Redis cluster multi write on kubernetes
Hello
Im using docker image 19.0.1-apache and the cluster sit on top of kubernetes
Redis version: 6.0.6
when I setup redis master-slave, everything is working as intended
But when I try to setup redis cluster master-master, Im getting this error:
  "Exception": "RedisClusterException",
  "Message": "Couldn't map cluster keyspace using any provided seed",
  "Code": 0,
  "Trace": [
      "file": "/var/www/html/lib/private/RedisFactory.php",
      "line": 65,
      "function": "__construct",
      "class": "RedisCluster",
      "type": "->",
      "args": [
        null,
          "redis-cluster-0.redis-cluster-headless.nextcloud.svc.cluster.local:6379",
          "redis-cluster-1.redis-cluster-headless.nextcloud.svc.cluster.local:6379",
          "redis-cluster-2.redis-cluster-headless.nextcloud.svc.cluster.local:6379"
        0,
        0
This is the config.php part of redis:
   'redis.cluster' => [
        'seeds' => [
            'redis-cluster-0.redis-cluster-headless.nextcloud.svc.cluster.local:6379',
            'redis-cluster-1.redis-cluster-headless.nextcloud.svc.cluster.local:6379',
            'redis-cluster-2.redis-cluster-headless.nextcloud.svc.cluster.local:6379',
        'timeout' => 0.0,
        'read_timeout' => 0.0,
        'failover_mode' => \RedisCluster::FAILOVER_ERROR,
        'password' => '',
What have I missed ? =X
I am facing a similar problem… Are you using Redis Sentinel or what do you mean with “master-master” cluster?
