RAW thumbnails/previews missing on hosted Nextcloud (Aruba Drive Advanced)
Hi everyone,
I’m a home user on a hosted Nextcloud provided by Aruba (Aruba Drive Advanced service). On the web UI I can’t see thumbnails or lightbox previews for RAW files (NEF/ARW/CR3/DNG). Files appear in the list, but clicking them triggers a download instead of an inline preview.
Context:
  • Service: Aruba Drive Advanced (managed Nextcloud – I don’t have admin access)
  • Desktop: Nextcloud Desktop on Windows 11
  • on Windows 11, with ā€œVirtual Filesā€ enabled, File Explorer shows no thumbnails for RAW placeholders. If I mark files ā€œAvailable offlineā€ and install Microsoft’s Raw Image Extension, thumbnails appear locally – so this part is expected on Windows.
  • just as comparison, on OneDrive I do get online RAW thumbnails (both on web UI and on File Explorer, but I realize that’s a different stack.
Aruba doesn’t enable it by its side.
Thanks!
Hello @Paolo85,
welcome to the Nextcloud community! :handshake:
this is your answer. if hosting provider doesn’t enable the feature you desire there is no way to overcome it.
Hello @wwe,
thank you very much both for your kind and quick reply, and for clarifying it for me :slight_smile:
Best regards,
Paolo
