Hi all, I have nextcloud 11.0.3 wih LDAP app configured and working.
I read the documentation about removing domain users from nextcloud.
I whish to summurize the parameters involved in user cleanup.
LDAP cache time to live
In this example, after 10 minuts (600 seconds), nextcloud will sync LDAP.
Considering in your AD you have the group ‘cloudusers’ and you removed ‘test1’ from it.
Now test1 can’t login anymore.
CRON
Even if you set 600 second in the ldap, you probably have to wait till cron gest’ triggered.
In such screenshot, it’s set to 15 minutes.
At this point, user test1 shoud be marked as deleted.
It’s file and database entries has not been deleted yet.
ldapUserCleanupInterval
In config.php you have to set the interval for the cleanup, i.e. ‘ldapUserCleanupInterval’ => ‘30’,
So I wonder if cron.php has to be triggered 3 times:
I answer my self abouth the right syntax.
From ./core/doc/admin/_sources/configuration_server/config_sample_php_parameters.txt
'ldapUserCleanupInterval' => 51,
defines the interval in minutes for the background job that checks user
existence and marks them as ready to be cleaned up. The number is always
minutes. Setting it to 0 disables the feature.
See command line (occ) methods ldap:show-remnants and user:delete
* defines the interval in minutes for the background job that checks user
* existence and marks them as ready to be cleaned up. The number is always
* minutes. Setting it to 0 disables the feature.
* See command line (occ) methods ``ldap:show-remnants`` and ``user:delete``
