Nextcloud version : 21.0.1
Operating system and version : Debian 10
Apache version : 2.2.34
PHP version (eg, 7.4): 7.3
Forbidden message when I try to upload in local external storage. Witch is a bind mount in an lxc container (previligied) in proxmox. The www-data user and group are the owners of the mounted folder (same uid and gid as the ones on the host). Can write to the folder in cli with the www-data user.
- Mount folder with proxmox on the container
- Add the mounted folder to nextcloud external storage plugin and make the uid and gid of the www-data user match with the ones on the folder.
- Try to upload a file in the folder
No log in particular about this
'instanceid' => 'ocp1doe25f5g',
'passwordsalt' => '',
'secret' => '',
0 => '',
'datadirectory' => '/var/www/nextcloud-data',
'version' => '21.0.1.1',
'overwrite.cli.url' => '',
'dbname' => 'nextcloud',
'dbhost' => 'localhost',
'dbuser' => '',
'dbpassword' => '',
'memcache.local' => '\OC\Memcache\Redis',
'memcache.distributed' => '\OC\Memcache\Redis',
'redis' => [
'port' => 0,
'timeout' => 1.5,
