I have a few errors that persist even with removing and installing richdocuments:
OC\DB\Exceptions\DbalException: An exception occurred while executing a query: SQLSTATE[42S02]: Base table or view not found: 1146 Table ânextcloud_e645ea39.oc_richdocuments_wopiâ doesnât exist
OC\DB\Exceptions\DbalException: An exception occurred while executing a query: SQLSTATE[42S02]: Base table or view not found: 1146 Table ânextcloud_e645ea39.oc_richdocuments_templateâ doesnât exist
How can I solve those or how can I do a fresh install of richdocuments including database?
Hello, hope someone can help.
the richdocuments app is installing without problems, but I get the error that the following tables are missing:
I actually canât find any oc_richdocuments tables in the database.
Are the oc_richdocuments tables are generated on install or part of nc db?
Can someone please post me the oc_richdocuments tables structure.
please donât double post. I moved you post together.
try to remove and install the app with occ try occ app:removeocc app:install and maybe occ maintenance:repair if this doesnât help use the search and post relevant logs.
@wwe thanks for the reply. I tried all that. My logs:
[richdocuments] Fehler: OC\DB\Exceptions\DbalException: An exception occurred while executing a query: SQLSTATE[42S22]: Column not found: 1054 Unknown column âtemplate_idâ in âfield listâ at <>
[core] Fehler: OC\DB\Exceptions\DbalException: An exception occurred while executing a query: SQLSTATE[42S02]: Base table or view not found: 1146 Table ânextcloud_e645ea39.oc_richdocuments_templateâ doesnât exist at <>
Caused by:
Doctrine\DBAL\Exception\TableNotFoundException: An exception occurred while executing a query: SQLSTATE[42S02]: Base table or view not found: 1146 Table ânextcloud_e645ea39.oc_richdocuments_templateâ doesnât exist at <>
Caused by:
Doctrine\DBAL\Driver\PDO\Exception: SQLSTATE[42S02]: Base table or view not found: 1146 Table ânextcloud_e645ea39.oc_richdocuments_templateâ doesnât exist at <>
Caused by:
PDOException: SQLSTATE[42S02]: Base table or view not found: 1146 Table ânextcloud_e645ea39.oc_richdocuments_templateâ doesnât exist at <>
I removed the traces. Let me know if needed.
Can you tell me if oc_richdocuments tables are generated on install or part of nc db?
