Redis NOT Work ANYWAY
    • 31.0.1
    • Ubuntu 22.04
    • Apache 2.4.52
    • Traefik 3
    • 8.3.20
    • YES
    • replace me
    • BAREMETAL
    • NO
Files are locked - redis installed and exist in config.php but error still shows in Admin settings
  1. Create folder in terminal in external storage
  2. Move files and folders via terminal from another folder
  3. Give rights chmod and chown to www-data
  4. cron job installed
  5. Can.t do anything with files in this folders
LOGS
Exception Error while copying file to target location (copied: -1 bytes, expected filesize: 76115 bytes)
  1. /var/www/oblako.stratim/3rdparty/sabre/dav/lib/DAV/Server.phpLine 1137
OCA\DAV\Connector\Sabre\File->put
  1. /var/www/oblako.stratim/3rdparty/sabre/dav/lib/DAV/CorePlugin.phpLine 492
Sabre\DAV\Server->updateFile
  "*** sensitive parameters replaced ***"
  1. /var/www/oblako.stratim/3rdparty/sabre/event/lib/WildcardEmitterTrait.phpLine 89
Sabre\DAV\CorePlugin->httpPut
  1. /var/www/oblako.stratim/3rdparty/sabre/dav/lib/DAV/Server.phpLine 472
Sabre\DAV\Server->emit
  1. /var/www/oblako.stratim/apps/dav/lib/Connector/Sabre/Server.phpLine 49
Sabre\DAV\Server->invokeMethod
  1. /var/www/oblako.stratim/apps/dav/lib/Server.phpLine 397
OCA\DAV\Connector\Sabre\Server->start
  1. /var/www/oblako.stratim/apps/dav/appinfo/v2/remote.phpLine 21
OCA\DAV\Server->exec
  1. /var/www/oblako.stratim/remote.phpLine 145
undefinedundefinedrequire_once
  "/var/www/oblako.stratim/apps/dav/appinfo/v2/remote.php"
Raw log entry
  "reqId": "ynh1HUbIgKbtjSgjZxIN",
  "level": 3,
  "time": "2025-04-22T17:04:46+03:00",
  "remoteAddr": "37.228.90.158",
  "user": "Georgii Trushkov",
  "app": "webdav",
  "method": "PUT",
  "url": "/remote.php/dav/files/Georgii%20Trushkov/%D0%9B%D0%B5%D1%82%D0%B0%D1%82%D0%B5%D0%BB%D1%8C%D0%BD%D1%8B%D0%B5%20%D0%B0%D0%BF%D0%BF%D0%B0%D1%80%D0%B0%D1%82%D1%8B/%D0%92%D0%BE%D1%80%D0%BE%D0%B1%D0%B5%D0%B9/%D0%9D%D0%BE%D0%B2%D1%8B%D0%B9/%D0%94%D0%BE%D0%BA%D1%83%D0%BC%D0%B5%D0%BD%D1%82%D0%B0%D1%86%D0%B8%D1%8F/%D0%9A%D0%94/%D0%A1%D0%B1%D0%BE%D1%80%D0%BA%D0%B8/%D0%A0%D1%8B%D1%87%D0%B0%D0%B3%20%D0%B2%20%D1%81%D0%B1%D0%BE%D1%80%D0%B5%20(%D0%BF%D0%B5%D1%80%D0%B5%D0%B4%D0%BD%D0%B8%D0%B9%20%D0%BF%D1%80%D0%B0%D0%B2%D1%8B%D0%B9)%20-01/%D0%9F%D0%BB%D0%B0%D1%81%D1%82%D0%B8%D0%BD%D0%B0%20%D0%BC%D0%BE%D1%82%D0%BE%D1%80%D0%B0%20-%20%D0%92%D0%A0%D0%91.741154.007.pdf",
  "message": "Error while copying file to target location (copied: -1 bytes, expected filesize: 76115 bytes)",
  "userAgent": "Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/135.0.0.0 Safari/537.36",
  "version": "31.0.1.2",
  "exception": {
    "Exception": "Sabre\\DAV\\Exception",
    "Message": "Error while copying file to target location (copied: -1 bytes, expected filesize: 76115 bytes)",
    "Code": 0,
    "Trace": [
        "file": "/var/www/oblako.stratim/3rdparty/sabre/dav/lib/DAV/Server.php",
        "line": 1137,
        "function": "put",
        "class": "OCA\\DAV\\Connector\\Sabre\\File",
        "type": "->"
        "file": "/var/www/oblako.stratim/3rdparty/sabre/dav/lib/DAV/CorePlugin.php",
        "line": 492,
        "function": "updateFile",
        "class": "Sabre\\DAV\\Server",
        "type": "->",
        "args": [
        "file": "/var/www/oblako.stratim/3rdparty/sabre/event/lib/WildcardEmitterTrait.php",
        "line": 89,
        "function": "httpPut",
        "class": "Sabre\\DAV\\CorePlugin",
        "type": "->"
        "line": 472,
        "function": "emit",
        "type": "->"
        "file": "/var/www/oblako.stratim/apps/dav/lib/Connector/Sabre/Server.php",
        "line": 49,
        "function": "invokeMethod",
        "type": "->"
        "file": "/var/www/oblako.stratim/apps/dav/lib/Server.php",
        "line": 397,
        "function": "start",
        "class": "OCA\\DAV\\Connector\\Sabre\\Server",
        "type": "->"
        "file": "/var/www/oblako.stratim/apps/dav/appinfo/v2/remote.php",
        "line": 21,
        "function": "exec",
        "class": "OCA\\DAV\\Server",
        "type": "->"
        "file": "/var/www/oblako.stratim/remote.php",
        "line": 145,
        "args": [
        "function": "require_once"
    "File": "/var/www/oblako.stratim/apps/dav/lib/Connector/Sabre/File.php",
    "Line": 240,
    "exception": [],
    "CustomMessage": "Error while copying file to target location (copied: -1 bytes, expected filesize: 76115 bytes)"
  "id": "6807a7941dffd"
CONFIG.PHP
  'memcache.local' => '\OC\Memcache\APCu',
  'memcache.locking' => '\OC\Memcache\Redis',
  'redis' =>
    'host' => '/run/redis/redis-server.sock',
    'port' => 0,
    'timeout' => 0.0,
  'instanceid' => 'ocaozq45akdu',
    0 => '192.168.90.254',
    0 => 'oblako.stratim',
    1 => '192.168.0.198',
    2 => '46.34.156.226',
    3 => 'cloud.stratim.tech',
  'datadirectory' => '/var/www/oblako.stratim/data',
  'version' => '31.0.1.2',
  'overwrite.cli.url' => 'http://cloud.stratim.tech',
  'logtimezone' => 'Europe/Moscow',
  'default_phone_region' => 'RU',
  'default_language' => 'ru',
  'dbname' => 'nextcloud',
  'dbhost' => 'localhost',
  'dbuser' => 'nextcloud',
  'force_locale' => 'ru_RU',
  'mail_smtpmode' => 'smtp',
  'mail_smtpsecure' => 'ssl',
  'mail_from_address' => 'sysadmin',
  'mail_domain' => 'stratim.tech',
  'mail_smtphost' => 'smtp.yandex.ru',
  'mail_smtpport' => '465',
  'mail_smtpauth' => 1,
  'defaultapp' => 'files',
  'app_install_overwrite' =>
    0 => 'apporder',
    1 => 'webhooks',
  'theme' => '',
  'loglevel' => 3,
  • activity: 4.0.0
  • admin_audit: 1.21.0
  • bruteforcesettings: 4.0.0
  • calendar: 5.2.1
  • circles: 31.0.0
  • collectives: 2.16.1
  • comments: 1.21.0
  • contacts: 7.0.6
  • contactsinteraction: 1.12.0
  • dav: 1.33.0
  • deck: 1.15.0
  • external: 6.0.2
  • federation: 1.21.0
  • files: 2.3.1
  • files_3dmodelviewer: 0.0.15
  • files_accesscontrol: 2.0.0
  • files_automatedtagging: 2.0.0
  • files_bpm: 1.7.1
  • files_downloadlimit: 4.0.0
  • files_external: 1.23.0
  • files_mindmap: 0.0.33
  • files_pdfviewer: 4.0.0
  • files_reminders: 1.4.0
  • files_sharing: 1.23.1
  • files_trashbin: 1.21.0
  • files_versions: 1.24.0
  • flow_notifications: 2.0.0
  • groupfolders: 19.0.4
  • logreader: 4.0.0
  • notes: 4.12.0
  • notifications: 4.0.0
  • oauth2: 1.19.1
  • onlyoffice: 9.7.0
  • password_policy: 3.0.0
  • photos: 4.0.0-dev.1
  • privacy: 3.0.0
  • profile: 1.0.0
  • provisioning_api: 1.21.0
  • recommendations: 4.0.0
  • related_resources: 2.0.0
  • serverinfo: 3.0.0
  • settings: 1.14.0
  • sharebymail: 1.21.0
  • support: 3.0.0
  • survey_client: 3.0.0
  • systemtags: 1.21.1
  • tasks: 0.16.1
  • text: 5.0.0
  • theming: 2.6.1
  • updatenotification: 1.21.0
  • user_saml: 6.5.0
  • viewer: 4.0.0
  • webhook_listeners: 1.2.0
  • webhooks: 0.4.3
  • workflow_media_converter: 1.13.5
  • workflowengine: 2.13.0
  • app_api: 5.0.2 (installed 4.0.0)
  • apporder: 0.15.0 (installed 0.15.0)
  • cadviewer: 10.10.7 (installed 10.10.7)
  • dashboard: 7.11.0 (installed 7.10.0)
  • encryption: 2.19.0
  • firstrunwizard: 4.0.0 (installed 3.0.0)
  • side_menu: 4.1.1 (installed 4.1.1)
  • spreed: 21.0.1 (installed 21.0.1)
  • suspicious_login: 9.0.1
  • user_ldap: 1.22.0
  • user_status: 1.11.0 (installed 1.11.0)
  • weather_status: 1.11.0 (installed 1.11.0)
These errors show that I did not do according to the documentation
PDO SQL set
noindex,nofollow added
REdis installed as socket
  • Collectives app is enabled, but PDO SQLite driver is missing. Please install it to enable full text search of the page content.
  • Some files have not passed the integrity check. List of invalid files… Rescan… For more details see the documentation :arrow_upper_right:.
  • 1274 errors in the logs since 15 апреля 2025 г., 17:44:49
  • Some headers are not set correctly on your instance - The X-Robots-Tag HTTP header is not set to noindex,nofollow. This is a potential security or privacy risk, as it is recommended to adjust this setting accordingly. For more details see the documentation :arrow_upper_right:.
  • The PHP OPcache module is not properly configured. The OPcache interned strings buffer is nearly full. To assure that repeating strings can be effectively cached, it is recommended to apply “opcache.interned_strings_buffer” to your PHP configuration with a value higher than “16”… For more details see the documentation :arrow_upper_right:.
You could actually use redis for your memcache.local also. here’s my redis array:
‘memcache.local’ => ‘\OC\Memcache\Redis’,
‘memcache.distributed’ => ‘\OC\Memcache\Redis’,
‘memcache.locking’ => ‘\OC\Memcache\Redis’,
‘redis’ =>
‘host’ => ‘/run/redis/redis-server.sock’,
‘port’ => 0,
‘timeout’ => 0.0,
‘read_timeout’ => 0.0,
Also make sure you have the right settings in your /etc/redis/redis.conf file to allow the use of redis to listen on a socket.
