Bonjour, je n’arrive pas à connaitre le quota allouer par défaut sur un NextCloud gratuit ?
it’s depending on the way you host it. if you plan to self-host a server from home there’s no limitation to it other than the drive-space you’re attaching to it.
if you plan to get yourself a free account with some internet-hoster you need to refer to their plans to check out the quota. I’ve seen some with up to 8 GB for free.
