example
longer
example
here
Nextcloud version: 23.02
Operating system and version: Ubuntu 18.04.6
Apache or nginx version : Apache 2.4.29
PHP version: 7.4
Calendar version: 3.2.0
Calendar shared via a public link or using the embed code do not display any events.
I have tried different calendars, deleted them and tried a brand new calendar with only 1 event.
The public link loads a blank calendar with the spinning loading wheel in the sidebar.
Is this the first time you’ve seen this error? (Y/N): Yes
- Create a Calendar
- Create a Public Share Link
Nothing relevant in the logs
'instanceid' => 'ocfexsglrzjv',
'passwordsalt' => 'gSoQoaa3AbNWfs0Z8yJl2sWbmdShKD',
'secret' => '9B1G1zD5gYbtbWYY+aMY0xE9iqImbNi9nx0KEMsQzVk4lNTe',
0 => 'URL',
'version' => '23.0.2.1',
'overwrite.cli.url' => 'https://URLHERE,
'dbname' => 'hub_nextcloud',
'dbhost' => 'localhost',
'dbuser' => 'hub_nextcloud',
'dbpassword' => 'PASSWORD',
'default_locale' => 'en_GB',
'default_phone_region' => 'GB',
'twofactor_enforced' => 'false',
'skeletondirectory' => '',
'theme' => '',
'loglevel' => 2,
nothing relevant in the log
