My nextcloud data directory is in a fast 250GB ssd however it’s not really utilized as I’m primarily using external local storage folder mounts (usb drives).
If I delete a folder than is 1TB in the local external storage folder…does it show up in the recycle bin?
If not, is there a way to make it show up (perhaps change the recycle bin location?)
