Hello there!
I can’t get rid off the following two security warnings in my admin center:
„X-Content-Type-Options“-HTTP-Header
-> is not “nosniff”
„X-Frame-Options“-HTTP-Header
-> is not “SAMEORIGIN”
I did try to fix it already with the nextcloud guide, but I can’t do it… Maybe it has to do with the guide I followed to install nextcloud? Could anyone be kind and watch into the guide I used and give me a hint why I get those messages?
Guides I used to install nextcloud:
I would be really thankful for some advice, I tried a lot but I can’t fix it…
Kind regards.
