Nextcloud version (eg, 18.0.2): 18.0.4
Operating system and version (eg, Ubuntu 20.04): Centos 7.7
Apache or nginx version (eg, Apache 2.4.25): Apache 2.4.6
PHP version (eg, 7.1): 7.2
We‘re using Nextcloud in our school with LDAP for the users and classes. When sharing to an LDAP group most pupils can see and access the share.
But in some accounts, the share doesn‘t appear! When I look under „activities“, there is an entry „TeacherXY has shared folder with you“, but when I click on this activity, there is an error.
Sometimes not even an entry appears in „activities“!
When I look as admin in the userlist, the pupils are listed correctly in the LDAP-class-group! In the database, there is also an correct entry for the share.
The only solution for now I found is, that I add a personal share for the folder for the pupil where the group-sharing doesn‘t work for.
We have ~1000 pupils in our school and facing this issue with 13 pupils for now! for all other pupils it works as expected.
When I create a local group in nextcloud and add such a „faulty pupil“, sharing to this local group works great!
It‘s only for LDAP-group-sharing with some pupils!
Since last night, there were more pupils with problems. Also such pupils, where no problems has been before! I don‘t know why, because, nothing was changed during last night!
What can I change, that sharing works properly?
Thank you for helping!
don‘t know, there are some accounts with this problem, the most without problems. Don‘t see any common ground.
There are MANY of these errors in log, also for pupils without problems!
Error while creating shared mount
[no app in context] Error: InvalidArgumentException: Invalid recipient at <<closure>>
0. /var/www/html/dhg-rw/nextcloud/apps/files_sharing/lib/SharedMount.php line 129
OC\Share20\Manager->moveShare(OC\Share20\Share {}, "efae3090-54f5-1038-90a2-6f2b389a9008")
1. /var/www/html/dhg-rw/nextcloud/apps/files_sharing/lib/SharedMount.php line 111
OCA\Files_Sharing\SharedMount->updateFileTarget("*** sensitive parameters replaced ***")
2. /var/www/html/dhg-rw/nextcloud/apps/files_sharing/lib/SharedMount.php line 77
OCA\Files_Sharing\SharedMount->verifyMountPoint("*** sensitive parameter replaced ***", {/efae3090-54f5- ... }}, OC\Cache\CappedMemoryCache {})
3. /var/www/html/dhg-rw/nextcloud/apps/files_sharing/lib/MountProvider.php line 125
OCA\Files_Sharing\SharedMount->__construct("\\OCA\\Files_Sharing\\SharedStorage", {/efae3090-54f5- ... }}, {user: "efae3090 ... e}, OC\Files\Storage\StorageFactory {}, OC\Files\View {}, OC\Cache\CappedMemoryCache {})
4. /var/www/html/dhg-rw/nextcloud/lib/private/Files/Config/MountProviderCollection.php line 114
OCA\Files_Sharing\MountProvider->getMountsForUser(OC\User\User {}, OC\Files\Storage\StorageFactory {})
5. /var/www/html/dhg-rw/nextcloud/lib/private/Files/Filesystem.php line 448
OC\Files\Config\MountProviderCollection->addMountForUser(OC\User\User {}, OC\Files\Mount\Manager {})
6. /var/www/html/dhg-rw/nextcloud/lib/private/Files/Filesystem.php line 377
OC\Files\Filesystem::initMountPoints("efae3090-54f5-1038-90a2-6f2b389a9008")
7. /var/www/html/dhg-rw/nextcloud/lib/private/legacy/util.php line 309
OC\Files\Filesystem::init("efae3090-54f5-1038-90a2-6f2b389a9008", "/efae3090-54f5- ... s")
8. /var/www/html/dhg-rw/nextcloud/apps/dav/lib/Connector/Sabre/Auth.php line 242
OC_Util::setupFS("efae3090-54f5-1038-90a2-6f2b389a9008")
9. /var/www/html/dhg-rw/nextcloud/apps/dav/lib/Connector/Sabre/Auth.php line 158
OCA\DAV\Connector\Sabre\Auth->auth(Sabre\HTTP\Reque ... "}, Sabre\HTTP\Response {})
10. /var/www/html/dhg-rw/nextcloud/3rdparty/sabre/dav/lib/DAV/Auth/Plugin.php line 201
OCA\DAV\Connector\Sabre\Auth->check(Sabre\HTTP\Reque ... "}, Sabre\HTTP\Response {})
11. /var/www/html/dhg-rw/nextcloud/3rdparty/sabre/dav/lib/DAV/Auth/Plugin.php line 150
Sabre\DAV\Auth\Plugin->check(Sabre\HTTP\Reque ... "}, Sabre\HTTP\Response {})
12. <<closure>>
Sabre\DAV\Auth\Plugin->beforeMethod(Sabre\HTTP\Reque ... "}, Sabre\HTTP\Response {})
13. /var/www/html/dhg-rw/nextcloud/3rdparty/sabre/event/lib/EventEmitterTrait.php line 105
call_user_func_array([Sabre\DAV\Auth\ ... "], [Sabre\HTTP\Requ ... }])
14. /var/www/html/dhg-rw/nextcloud/3rdparty/sabre/dav/lib/DAV/Server.php line 466
Sabre\Event\EventEmitter->emit("beforeMethod", [Sabre\HTTP\Requ ... }])
15. /var/www/html/dhg-rw/nextcloud/3rdparty/sabre/dav/lib/DAV/Server.php line 254
Sabre\DAV\Server->invokeMethod(Sabre\HTTP\Reque ... "}, Sabre\HTTP\Response {})
16. /var/www/html/dhg-rw/nextcloud/apps/dav/lib/Server.php line 319
Sabre\DAV\Server->exec()
17. /var/www/html/dhg-rw/nextcloud/apps/dav/appinfo/v2/remote.php line 35
OCA\DAV\Server->exec()
18. /var/www/html/dhg-rw/nextcloud/remote.php line 165
require_once("/var/www/html/d ... p")
PROPFIND /remote.php/dav/files/efae3090-54f5-1038-90a2-6f2b389a9008/<filename removed>
from <IP removed> by efae3090-54f5-1038-90a2-6f2b389a9008 at 2020-04-28T08:08:14+00:00
‘dbtype‘ => ‘mysql‘,
‘version‘ => ‘18.0.4.2’,
‘mysql.utf8mb4’ => true,
‘ldapIgnoreNamingRules’ => false,
‘ldapProviderFactory’ => ‘OCA\\User_LDAP\\LDAPProviderFactory’,
‘memcache.distributed’ => ‘\\OC\\Memcache\\Redis’,
no errors!
