Hello everybody,
iām facing a problem with the recognize app. The app was working well but a few months ago it stopped to do so. When i check the log it tells me:
Failed to generate preview of 1765741 with dimension 1024 with nextcloud preview manager: Undefined constant āOCA\Recognize\Classifiers\IMAGETYPE_AVIFā
There are many more errors like this. I canāt grab the problem, it seems like it is not possible to scan AVIF-files?
I tried to add it in the Nextcloud config into the array
āenabledPreviewProvidersā
like
14 => āOC\Preview\AVIFā,
but it has no effect.
Do you know where this problem is caused? And maybe even a solution?
I would be very thankfull
