I am a user (no access to the admin area) of a Nextcloud instance. I did a search and didn’t see mention of my exact problem. So before I try to get help through the hosting site, I wonder if there is anything the community can provide that I can relay to the hosting site admins.
Here is what works no problem:
- I can log into the web page and upload and download files
- I can also use the desktop sync client
- I can mount the WebDAV mount in Windows 10 and see files/directories
- I can use rclone to connect to the WebDAV mount and list files/directories
- I can download files in Windows 10 or using rclone
- I can create directories in Windows 10 or using rclone
- I can delete files in Windows 10 or using rclone
What does not work:
- I cannot upload any files of any size/type using the mounted Windows 10 share
- I cannot upload any files of any size/type using rclone
This problem happens every time - I have never been able to succeed in the steps above.
Since I do not have access to the admin area, this is the only information I have from the failed rclone attempt:
$ rclone -v copy webdav.sh h2:test123/
2018/10/15 13:11:14 ERROR : webdav.sh: Failed to copy: 406 Not Acceptable
2018/10/15 13:11:14 ERROR : Attempt 1/3 failed with 1 errors and: 406 Not Acceptable
2018/10/15 13:11:16 ERROR : webdav.sh: Failed to copy: 406 Not Acceptable
2018/10/15 13:11:16 ERROR : Attempt 2/3 failed with 1 errors and: 406 Not Acceptable
2018/10/15 13:11:17 ERROR : webdav.sh: Failed to copy: 406 Not Acceptable
2018/10/15 13:11:17 ERROR : Attempt 3/3 failed with 1 errors and: 406 Not Acceptable
2018/10/15 13:11:17 Failed to copy: 406 Not Acceptable
Is there some WebDAV setting which may be missing?
Nextcloud version (eg, 12.0.2): 13 something
Operating system and version (eg, Ubuntu 17.04): Unknown
Apache or nginx version (eg, Apache 2.4.25): Unknown
PHP version (eg, 7.1): Unknown
Thanks for any help you can provide.
