example
longer
example
here
Nextcloud version 18.0.1
Operating system and version: Ubuntu Mate 18.04
Apache or nginx version: 2.4.29
PHP version: 7.2.24
The issue you are facing: Warnings from Overview page still state the following: "No memory cache has been configured. To enhance performance, please configure a memcache, if available. "
Is this the first time you’ve seen this error? (Y/N): Y, it has been there since the installation.
The output of ps as | grep redis :
'memcahce.local' => '\OC\Memcache\APCu',
'memcache.distributed' => '\OC\Memcache\Redis',
'memcache.locking' => '\OC\Memcache\Redis',
'redis' =>
'port' => 0,
'timeout' => 2.0,
'dbindex' => 0,
Output of php -m
[PHP Modules]
apcu
bz2
calendar
Core
ctype
curl
date
dom
exif
fileinfo
filter
ftp
gd
gettext
hash
iconv
igbinary
imagick
intl
json
libxml
mbstring
mysqli
mysqlnd
openssl
pcntl
pcre
PDO
pdo_mysql
pdo_pgsql
pgsql
Phar
posix
readline
recode
redis
Reflection
session
shmop
SimpleXML
sockets
sodium
SPL
standard
sysvmsg
sysvsem
sysvshm
tidy
tokenizer
wddx
xml
xmlreader
xmlrpc
xmlwriter
xsl
Zend OPcache
zip
zlib
[Zend Modules]
Zend OPcache
Output of getent group www-data
www-data:x:33:redis
Output of getent group redis
redis:x:138:www-data
redis.conf has been set with the following:
bind 127.0.0.1
protected-mode yes
port 0
unixsocket /var/run/redis/redis-server.sock
unixsocketperm 777
Output of redis-cli -p 0:
Could not connect to Redis at 127.0.0.1:0: Connection refused
not connected>
Output of redis-cli -s /var/run/redis/redis-server.sock MONITOR:
OK
1583108531.131195 [0 unix:/var/run/redis/redis-server.sock] "SELECT" "0"
1583108531.428310 [0 unix:/var/run/redis/redis-server.sock] "SELECT" "0"
1583108532.099728 [0 unix:/var/run/redis/redis-server.sock] "SELECT" "0"
1583108536.073153 [0 unix:/var/run/redis/redis-server.sock] "SELECT" "0"
1583108538.026951 [0 unix:/var/run/redis/redis-server.sock] "SELECT" "0"
1583108538.209583 [0 unix:/var/run/redis/redis-server.sock] "GET" "0d079553b0e20bf8aef987f4f8c7a574/imagePath-21534aeba7e160d7d4b3c670f583be2f-core-actions/user.svg"
1583108538.210173 [0 unix:/var/run/redis/redis-server.sock] "GET" "0d079553b0e20bf8aef987f4f8c7a574/imagePath-21534aeba7e160d7d4b3c670f583be2f-settings-password.svg"
1583108538.210630 [0 unix:/var/run/redis/redis-server.sock] "GET" "0d079553b0e20bf8aef987f4f8c7a574/imagePath-21534aeba7e160d7d4b3c670f583be2f-core-clients/phone.svg"
1583108538.218612 [0 unix:/var/run/redis/redis-server.sock] "GET" "0d079553b0e20bf8aef987f4f8c7a574/imagePath-21534aeba7e160d7d4b3c670f583be2f-core-actions/settings-dark.svg"
1583108538.229607 [0 unix:/var/run/redis/redis-server.sock] "GET" "0d079553b0e20bf8aef987f4f8c7a574/imagePath-21534aeba7e160d7d4b3c670f583be2f-activity-activity-dark.svg"
1583108538.232821 [0 unix:/var/run/redis/redis-server.sock] "GET" "0d079553b0e20bf8aef987f4f8c7a574/imagePath-21534aeba7e160d7d4b3c670f583be2f-audioplayer-app-dark.svg"
1583108538.233856 [0 unix:/var/run/redis/redis-server.sock] "GET" "0d079553b0e20bf8aef987f4f8c7a574/imagePath-21534aeba7e160d7d4b3c670f583be2f-files_external-app-dark.svg"
1583108538.234402 [0 unix:/var/run/redis/redis-server.sock] "GET" "0d079553b0e20bf8aef987f4f8c7a574/imagePath-21534aeba7e160d7d4b3c670f583be2f-accessibility-app-dark.svg"
1583108538.236155 [0 unix:/var/run/redis/redis-server.sock] "GET" "0d079553b0e20bf8aef987f4f8c7a574/imagePath-21534aeba7e160d7d4b3c670f583be2f-core-actions/share.svg"
1583108538.239097 [0 unix:/var/run/redis/redis-server.sock] "GET" "0d079553b0e20bf8aef987f4f8c7a574/imagePath-21534aeba7e160d7d4b3c670f583be2f-workflowengine-app-dark.svg"
1583108538.241942 [0 unix:/var/run/redis/redis-server.sock] "GET" "0d079553b0e20bf8aef987f4f8c7a574/imagePath-21534aeba7e160d7d4b3c670f583be2f-privacy-app-dark.svg"
1583108538.243676 [0 unix:/var/run/redis/redis-server.sock] "GET" "0d079553b0e20bf8aef987f4f8c7a574/imagePath-21534aeba7e160d7d4b3c670f583be2f-settings-admin.svg"
I have honestly tried everything I can think of at this point and am desperate for any advice anyone can offer.
Many Thanks.
