Question about "Domaincheck container is not running"
    • Nextcloud AIO v11.7.0
    • Debian 12
    • replace me
    • nginxv2.12.6
    • replace me
    • yes
    • From first installation
    • AIOdocker on OpenMediaVault
    • no
After login with passphrase i get this:
This is not expected. Most likely this happened because port 11000 is already in use on your server. You can check the mastercontainer logs and domaincheck container logs for further clues. You should be able to resolve this by adjusting the APACHE_PORT by following the reverse proxy documentation. Advice: have a detailed look at the changed docker run command for AIO.
This is yml for container:
services:
image: ghcr.io/nextcloud-releases/all-in-one:latest
init: true
restart: always
volumes:
  • nextcloud_aio_mastercontainer:/mnt/docker-aio-config
  • /var/run/docker.sock:/var/run/docker.sock:ro
    ports:
  • 8080:8080
    environment:
  • APACHE_PORT=11000
  • APACHE_IP_BINDING=127.0.0.1
  • NEXTCLOUD_DATADIR=/srv/dev-disk-by-uxxxx-0b673f98fdd4/data/nextcloud
  • NEXTCLOUD_MOUNT=/srv/dev-disk-by-xxxx-0b673f98fdd4/data/media/
    #- TALK_PORT=3679
    volumes:
Tried with adding dns:
cat /etc/docker/daemon.json
“data-root”: “/srv/dev-disk-by-xxx/docker”
“dns”: [“8.8.8.8”, “1.1.1.1”]
TEsting:
nano /etc/docker/daemon.json
root@xxx:~# systemctl restart docker
root@xxx:~# docker info | grep DNS
root@xxx:~# docker run --rm busybox nslookup ghcr.io
Unable to find image ‘busybox:latest’ locally
latest: Pulling from library/busybox
80bfbb8a41a2: Pull complete
Digest: sha2xxxxx
Status: Downloaded newer image for busybox:latest
Server: 8.8.8.8
Address: 8.8.8.8:53
Non-authoritative answer:
Address: 140.82.121.33
Its my first time to deal with NextCloud
As I understand, for nextcloud-aio-mastercontainer with reverse proxy i do not need this “nextcloud-aio-domaincheck“, and i dont have it as image in yml, but it keeps trying to create:
dont know why im getting error “URL error 6: Could not resolve host: ghcr.io“ if I can ping it:
root@xxx:~# docker exec -it nextcloud-aio-mastercontainer /bin/bash
fd031dssad6xxb8:/var/www/docker-aio# ping ghcr.io
PING ghcr.io (140.82.121.34): 56 data bytes
64 bytes from 140.82.121.34: seq=0 ttl=51 time=45.202 ms
64 bytes from 140.82.121.34: seq=1 ttl=51 time=47.031 ms
64 bytes from 140.82.121.34: seq=2 ttl=51 time=47.043 ms
  1. Installed ngingx and configured like in
    all-in-one/reverse-proxy.md at main · nextcloud/all-in-one
  2. Installing container nextcloud-aio-mastercontainer
  3. after login with passphrase i get that Domaincheck container is not running
Initial startup of Nextcloud All-in-One complete!
You should be able to open the Nextcloud AIO Interface now on port 8080 of this server!
E.g. https://internal.ip.of.this.server:8080
⚠️ Important: do always use an ip-address if you access this port and not a domain as HSTS might block access to it later!
If your server has port 80 and 8443 open and you point a domain to your server, you can get a valid certificate automatically by opening the Nextcloud AIO Interface via:
https://your-domain-that-points-to-this-server.tld:8443
/usr/lib/python3.12/site-packages/supervisor/options.py:13: UserWarning: pkg_resources is deprecated as an API. See https://setuptools.pypa.io/en/latest/pkg_resources.html. The pkg_resources package is slated for removal as early as 2025-11-30. Refrain from using this package or pin to Setuptools<81.
  import pkg_resources
[Sat Sep 13 21:48:43.631198 2025] [mpm_event:notice] [pid 173:tid 173] AH00489: Apache/2.4.65 (Unix) OpenSSL/3.5.2 configured -- resuming normal operations
[Sat Sep 13 21:48:43.631238 2025] [core:notice] [pid 173:tid 173] AH00094: Command line: 'httpd -D FOREGROUND'
{"level":"info","ts":1757800123.6388743,"msg":"maxprocs: Leaving GOMAXPROCS=8: CPU quota undefined"}
{"level":"info","ts":1757800123.639134,"msg":"GOMEMLIMIT is updated","package":"github.com/KimMachineGun/automemlimit/memlimit","GOMEMLIMIT":29622734438,"previous":9223372036854775807}
{"level":"info","ts":1757800123.63919,"msg":"using config from file","file":"/Caddyfile"}
{"level":"info","ts":1757800123.640178,"msg":"adapted config to JSON","adapter":"caddyfile"}
[13-Sep-2025 21:48:43] NOTICE: fpm is running, pid 179
[13-Sep-2025 21:48:43] NOTICE: ready to handle connections
{"level":"info","ts":1757800123.6409214,"msg":"maxprocs: No GOMAXPROCS change to reset"}
Error: loading initial config: loading new config: starting caddy administration endpoint: listen tcp: lookup localhost on [::1]:53: read udp [::1]:44425->[::1]:53: read: connection refused
{"level":"info","ts":1757800124.6815026,"msg":"maxprocs: Leaving GOMAXPROCS=8: CPU quota undefined"}
{"level":"info","ts":1757800124.6816704,"msg":"GOMEMLIMIT is updated","package":"github.com/KimMachineGun/automemlimit/memlimit","GOMEMLIMIT":29622734438,"previous":9223372036854775807}
{"level":"info","ts":1757800124.681696,"msg":"using config from file","file":"/Caddyfile"}
{"level":"info","ts":1757800124.6825526,"msg":"adapted config to JSON","adapter":"caddyfile"}
{"level":"info","ts":1757800124.6834552,"msg":"maxprocs: No GOMAXPROCS change to reset"}
Error: loading initial config: loading new config: starting caddy administration endpoint: listen tcp: lookup localhost on [::1]:53: read udp [::1]:33531->[::1]:53: read: connection refused
{"level":"info","ts":1757800126.7247262,"msg":"maxprocs: Leaving GOMAXPROCS=8: CPU quota undefined"}
{"level":"info","ts":1757800126.7249002,"msg":"GOMEMLIMIT is updated","package":"github.com/KimMachineGun/automemlimit/memlimit","GOMEMLIMIT":29622734438,"previous":9223372036854775807}
{"level":"info","ts":1757800126.7249296,"msg":"using config from file","file":"/Caddyfile"}
{"level":"info","ts":1757800126.7257826,"msg":"adapted config to JSON","adapter":"caddyfile"}
{"level":"info","ts":1757800126.7265444,"msg":"maxprocs: No GOMAXPROCS change to reset"}
Error: loading initial config: loading new config: starting caddy administration endpoint: listen tcp: lookup localhost on [::1]:53: read udp [::1]:36130->[::1]:53: read: connection refused
{"level":"info","ts":1757800129.7696204,"msg":"maxprocs: Leaving GOMAXPROCS=8: CPU quota undefined"}
{"level":"info","ts":1757800129.769811,"msg":"GOMEMLIMIT is updated","package":"github.com/KimMachineGun/automemlimit/memlimit","GOMEMLIMIT":29622734438,"previous":9223372036854775807}
{"level":"info","ts":1757800129.7698388,"msg":"using config from file","file":"/Caddyfile"}
{"level":"info","ts":1757800129.7707255,"msg":"adapted config to JSON","adapter":"caddyfile"}
{"level":"info","ts":1757800129.7715194,"msg":"maxprocs: No GOMAXPROCS change to reset"}
Error: loading initial config: loading new config: starting caddy administration endpoint: listen tcp: lookup localhost on [::1]:53: read udp [::1]:33914->[::1]:53: read: connection refused
NOTICE: PHP message: Could not get digest of container nextcloud-releases/aio-domaincheck:latest cURL error 6: Could not resolve host: ghcr.io (see https://curl.haxx.se/libcurl/c/libcurl-errors.html) for https://ghcr.io/token?scope=repository:nextcloud-releases/aio-domaincheck:pull
NOTICE: PHP message: Not pulling the ghcr.io/nextcloud-releases/aio-domaincheck image for the nextcloud-aio-domaincheck container because the registry does not seem to be reachable.
NOTICE: PHP message: Could not start domaincheck container: Could not create container nextcloud-aio-domaincheck: {"message":"No such image: ghcr.io/nextcloud-releases/aio-domaincheck:latest"}
NOTICE: PHP message: Could not get digest of container nextcloud-releases/all-in-one:latest cURL error 6: Could not resolve host: ghcr.io (see https://curl.haxx.se/libcurl/c/libcurl-errors.html) for https://ghcr.io/token?scope=repository:nextcloud-releases/all-in-one:pull
PASTE
PASTE HEREapp-1  | [9/13/2025] [9:03:53 PM] [SSL      ] › ℹ  info      Renewing SSL certs expiring within 30 days ...
app-1  | [9/13/2025] [9:03:53 PM] [SSL      ] › ℹ  info      Completed SSL cert renew process
app-1  | [9/13/2025] [9:11:40 PM] [Global   ] › ℹ  info      PID 183 received SIGTERM
app-1  | [9/13/2025] [9:11:40 PM] [Global   ] › ℹ  info      Stopping.
app-1  | e[1;34m❯ e[1;36mConfiguring npm user ...e[0m
app-1  | 0
app-1  | usermod: no changes
app-1  | e[1;34m❯ e[1;36mConfiguring npm group ...e[0m
app-1  | e[1;34m❯ e[1;36mChecking paths ...e[0m
app-1  | e[1;34m❯ e[1;36mSetting ownership ...e[0m
app-1  | - /data ...
app-1  |     SKIPPED
app-1  | - /etc/letsencrypt ...
app-1  |     SKIPPED
app-1  | - /run/nginx ...
app-1  |     SKIPPED
app-1  | - /tmp/nginx ...
app-1  |     SKIPPED
app-1  | - /var/cache/nginx ...
app-1  |     SKIPPED
app-1  | - /var/lib/logrotate ...
app-1  |     SKIPPED
app-1  | - /var/lib/nginx ...
app-1  |     SKIPPED
app-1  | - /var/log/nginx ...
app-1  |     SKIPPED
app-1  | - /etc/nginx/nginx ...
app-1  |     SKIPPED
app-1  | - /etc/nginx/nginx.conf ...
app-1  |     SKIPPED
app-1  | - /etc/nginx/conf.d ...
app-1  |     SKIPPED
app-1  | e[1;34m❯ e[1;36mChanging ownership of certbot directories, this may take some time ...e[0m
app-1  | - /opt/certbot ...
app-1  |     SKIPPED
app-1  | - /opt/certbot/bin ...
app-1  |     SKIPPED
app-1  | - /opt/certbot/lib/python3.11/site-packages ...
app-1  |     SKIPPED
app-1  | e[1;34m❯ e[1;36mDynamic resolvers ...e[0m
app-1  | e[1;34m❯ e[1;36mIPv6 ...e[0m
app-1  | Enabling IPV6 in hosts in: /etc/nginx/conf.d
app-1  | - /etc/nginx/conf.d/default.conf
app-1  | - /etc/nginx/conf.d/include/block-exploits.conf
app-1  | - /etc/nginx/conf.d/include/assets.conf
app-1  | - /etc/nginx/conf.d/include/proxy.conf
app-1  | - /etc/nginx/conf.d/include/force-ssl.conf
app-1  | - /etc/nginx/conf.d/include/ssl-ciphers.conf
app-1  | - /etc/nginx/conf.d/include/letsencrypt-acme-challenge.conf
app-1  | - /etc/nginx/conf.d/include/log.conf
app-1  | - /etc/nginx/conf.d/include/ssl-cache.conf
app-1  | - /etc/nginx/conf.d/include/ssl-cache-stream.conf
app-1  | - /etc/nginx/conf.d/include/ip_ranges.conf
app-1  | - /etc/nginx/conf.d/include/resolvers.conf
app-1  | - /etc/nginx/conf.d/production.conf
app-1  | Enabling IPV6 in hosts in: /data/nginx
app-1  | - /data/nginx/proxy_host/2.conf
app-1  | e[1;34m❯ e[1;36mDocker secrets ...e[0m
app-1  |
app-1  | -------------------------------------
app-1  |  _   _ ____  __  __
app-1  | | \ | |  _ \|  \/  |
app-1  | |  \| | |_) | |\/| |
app-1  | | |\  |  __/| |  | |
app-1  | |_| \_|_|   |_|  |_|
app-1  | User:  npm PUID:0 ID:0 GROUP:0
app-1  | Group: npm PGID:0 ID:0
app-1  |
app-1  | e[1;34m❯ e[1;36mStarting nginx ...e[0m
app-1  | e[1;34m❯ e[1;36mStarting backend ...e[0m
app-1  | [9/13/2025] [9:11:47 PM] [Global   ] › ℹ  info      Using MySQL configuration
app-1  | [9/13/2025] [9:11:48 PM] [Migrate  ] › ℹ  info      Current database version: 20240427161436
app-1  | [9/13/2025] [9:11:48 PM] [Setup    ] › ℹ  info      Logrotate Timer initialized
app-1  | [9/13/2025] [9:11:48 PM] [Global   ] › ⬤  debug     CMD: logrotate /etc/logrotate.d/nginx-proxy-manager
app-1  | [9/13/2025] [9:11:48 PM] [Setup    ] › ℹ  info      Logrotate completed.
app-1  | [9/13/2025] [9:11:48 PM] [Global   ] › ℹ  info      IP Ranges fetch is enabled
app-1  | [9/13/2025] [9:11:48 PM] [IP Ranges] › ℹ  info      Fetching IP Ranges from online services...
app-1  | [9/13/2025] [9:11:48 PM] [IP Ranges] › ℹ  info      Fetching https://ip-ranges.amazonaws.com/ip-ranges.json
app-1  | [9/13/2025] [9:11:48 PM] [IP Ranges] › ℹ  info      Fetching https://www.cloudflare.com/ips-v4
app-1  | [9/13/2025] [9:11:48 PM] [IP Ranges] › ℹ  info      Fetching https://www.cloudflare.com/ips-v6
app-1  | [9/13/2025] [9:11:48 PM] [SSL      ] › ℹ  info      Let's Encrypt Renewal Timer initialized
app-1  | [9/13/2025] [9:11:48 PM] [SSL      ] › ℹ  info      Renewing SSL certs expiring within 30 days ...
app-1  | [9/13/2025] [9:11:48 PM] [IP Ranges] › ℹ  info      IP Ranges Renewal Timer initialized
app-1  | [9/13/2025] [9:11:48 PM] [Global   ] › ℹ  info      Backend PID 175 listening on port 3000 ...
app-1  | [9/13/2025] [9:11:48 PM] [SSL      ] › ℹ  info      Completed SSL cert renew process
app-1  | [9/13/2025] [9:47:56 PM] [Global   ] › ⬤  debug     CMD: /usr/sbin/nginx -t -g "error_log off;"
app-1  | [9/13/2025] [9:47:56 PM] [Nginx    ] › ⬤  debug     Deleting file: /data/nginx/proxy_host/2.conf
app-1  | [9/13/2025] [9:47:56 PM] [Nginx    ] › ℹ  info      Reloading Nginx
app-1  | [9/13/2025] [9:47:56 PM] [Global   ] › ⬤  debug     CMD: /usr/sbin/nginx -s reload
PASTE HERE
Your logs suggest the mastercontainer only has IPv6 connectivity (and it’s not working in your Docker environment). I suspect that’s related.
That was from the log of the nginx. But nginx is running and i can access it on browser.I checked that link and “docker network inspect nextcloud-aio | grep EnableIPv6“ returned false.I guess i dont need the IPv6, right?
But i tried that, changed to enable trueAnd after first login to AIO i get some strange logs, but after second try it was the same as beforelog after first login:
NOTICE: PHP message: 404 Not FoundType: Slim\Exception\HttpNotFoundExceptionCode: 404Message: Not found.File: /var/www/docker-aio/php/vendor/slim/slim/Slim/Middleware/RoutingMiddleware.phpLine: 76Trace: #0 /var/www/docker-aio/php/vendor/slim/slim/Slim/Routing/RouteRunner.php(62): Slim\Middleware\RoutingMiddleware->performRouting(Object(GuzzleHttp\Psr7\ServerRequest))#1 /var/www/docker-aio/php/vendor/slim/csrf/src/Guard.php(482): Slim\Routing\RouteRunner->handle(Object(GuzzleHttp\Psr7\ServerRequest))#2 /var/www/docker-aio/php/vendor/slim/slim/Slim/MiddlewareDispatcher.php(178): Slim\Csrf\Guard->process(Object(GuzzleHttp\Psr7\ServerRequest), Object(Slim\Routing\RouteRunner))#3 /var/www/docker-aio/php/vendor/slim/twig-view/src/TwigMiddleware.php(117): Psr\Http\Server\RequestHandlerInterface@anonymous->handle(Object(GuzzleHttp\Psr7\ServerRequest))#4 /var/www/docker-aio/php/vendor/slim/slim/Slim/MiddlewareDispatcher.php(129): Slim\Views\TwigMiddleware->process(Object(GuzzleHttp\Psr7\ServerRequest), Object(Psr\Http\Server\RequestHandlerInterface@anonymous))#5 /var/www/docker-aio/php/src/Middleware/AuthMiddleware.php(36): Psr\Http\Server\RequestHandlerInterface@anonymous->handle(Object(GuzzleHttp\Psr7\ServerRequest))#6 /var/www/docker-aio/php/vendor/slim/slim/Slim/MiddlewareDispatcher.php(283): AIO\Middleware\AuthMiddleware->__invoke(Object(GuzzleHttp\Psr7\ServerRequest), Object(Psr\Http\Server\RequestHandlerInterface@anonymous))#7 /var/www/docker-aio/php/vendor/slim/slim/Slim/Middleware/ErrorMiddleware.php(77): Psr\Http\Server\RequestHandlerInterface@anonymous->handle(Object(GuzzleHttp\Psr7\ServerRequest))#8 /var/www/docker-aio/php/vendor/slim/slim/Slim/MiddlewareDispatcher.php(129): Slim\Middleware\ErrorMiddleware->process(Object(GuzzleHttp\Psr7\ServerRequest), Object(Psr\Http\Server\RequestHandlerInterface@anonymous))#9 /var/www/docker-aio/php/vendor/slim/slim/Slim/MiddlewareDispatcher.php(73): Psr\Http\Server\RequestHandlerInterface@anonymous->handle(Object(GuzzleHttp\Psr7\ServerRequest))#10 /var/www/docker-aio/php/vendor/slim/slim/Slim/App.php(209): Slim\MiddlewareDispatcher->handle(Object(GuzzleHttp\Psr7\ServerRequest))#11 /var/www/docker-aio/php/vendor/slim/slim/Slim/App.php(193): Slim\App->handle(Object(GuzzleHttp\Psr7\ServerRequest))#12 /var/www/docker-aio/php/public/index.php(198): Slim\App->run()#13 {main}Tips: To display error details in HTTP response set “displayErrorDetails” to true in the ErrorHandler constructor.NOTICE: PHP message: 405 Method Not AllowedType: Slim\Exception\HttpMethodNotAllowedExceptionCode: 405Message: Method not allowed. Must be one of: POSTFile: /var/www/docker-aio/php/vendor/slim/slim/Slim/Middleware/RoutingMiddleware.phpLine: 79Trace: #0 /var/www/docker-aio/php/vendor/slim/slim/Slim/Routing/RouteRunner.php(62): Slim\Middleware\RoutingMiddleware->performRouting(Object(GuzzleHttp\Psr7\ServerRequest))#1 /var/www/docker-aio/php/vendor/slim/csrf/src/Guard.php(482): Slim\Routing\RouteRunner->handle(Object(GuzzleHttp\Psr7\ServerRequest))#2 /var/www/docker-aio/php/vendor/slim/slim/Slim/MiddlewareDispatcher.php(178): Slim\Csrf\Guard->process(Object(GuzzleHttp\Psr7\ServerRequest), Object(Slim\Routing\RouteRunner))#3 /var/www/docker-aio/php/vendor/slim/twig-view/src/TwigMiddleware.php(117): Psr\Http\Server\RequestHandlerInterface@anonymous->handle(Object(GuzzleHttp\Psr7\ServerRequest))#4 /var/www/docker-aio/php/vendor/slim/slim/Slim/MiddlewareDispatcher.php(129): Slim\Views\TwigMiddleware->process(Object(GuzzleHttp\Psr7\ServerRequest), Object(Psr\Http\Server\RequestHandlerInterface@anonymous))#5 /var/www/docker-aio/php/src/Middleware/AuthMiddleware.php(36): Psr\Http\Server\RequestHandlerInterface@anonymous->handle(Object(GuzzleHttp\Psr7\ServerRequest))#6 /var/www/docker-aio/php/vendor/slim/slim/Slim/MiddlewareDispatcher.php(283): AIO\Middleware\AuthMiddleware->__invoke(Object(GuzzleHttp\Psr7\ServerRequest), Object(Psr\Http\Server\RequestHandlerInterface@anonymous))#7 /var/www/docker-aio/php/vendor/slim/slim/Slim/Middleware/ErrorMiddleware.php(77): Psr\Http\Server\RequestHandlerInterface@anonymous->handle(Object(GuzzleHttp\Psr7\ServerRequest))#8 /var/www/docker-aio/php/vendor/slim/slim/Slim/MiddlewareDispatcher.php(129): Slim\Middleware\ErrorMiddleware->process(Object(GuzzleHttp\Psr7\ServerRequest), Object(Psr\Http\Server\RequestHandlerInterface@anonymous))#9 /var/www/docker-aio/php/vendor/slim/slim/Slim/MiddlewareDispatcher.php(73): Psr\Http\Server\RequestHandlerInterface@anonymous->handle(Object(GuzzleHttp\Psr7\ServerRequest))#10 /var/www/docker-aio/php/vendor/slim/slim/Slim/App.php(209): Slim\MiddlewareDispatcher->handle(Object(GuzzleHttp\Psr7\ServerRequest))#11 /var/www/docker-aio/php/vendor/slim/slim/Slim/App.php(193): Slim\App->handle(Object(GuzzleHttp\Psr7\ServerRequest))#12 /var/www/docker-aio/php/public/index.php(198): Slim\App->run()#13 {main}Tips: To display error details in HTTP response set “displayErrorDetails” to true in the ErrorHandler constructor.
And after second login try:
NOTICE: PHP message: Could not get digest of container nextcloud-releases/aio-domaincheck:latest cURL error 6: Could not resolve host: ghcr.io (see  ) for https://ghcr.io/token?scope=repository:nextcloud-releases/aio-domaincheck:pullNOTICE: PHP message: Not pulling the ghcr.io/nextcloud-releases/aio-domaincheck image for the nextcloud-aio-domaincheck container because the registry does not seem to be reachable.NOTICE: PHP message: Could not start domaincheck container: Could not create container nextcloud-aio-domaincheck: {“message”:“No such image: ghcr.io/nextcloud-releases/aio-domaincheck:latest”}NOTICE: PHP message: Could not get digest of container nextcloud/all-in-one:latest cURL error 6: Could not resolve host: auth.docker.io (see  ) for https://auth.docker.io/token?service=registry.docker.io&scope=repository:nextcloud/all-in-one:pull
