after updating to NCP v1.54.2, I get the following error messages in the Nextcloud log every time I restart:
[bruteforcesettings] Fatal: Error during app loading: LOADING Redis is loading the dataset in memory
von ? von – um 10.05.2024, 12:18:45
{“reqId”:“SCe54t5Sob235WuMgwIr”,“level”:4,“time”:“2024-05-10T10:18:45+00:00”,“remoteAddr”:“”,“user”:“–”,“app”:“bruteforcesettings”,“method”:“”,“url”:“–”,“message”:“Error during app loading: LOADING Redis is loading the dataset in memory”,“userAgent”:“–”,“version”:“28.0.3.2”,“exception”:{“Exception”:“RedisException”,“Message”:“LOADING Redis is loading the dataset in memory”,“Code”:0,“Trace”:[{“file”:“/var/www/nextcloud/lib/private/Memcache/Redis.php”,“line”:76,“function”:“get”,“class”:“Redis”,“type”:“->”},{“file”:“/var/www/nextcloud/lib/autoloader.php”,“line”:154,“function”:“get”,“class”:“OC\Memcache\Redis”,“type”:“->”},{“function”:“load”,“class”:“OC\Autoloader”,“type”:“->”},{“file”:“/var/www/nextcloud/lib/private/AppFramework/Bootstrap/Coordinator.php”,“line”:217,“function”:“class_exists”},{“file”:“/var/www/nextcloud/lib/private/App/AppManager.php”,“line”:397,“function”:“isBootable”,“class”:“OC\AppFramework\Bootstrap\Coordinator”,“type”:“->”},{“file”:“/var/www/nextcloud/lib/private/App/AppManager.php”,“line”:213,“function”:“loadApp”,“class”:“OC\App\AppManager”,“type”:“->”},{“file”:“/var/www/nextcloud/lib/private/legacy/OC_App.php”,“line”:125,“function”:“loadApps”,“class”:“OC\App\AppManager”,“type”:“->”},{“file”:“/var/www/nextcloud/lib/private/Console/Application.php”,“line”:114,“function”:“loadApps”,“class”:“OC_App”,“type”:“::”},{“file”:“/var/www/nextcloud/console.php”,“line”:99,“function”:“loadCommands”,“class”:“OC\Console\Application”,“type”:“->”},{“file”:“/var/www/nextcloud/occ”,“line”:11,“args”:[“/var/www/nextcloud/console.php”],“function”:“require_once”}],“File”:“/var/www/nextcloud/lib/private/Memcache/Redis.php”,“Line”:76,“message”:“Error during app loading: LOADING Redis is loading the dataset in memory”,“exception”:,“CustomMessage”:“Error during app loading: LOADING Redis is loading the dataset in memory”},“id”:“663df4bae3789”}
[core] Fehler: Exception thrown: RedisException
GET /.env.example
von 31.7.62.226 von – um 10.05.2024, 12:18:45
{“reqId”:“Zj30gmnz_Gjio81yQcEyyQAAAEY”,“level”:3,“time”:“2024-05-10T10:18:45+00:00”,“remoteAddr”:“31.7.62.226”,“user”:“–”,“app”:“core”,“method”:“GET”,“url”:“/.env.example”,“message”:“Exception thrown: RedisException”,“userAgent”:“Mozilla/5.0 (Linux; Android 9; SAMSUNG SM-G965W Build/PPR1.180610.011) AppleWebKit/537.36 (KHTML, like Gecko) SamsungBrowser/9.4 Chrome/67.0.3396.87 Mobile Safari/537.36”,“version”:“28.0.3.2”,“exception”:{“Exception”:“RedisException”,“Message”:“Redis server /var/run/redis/redis.sock:0 went away”,“Code”:0,“Trace”:[{“file”:“/var/www/nextcloud/lib/private/Memcache/Redis.php”,“line”:76,“function”:“get”,“class”:“Redis”,“type”:“->”},{“file”:“/var/www/nextcloud/lib/private/URLGenerator.php”,“line”:203,“function”:“get”,“class”:“OC\Memcache\Redis”,“type”:“->”},{“file”:“/var/www/nextcloud/lib/private/legacy/template/functions.php”,“line”:249,“function”:“imagePath”,“class”:“OC\URLGenerator”,“type”:“->”},{“file”:“/var/www/nextcloud/core/templates/layout.guest.php”,“line”:20,“function”:“image_path”},{“file”:“/var/www/nextcloud/lib/private/Template/Base.php”,“line”:180,“args”:[“/var/www/nextcloud/core/templates/layout.guest.php”],“function”:“include”},{“file”:“/var/www/nextcloud/lib/private/Template/Base.php”,“line”:150,“function”:“load”,“class”:“OC\Template\Base”,“type”:“->”},{“file”:“/var/www/nextcloud/lib/private/legacy/OC_Template.php”,“line”:139,“function”:“fetchPage”,“class”:“OC\Template\Base”,“type”:“->”},{“file”:“/var/www/nextcloud/lib/private/legacy/OC_Template.php”,“line”:170,“function”:“fetchPage”,“class”:“OC_Template”,“type”:“->”},{“file”:“/var/www/nextcloud/lib/private/Template/Base.php”,“line”:132,“function”:“fetchPage”,“class”:“OC_Template”,“type”:“->”},{“file”:“/var/www/nextcloud/lib/private/legacy/OC_Template.php”,“line”:258,“function”:“printPage”,“class”:“OC\Template\Base”,“type”:“->”},{“file”:“/var/www/nextcloud/lib/base.php”,“line”:1126,“function”:“printErrorPage”,“class”:“OC_Template”,“type”:“::”},{“file”:“/var/www/nextcloud/index.php”,“line”:39,“function”:“handleRequest”,“class”:“OC”,“type”:“::”}],“File”:“/var/www/nextcloud/lib/private/Memcache/Redis.php”,“Line”:76,“CustomMessage”:“Exception thrown: RedisException”},“id”:“663df4bae384c”}
PROPFIND /remote.php/dav/files/malte/
von 79.193.0.5 von – um 10.05.2024, 12:18:45
{“reqId”:“Zj30hI7iSVcKq-IIKdjuRgAAAAE”,“level”:3,“time”:“2024-05-10T10:18:45+00:00”,“remoteAddr”:“79.193.0.5”,“user”:“–”,“app”:“core”,“method”:“PROPFIND”,“url”:“/remote.php/dav/files/malte/”,“message”:“Exception thrown: RedisException”,“userAgent”:“Mozilla/5.0 (Windows) mirall/3.13.0stable-Win64 (build 20240423) (Nextcloud, windows-10.0.19045 ClientArchitecture: x86_64 OsArchitecture: x86_64)”,“version”:“28.0.3.2”,“exception”:{“Exception”:“RedisException”,“Message”:“Redis server /var/run/redis/redis.sock:0 went away”,“Code”:0,“Trace”:[{“file”:“/var/www/nextcloud/lib/private/Memcache/Redis.php”,“line”:76,“function”:“get”,“class”:“Redis”,“type”:“->”},{“file”:“/var/www/nextcloud/lib/autoloader.php”,“line”:154,“function”:“get”,“class”:“OC\Memcache\Redis”,“type”:“->”},{“function”:“load”,“class”:“OC\Autoloader”,“type”:“->”},{“file”:“/var/www/nextcloud/lib/private/Server.php”,“line”:1170,“function”:“class_exists”},{“file”:“/var/www/nextcloud/lib/private/AppFramework/Utility/SimpleContainer.php”,“line”:175,“function”:“OC\{closure}”,“class”:“OC\Server”,“type”:“->”,“args”:[“*** sensitive parameters replaced “]},{“file”:”/var/www/nextcloud/3rdparty/pimple/pimple/src/Pimple/Container.php",“line”:122,“function”:“OC\AppFramework\Utility\{closure}”,“class”:“OC\AppFramework\Utility\SimpleContainer”,“type”:“->”,“args”:[" sensitive parameters replaced “]},{“file”:”/var/www/nextcloud/lib/private/AppFramework/Utility/SimpleContainer.php",“line”:142,“function”:“offsetGet”,“class”:“Pimple\Container”,“type”:“->”},{“file”:“/var/www/nextcloud/lib/private/ServerContainer.php”,“line”:173,“function”:“query”,“class”:“OC\AppFramework\Utility\SimpleContainer”,“type”:“->”},{“file”:“/var/www/nextcloud/lib/private/AppFramework/Utility/SimpleContainer.php”,“line”:64,“function”:“query”,“class”:“OC\ServerContainer”,“type”:“->”},{“file”:“/var/www/nextcloud/lib/private/Server.php”,“line”:2112,“function”:“get”,“class”:“OC\AppFramework\Utility\SimpleContainer”,“type”:“->”},{“file”:“/var/www/nextcloud/lib/private/Server.php”,“line”:1360,“function”:“getThemingDefaults”,“class”:“OC\Server”,“type”:“->”},{“file”:“/var/www/nextcloud/lib/private/AppFramework/Utility/SimpleContainer.php”,“line”:175,“function”:“OC\{closure}”,“class”:“OC\Server”,“type”:“->”,“args”:[" sensitive parameters replaced “]},{“file”:”/var/www/nextcloud/3rdparty/pimple/pimple/src/Pimple/Container.php",“line”:122,“function”:“OC\AppFramework\Utility\{closure}”,“class”:“OC\AppFramework\Utility\SimpleContainer”,“type”:“->”,“args”:[" sensitive parameters replaced ***”]},{“file”:“/var/www/nextcloud/lib/private/AppFramework/Utility/SimpleContainer.php”,“line”:142,“function”:“offsetGet”,“class”:“Pimple\Container”,“type”:“->”},{“file”:“/var/www/nextcloud/lib/private/ServerContainer.php”,“line”:173,“function”:“query”,“class”:“OC\AppFramework\Utility\SimpleContainer”,“type”:“->”},{“file”:“/var/www/nextcloud/lib/private/AppFramework/Utility/SimpleContainer.php”,“line”:64,“function”:“query”,“class”:“OC\ServerContainer”,“type”:“->”},{“file”:“/var/www/nextcloud/lib/public/Server.php”,“line”:55,“function”:“get”,“class”:“OC\AppFramework\Utility\SimpleContainer”,“type”:“->”},{“file”:“/var/www/nextcloud/lib/private/legacy/OC_Template.php”,“line”:80,“function”:“get”,“class”:“OCP\Server”,“type”:“::”},{“file”:“/var/www/nextcloud/lib/private/legacy/OC_Template.php”,“line”:281,“function”:“__construct”,“class”:“OC_Template”,“type”:“->”},{“file”:“/var/www/nextcloud/remote.php”,“line”:92,“function”:“printExceptionErrorPage”,“class”:“OC_Template”,“type”:“::”},{“file”:“/var/www/nextcloud/remote.php”,“line”:174,“function”:“handleException”}],“File”:“/var/www/nextcloud/lib/private/Memcache/Redis.php”,“Line”:76,“CustomMessage”:“Exception thrown: RedisException”},“id”:“663df4bae3b77”}
Does anyone have any idea what is causing this error and how to fix it?
I am using NextCloudPi 28.0.3 on a Raspi4.
Thank you very much,
Malte
