Reorder digging deeper developer documentation
Hello guys.
I have seen the documentation section digging deeper is a rather loose collection of examples and detailed description of various use-cases. All right so far.
I would like to file a PR to make these sections alphabetical for simpler reading. There seem to be a alphabetical start and then new entries were added at the ending. However, I do not want to break a preexisting logical structure that I do not see right now.
Does anyone here see a structure in the digging deeper section that might be not obvious to me or do you think an alphabetical ordering might be a good option?
Christian
I don’t see a structure in that digging deeper section. Because it really seems to be a mix of everything, I doubt that an alphabetical order makes reading easier. But at least that would be some kind of structure.
I don’t think there is a structure at the moment. :smiley:
Thanks for mentioning it :+1:
ABC sounds good to me.
For cross-reference: https://github.com/nextcloud/documentation/pull/12270
