee21af121fa"}
NC forwards these to stderr in this container, and I don’t see the same error as above here
"dbtype": "mysql",
"version": "31.0.2.1",
"overwrite.cli.url": "http:\/\/localhost",
"dbport": "",
"mysql.utf8mb4": true,
"overwriteprotocol": "https",
"loglevel": 2,
"theme": "",
"templatedirectory": "\/var\/www\/html\/config\/templates\/",
"oidc_login_provider_url": "***",
"oidc_login_client_id": "nextcloud",
"oidc_login_client_secret": "***",
"oidc_login_disable_registration": false,
"app_install_overwrite": [
"extract"
- activity: 4.0.0
- app_api: 5.0.2
- bruteforcesettings: 4.0.0
- calendar: 5.2.0
- calendar_resource_management: 0.9.0
- circles: 31.0.0
- comments: 1.21.0
- contacts: 7.0.4
- contactsinteraction: 1.12.0
- dashboard: 7.11.0
- dav: 1.33.0
- deck: 1.15.0
- federation: 1.21.0
- files: 2.3.1
- files_downloadlimit: 4.0.0
- files_fulltextsearch: 31.0.0
- files_mindmap: 0.0.33
- files_pdfviewer: 4.0.0
- files_reminders: 1.4.0
- files_sharing: 1.23.1
- files_trashbin: 1.21.0
- files_versions: 1.24.0
- firstrunwizard: 4.0.0
- fulltextsearch: 31.0.0
- groupfolders: 19.0.4
- htmlviewer: 31.0.0
- logreader: 4.0.0
- mail: 4.3.3
- metadata: 0.22.0
- notifications: 4.0.0
- oauth2: 1.19.1
- oidc_login: 3.2.2
- password_policy: 3.0.0
- previewgenerator: 5.8.0
- privacy: 3.0.0
- profile: 1.0.0
- provisioning_api: 1.21.0
- recommendations: 4.0.0
- related_resources: 2.0.0
- richdocuments: 8.6.3
- richdocumentscode: 24.4.1302
- serverinfo: 3.0.0
- settings: 1.14.0
- sharebymail: 1.21.0
- support: 3.0.0
- survey_client: 3.0.0
- systemtags: 1.21.1
- text: 5.0.0
- theming: 2.6.1
- updatenotification: 1.21.0
- user_status: 1.11.0
- viewer: 4.0.0
- webhook_listeners: 1.2.0
- workflowengine: 2.13.0
- admin_audit: 1.21.0
- analytics: 5.3.0 (installed 5.3.0)
- appointments: 2.4.3 (installed 2.4.3)
- drawio: 3.0.4 (installed 3.0.4)
- encryption: 2.19.0
- files_external: 1.23.0
- integration_excalidraw: 2.4.0 (installed 2.4.0)
- integration_mattermost: 2.1.0 (installed 2.1.0)
- notes: 4.11.0
- photos: 4.0.0-dev.1 (installed 4.0.0-dev.1)
- spreed: 21.0.1 (installed 21.0.0)
- suspicious_login: 9.0.1
- tables: 0.9.0 (installed 0.9.0)
- thesearchpage: 1.2.10 (installed 1.2.10)
- user_ldap: 1.22.0
- weather_status: 1.11.0 (installed 1.11.0)
- whiteboard: 1.0.5 (installed 1.0.5)
