Hey Guys,
I’m facing a massive issue with nextcloud 25.0.0 directly after I updated. Before Updating I made a 1:1 copy of the data and the database, created an extra docker container and updated this. Everything was working fine with it, but when I went for the real thing it seems it broke. I’m seeing massive log entries and I can’t install recognize. I’m not sure what’s the underlying issue, but hopefulle someone from you has an idea.
I provided some information, if you need anything else, let me know!
Thank you in advance,
Autchi
Nextcloud version: 25.0.0
Operating system and version: official docker container
-recognize won’t install,
-massive ammounts of log entries
Is this the first time you’ve seen this error? Yes
-always going on, don’t have to do anything
The output of your Nextcloud log in Admin > Logging: dosen’t show anything (only really short and then it’s gone immediately)
'redis' =>
'host' => '-',
'port' => 6379,
'datadirectory' => '/data',
'instanceid' => '-',
'passwordsalt' => '-',
'secret' => '-',
0 => 'nextcloud.1.eu',
1 => 'nextcloud.2.eu',
2 => 'local:8443',
'trusted_proxies' =>
0 => 'swag',
'log_type' => 'file',
'logfile' => '/config/log/nextcloud.log',
'loglevel' => 0,
'syslog_tag' => 'Nextcloud',
'version' => '25.0.0.18',
'overwrite.cli.url' => 'https://nextcloud.1.eu',
'dbname' => 'nextcloud',
'dbhost' => 'local:3306',
'dbuser' => 'nextcloud',
'dbpassword' => '-',
'allow_local_remote_servers' => true,
'mail_domain' => '1.eu',
'mail_from_address' => '-',
'mail_smtpmode' => 'smtp',
'mail_smtpsecure' => 'ssl',
'mail_smtphost' => '-',
'mail_smtpauth' => 1,
'mail_smtpport' => '465',
'mail_smtppassword' => '-',
'mail_smtpname' => '-',
'has_rebuilt_cache' => true,
'theme' => '',
'default_language' => 'de',
'preview_max_memory' => 1024,
'twofactor_enforced' => 'true',
0 => 'No2FA',
'app_install_overwrite' =>
0 => 'twofactor_admin',
1 => 'dicomviewer',
'updater.secret' => '-',
[EDIT]
After some digging, I decided to remove 2 apps which were throwing quite some issues, but to me it still seems like there is something going wrong with nextcloud.
