Regular expression for file access add-on in Flow
Nextcloud version (eg, 29.0.5): 26.0.13
Operating system and version (eg, Ubuntu 24.04): Debian 12
Apache or nginx version (eg, Apache 2.4.25): Apache
PHP version (eg, 8.3): 7.3
What a correct set for regular expressions to use on flow app for file access control?
For example to block files like file.3dmbak i try to use ^.*.3dmbak$
It work on regex101, but flow return: "The given regular expression is invalid "
Kind regards.
From the example shown when you create a rule, you just need:
/^.*.3dmbak$/i
and then if I try to rename a file to whatever.3dmbak, it does not work.
