i would like to have a nextcloud server running wich uses a data directory on another virtual machine. This data server is already set up and works correctly, and i am able to access it from another client.
The problem is: when i set up nextcloud, it doesnt use the remote server (even if i tell it to use the remote database in the installation wizard and the config.php file is correct), but creates a local data directory and stores all the files in it…
Good idea, but i have a mysql cluster running wich i would like to use. So i kind of need to use the remote connection, and i thought nextcloud would support it… Or am i wrong?
