Recognize not working with Memories
    • 30.0.4
    • Yunohost
    • nginx/1.22.1
    • replace me
    • 8.2 and 8.3
    • Yes
    • replace me
    • Yunohost / NC apps
    • I dont know
      la
I have installed Memories and Recognize app in order to use the AI tagging features.
Everything in the admin panel pages for Memories and Recognize are green, except for few yellows like geolocation and skipped media file indexin, which seem unimportant.
The only thing from Recognize that has worked is that it has tagged a photo folder with very old pictures, like 10+ years old, with tags like people, cooking, tool, etc. Moving new pictures to that same folder will not get them tagged.
But after over 24 hours, nothing else has been tagged, such as dozens of recent pictrues that clearly have a car in them. Neither has been any “People” been recognized.
I’ve run the manual occ commands. Some of them work (work, as in no errors), suchs as
  • occ recognize:download-models
  • occ recognize:recrawl
Some of them don’t work, such as
  • occ recognize:reset-tags → Connection to LDAP server could not be established
  • occ recognize:classify → In Connection.php line 241: Connection to LDAP server could not be established
I already spent a few hours trying to fix this with ChatGPT with no luck.
  1. run the occ commands
Note: some of the configuration errors are related to when changed the “LDAP / AD username” setting, which made the web UI not work. That is fixed now, but the problem was the same before that.
https://pastebin.com/hBcffisZ
Idk know which log file to paste? There’s so many
https://pastebin.com/SV3sPhVb
List
  • app_api: 4.0.3
  • bruteforcesettings: 3.0.0
  • cloud_federation_api: 1.13.0
  • contacts: 6.1.1
  • dashboard: 7.10.0
  • dav: 1.31.1
  • federatedfilesharing: 1.20.0
  • federation: 1.20.0
  • files: 2.2.0
  • files_downloadlimit: 3.0.0
  • files_external: 1.22.0
  • files_pdfviewer: 3.0.0
  • files_reminders: 1.3.0
  • files_trashbin: 1.20.1
  • files_versions: 1.23.0
  • firstrunwizard: 3.0.0
  • logreader: 3.0.0
  • lookup_server_connector: 1.18.0
  • memories: 7.4.1
  • nextcloud_announcements: 2.0.0
  • notes: 4.11.0
  • notifications: 3.0.0
  • oauth2: 1.18.1
  • password_policy: 2.0.0
  • photos: 3.0.2
  • previewgenerator: 5.7.0
  • privacy: 2.0.0
  • provisioning_api: 1.20.0
  • recognize: 8.2.0
  • related_resources: 1.5.0
  • serverinfo: 2.0.0
  • settings: 1.13.0
  • support: 2.0.0
  • survey_client: 2.0.0
  • systemtags: 1.20.0
  • text: 4.1.0
  • theming: 2.5.0
  • twofactor_backupcodes: 1.19.0
  • user_ldap: 1.21.0
  • viewer: 3.0.0
  • weather_status: 1.10.0
  • webhook_listeners: 1.1.0-dev
  • workflow_ocr: 1.30.1
  • workflowengine: 2.12.0
  • activity: 3.0.0 (installed 2.21.1)
  • admin_audit: 1.20.0
  • circles: 30.0.0 (installed 29.0.0-dev)
  • comments: 1.20.1 (installed 1.19.0)
  • contactsinteraction: 1.11.0 (installed 1.10.0)
  • encryption: 2.18.0
  • files_sharing: 1.22.0 (installed 1.22.0)
  • recommendations: 3.0.0 (installed 2.1.0)
  • sharebymail: 1.20.0 (installed 1.19.0)
  • suspicious_login: 8.0.0
  • twofactor_nextcloud_notification: 4.0.0
  • twofactor_totp: 12.0.0-dev
  • updatenotification: 1.20.0 (installed 1.19.1)
  • user_status: 1.10.0 (installed 1.9.0)
This seems unrelated to recognize or memories. Your LDAP config seems to be broken, or your LDAP server is down.
Okay, but it’s still required for them to work? I don’t know how to fix it and everything I can find on google don’t seem to re related to my problem
It seems that the issue is not with the LDAP thing, because some new photos have been correctly tagged. These are photos taken with a phone and automatically uploaded to Nextcloud.
So it is partly working, but not tagging everything, even when the object is obvious, and it still has not regocnized any people.
Any ideas how to diagnose this further?
Yes, for recognize to work your nextcloud needs to work. A broken LDAP config is a pretty basic thing to be broken in a Nextcloud instance, a lot depends on the User backend.
I haven’t seen any configuration requirements for LDAP when installing Nextcloud, Memories or Recognize. What tutorial should I follow to get that fixed?
And why would tagging work for some photos but not others, if LDAP config was the issue? You’d think it either works or it doesn’t work.
Everything else in Nextcloud works as far as I have experienced (file uploads, syncing between devices etc).
I don’t know the answers to these questions, sadly. I’m not an LDAP expert. Recognize doesn’t depend on LDAP, but if you get an LDAP error, I’d say you need LDAP help, not recognize help.
I have the same issue
Which features do not work for you? Did you use Memories before and now added Recognize, or start using both at the same time?
Not that I’d know how to help. For me tagging new photos seems to work, but it just didnt most of my old photos, just some. And recognizing people doesn’t work at all.
