Problems with SMB shares
    • 32.0.1
    • Debian 12.10.0
    • Apache/2.4.65
    • Haproxy 2.9
    • 8.2.29
    • After Install (always there)
    • Bare Metal
When adding an External Storage from the webui, it asks for my admin password, wich I type, but it returns as wrong password. It is the right password, it works in other categories.
(I wanna add that this problem is not present on the TrueNas version of NC, but due to network reasons I wanna use a hosted version)
  1. Login to WebGui as an admin
  2. Go to Administration settings > External Storage
  3. Add an SMB/CIFS Storage, fill the infos.
  4. Click the save icon
  5. Enter password
  6. It says wrong password even if the password is right
  "reqId": "KH4zHGNistKsFBhS4MJQ",
  "level": 0,
  "time": "2025-11-05T12:52:14+00:00",
  "remoteAddr": "192.168.0.205",
  "user": "Ynos",
  "app": "files_external",
  "method": "GET",
  "url": "/index.php/apps/logreader/api/log?offset=0&query=",
  "message": "The loading of lazy AppConfig values have been triggered by app \"files_external\"",
  "userAgent": "Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:140.0) Gecko/20100101 Firefox/140.0",
  "version": "32.0.1.2",
  "exception": {
    "Exception": "RuntimeException",
    "Message": "The loading of lazy AppConfig values have been triggered by app \"files_external\"",
    "Code": 0,
    "Trace": [
        "file": "/var/www/nextcloud/lib/private/AppConfig.php",
        "line": 492,
        "function": "loadConfig",
        "class": "OC\\AppConfig",
        "type": "->"
        "line": 427,
        "function": "getTypedValue",
        "type": "->"
        "file": "/var/www/nextcloud/apps/files_external/lib/Service/BackendService.php",
        "line": 65,
        "function": "getValueBool",
        "type": "->"
        "function": "__construct",
        "class": "OCA\\Files_External\\Service\\BackendService",
        "type": "->"
        "file": "/var/www/nextcloud/lib/private/AppFramework/Utility/SimpleContainer.php",
        "line": 72,
        "function": "newInstanceArgs",
        "class": "ReflectionClass",
        "type": "->"
        "line": 122,
        "function": "buildClass",
        "class": "OC\\AppFramework\\Utility\\SimpleContainer",
        "type": "->"
        "line": 140,
        "function": "resolve",
        "type": "->"
        "file": "/var/www/nextcloud/lib/private/AppFramework/DependencyInjection/DIContainer.php",
        "line": 352,
        "function": "query",
        "type": "->"
        "line": 324,
        "function": "queryNoFallback",
        "class": "OC\\AppFramework\\DependencyInjection\\DIContainer",
        "type": "->"
        "line": 90,
        "type": "->"
        "function": "OC\\AppFramework\\Utility\\{closure}",
        "type": "->",
        "args": [
          "*** sensitive parameters replaced ***"
        "line": 77,
        "function": "array_map"
        "line": 72,
        "function": "buildClassConstructorParameters",
        "type": "->"
        "line": 122,
        "type": "->"
        "line": 140,
        "type": "->"
        "line": 352,
        "type": "->"
        "line": 324,
        "type": "->"
        "line": 90,
        "type": "->"
        "type": "->",
        "args": [
        "line": 77,
        "line": 72,
        "type": "->"
        "line": 122,
        "type": "->"
        "line": 140,
        "type": "->"
        "line": 352,
        "type": "->"
        "line": 324,
        "type": "->"
        "line": 45,
        "type": "->"
        "file": "/var/www/nextcloud/lib/private/AppFramework/Bootstrap/FunctionInjector.php",
        "line": 32,
        "function": "get",
        "type": "->"
        "function": "OC\\AppFramework\\Bootstrap\\{closure}",
        "class": "OC\\AppFramework\\Bootstrap\\FunctionInjector",
        "type": "->",
        "args": [
        "line": 28,
        "file": "/var/www/nextcloud/lib/private/AppFramework/Bootstrap/BootContext.php",
        "line": 32,
        "function": "injectFn",
        "type": "->"
        "file": "/var/www/nextcloud/apps/files_external/lib/AppInfo/Application.php",
        "line": 79,
        "class": "OC\\AppFramework\\Bootstrap\\BootContext",
        "type": "->"
        "file": "/var/www/nextcloud/lib/private/AppFramework/Bootstrap/Coordinator.php",
        "line": 170,
        "function": "boot",
        "class": "OCA\\Files_External\\AppInfo\\Application",
        "type": "->"
        "file": "/var/www/nextcloud/lib/private/App/AppManager.php",
        "line": 481,
        "function": "bootApp",
        "class": "OC\\AppFramework\\Bootstrap\\Coordinator",
        "type": "->"
        "line": 273,
        "function": "loadApp",
        "class": "OC\\App\\AppManager",
        "type": "->"
        "file": "/var/www/nextcloud/lib/base.php",
        "line": 1021,
        "function": "loadApps",
        "type": "->"
        "file": "/var/www/nextcloud/index.php",
        "line": 25,
        "function": "handleRequest",
        "class": "OC",
        "type": "::"
    "File": "/var/www/nextcloud/lib/private/AppConfig.php",
    "Line": 1326,
    "exception": [],
    "CustomMessage": "The loading of lazy AppConfig values have been triggered by app \"files_external\""
  "id": "690b487eeef86"
POST
scheme
	http
host
	192.168.0.208
filename
	/index.php/apps/files_external/globalstorages
Address
	192.168.0.208:80
Status
422
Unprocessable Entity
VersionHTTP/1.1
Transferred851 B (45 B size)
Referrer Policyno-referrer
Request PriorityHighest
DNS ResolutionSystem
Cache-Control
	no-cache, no-store, must-revalidate
Connection
	Keep-Alive
Content-Length
	45
Content-Security-Policy
	default-src 'none';base-uri 'none';manifest-src 'self';frame-ancestors 'none'
Content-Type
	application/json; charset=utf-8
Date
	Wed, 05 Nov 2025 12:53:48 GMT
Feature-Policy
	autoplay 'none';camera 'none';fullscreen 'none';geolocation 'none';microphone 'none';payment 'none'
Keep-Alive
	timeout=5, max=100
Referrer-Policy
	no-referrer
Server
	Apache/2.4.65 (Debian)
Set-Cookie
	ocxw5ym4x11k=m1pa880pgle9ir3ptq7nbtcpf6; path=/; HttpOnly; SameSite=Lax
X-Content-Type-Options
	nosniff
X-Frame-Options
	SAMEORIGIN
X-Permitted-Cross-Domain-Policies
	none
X-Request-Id
	sXIn3GgE8nNfxq7cjJn2
X-Robots-Tag
	noindex, nofollow
X-User-Id
	Ynos
Accept
	application/json, text/plain, */*
Accept-Encoding
	gzip, deflate
Accept-Language
	en-US,en;q=0.5
Authorization
	Basic WW5vczpib25uaWVvbGQxMjM=
Connection
	keep-alive
Content-Length
	472
Content-Type
	application/json
Cookie
	ocxw5ym4x11k=m1pa880pgle9ir3ptq7nbtcpf6; oc_sessionPassphrase=xzPqxTOf4q1O4KAt7DV%2BJ%2FYfvkP9Emp9KFO4ZFcf8HW%2B%2B98tJssXFOnYjVU1PDlv6SB4uxXHiDGewYvahhvglBDGTHMPTgZd2Q6Pvjx1URkApphzTZykgidUGMue6Wvj; nc_sameSiteCookielax=true; nc_sameSiteCookiestrict=true; nc_username=Ynos; nc_token=k6SfS3gMS9zwkKPLNKQH6Vpf1DZKnPM7; nc_session_id=m1pa880pgle9ir3ptq7nbtcpf6
Host
	192.168.0.208
Idempotency-Key
	"10947362443535643115"
Origin
	http://192.168.0.208
Priority
	u=0
requesttoken
	SyhldycBJNBQNeyKgeX9dHW+Le5SY6UlN+DZcArsZLs=:YE8BHmhsTrogAbXj99ObJz7nfpg/IfZzYZeWJl3fIvI=
Sec-GPC
	1
User-Agent
X-Requested-With
	XMLHttpRequest, XMLHttpRequest
Not using reverse proxy yet
sudo -u www-data php occ config:list system
            "192.168.0.X"
        "dbtype": "mysql",
        "overwrite.cli.url": "http:\/\/192.168.0.X",
        "mysql.utf8mb4": true,
            "password_confirmation_required": false
        "loglevel": "0"
sudo -u www-data php occ app:list
  • app_api: 32.0.0
  • circles: 32.0.0
  • comments: 1.22.0
  • contactsinteraction: 1.13.1
  • dav: 1.34.2
  • federation: 1.22.0
  • files: 2.4.0
  • files_external: 1.24.0
  • files_reminders: 1.5.0
  • files_sharing: 1.24.0
  • files_trashbin: 1.22.0
  • files_versions: 1.25.0
  • firstrunwizard: 5.0.0-dev.0
  • logreader: 5.0.0-dev.0
  • notes: 4.12.3
  • notifications: 5.0.0-dev.0
  • oauth2: 1.20.0
  • privacy: 4.0.0-dev.0
  • profile: 1.1.0
  • provisioning_api: 1.22.0
  • richdocuments: 9.0.1
  • richdocumentscode: 25.4.504
  • serverinfo: 4.0.0-dev.0
  • settings: 1.15.1
  • sharebymail: 1.22.0
  • support: 4.0.0-dev.0
  • survey_client: 4.0.0-dev.0
  • systemtags: 1.22.0
  • text: 6.0.1
  • theming: 2.7.0
  • updatenotification: 1.22.0
  • user_status: 1.12.0
  • viewer: 5.0.0-dev.0
  • weather_status: 1.12.0
  • webhook_listeners: 1.3.0
  • workflowengine: 2.14.0
  • activity: 5.0.0-dev.0 (installed 5.0.0-dev.0)
  • admin_audit: 1.22.0
  • dashboard: 7.12.0 (installed 7.12.0)
  • encryption: 2.20.0
  • photos: 5.0.0-dev.1 (installed 5.0.0-dev.1)
  • twofactor_totp: 14.0.0
  • user_ldap: 1.23.0
I hit the problem short time ago and tracked down to a bug
my solution was to revert to 30.0.10 last version before the problem was introduced. Once I created the external storage it was possible to update to last version.
a workaround could be to add external storage using occ, I think it works in all versions
# configure SMB shares
occ files_external:create "name of the share" smb password::sessioncredentials -c host=smbserver.internal -c share=smbRootPath -c domain=ADDomain
I’m using session credencials from LDAP login in this case - adjust for your system is needed
I see, would the process only be to extract the old version in /car/www/nextcloud
Then access it after restarting apache2, recreate the shares
Replace the /var/www/nextcloud by a nextcloud 32 and restart again ?
Following this logic, i guess i can also put the nextcloud files in the html folder so it is easier with certificates ?
Thanks for tour time !
downgrading an installation is not supported. in my case it was a new install so started over from scratch. thank docker it’s just matter of minutes to rewind another installation.
look at official server docs to learn everything you need.
I figured the hard way :confused: after downgrading no problem, I did it two times cause the version you provided did not fixed my issue, i went further back.
I updated 2 majors versions in one go wich corrupted everything :sweat_smile:
I am slowly restarting, at the moment, i mounted the shares and updated to 31, now i need to update to 32, hopefully it will work.
So i did everything, from v30, mounted the shares, updated to 31, it was working. Updated to 32, all went good, working as well but with minor errors from the app api, tried to repair it but nothing worked. Now my shares are broken on the nextcloud server, I am giving up on the debian based version cause it seems to be far too broken since the v30. Going back to the truenas version cause it seems usable, gonna work around for the certs.
Problem is still present in version Nextcloud Hub 25 Autumn (32.0.2). Is there any plans to solve this issue on upcoming updates?
