I installed Rainloop as my webmail client, at: /var/www/html/rainloop
I subsequently installed Nextcloud.
I am now interested in adding the Rainloop app via Nextcloud, but am wondering:
- Is there any value to integrating Rainloop with Nextcloud; and if I do
- Where does Nextcloud install Rainloop - and will it break/cause conflicts with the existing installation?
Thanks very much for any pointers.
