[/details]
I am running Nextcloud installed on TrueNas Scale. It is installed via helm charts from TrueCharts.
Nextcloud version: 27.1.4
Operating system and version: TrueNas Scale (Debian)
Webserver: nginx
I am mounting to the container’s local paths from my host machine. While accessing those paths from the terminal on the pod, there is no issues, the files are easily accessible.
The issue starts using the UI. I have tried:
- chrome
- firefox
- Edge
Browser (and its version) seems not to matter.
While I browse the mounted folders, Nextcloud UI shows me it is empty. Once I refresh the page, it starts to load files. The real problem is that I want to upload something there - the upload randomly fails with “File not found” error.
I admit those folders are quite heavily packed, 2TB total.
- Have a few folders locally on the nextcloud host
- mount those folders inside the nextcloud using Settings > External storage
- Try to browse the files and upload files in bulk
"reqId": "ZVGsrAosr8A3FnnXAb6Q",
"level": 3,
"time": "09/10/2023 10:39:50",
"remoteAddr": "192.168.220.179",
"user": "--",
"app": "no app in context",
"method": "PROPFIND",
"url": "/remote.php/dav/files/REDACTED",
"message": "Could not boot files_trashbin: Could not resolve trashManager! Class \"trashManager\" does not exist",
"userAgent": "Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:109.0) Gecko/20100101 Firefox/117.0",
"version": "27.0.2.1",
"exception": {
"Exception": "OC\\AppFramework\\Utility\\QueryNotFoundException",
"Message": "Could not resolve trashManager! Class \"trashManager\" does not exist",
"Code": 0,
"Trace": [
"file": "/var/www/html/lib/private/AppFramework/Utility/SimpleContainer.php",
"line": 142,
"function": "resolve",
"class": "OC\\AppFramework\\Utility\\SimpleContainer",
"type": "->",
"args": ["trashManager"]
"file": "/var/www/html/lib/private/ServerContainer.php",
"line": 171,
"function": "query",
"type": "->",
"args": ["trashManager", true]
"file": "/var/www/html/lib/private/AppFramework/DependencyInjection/DIContainer.php",
"line": 469,
"class": "OC\\ServerContainer",
"type": "->",
"line": 65,
"class": "OC\\AppFramework\\DependencyInjection\\DIContainer",
"type": "->",
"file": "/var/www/html/lib/private/AppFramework/Bootstrap/FunctionInjector.php",
"line": 56,
"function": "get",
"type": "->",
"function": "OC\\AppFramework\\Bootstrap\\{closure}",
"class": "OC\\AppFramework\\Bootstrap\\FunctionInjector",
"type": "->",
"args": ["*** sensitive parameters replaced ***"]
"line": 45,
"function": "array_map",
"args": [
["Closure"],
["ReflectionParameter", "serverContainer"],
["ReflectionParameter", "logger"],
["ReflectionParameter", "appManager"],
"file": "/var/www/html/lib/private/AppFramework/Bootstrap/BootContext.php",
"line": 50,
"function": "injectFn",
"type": "->",
"args": [[["OCA\\Files_Trashbin\\AppInfo\\Application"], "registerTrashBackends"]]
"file": "/var/www/html/apps/files_trashbin/lib/AppInfo/Application.php",
"line": 68,
"class": "OC\\AppFramework\\Bootstrap\\BootContext",
"type": "->",
"file": "/var/www/html/lib/private/AppFramework/Bootstrap/Coordinator.php",
"line": 200,
"function": "boot",
"class": "OCA\\Files_Trashbin\\AppInfo\\Application",
"type": "->",
"args": [["OC\\AppFramework\\Bootstrap\\BootContext"]]
"file": "/var/www/html/lib/private/App/AppManager.php",
"line": 437,
"function": "bootApp",
"class": "OC\\AppFramework\\Bootstrap\\Coordinator",
"type": "->",
"args": ["files_trashbin"]
"line": 216,
"function": "loadApp",
"class": "OC\\App\\AppManager",
"type": "->",
"file": "/var/www/html/lib/private/legacy/OC_App.php",
"line": 126,
"function": "loadApps",
"type": "->",
"args": [["dav"]]
"file": "/var/www/html/apps/dav/lib/AppInfo/Application.php",
"line": 209,
"class": "OC_App",
"type": "::",
"args": [["dav"]]
"line": 200,
"function": "boot",
"class": "OCA\\DAV\\AppInfo\\Application",
"type": "->",
"line": 437,
"type": "->",
"args": ["dav"]
"line": 216,
"type": "->",
"args": ["dav"]
"line": 126,
"type": "->",
"args": [["filesystem"]]
"file": "/var/www/html/lib/private/Files/SetupManager.php",
"line": 132,
"class": "OC_App",
"type": "::",
"line": 351,
"function": "setupBuiltinWrappers",
"class": "OC\\Files\\SetupManager",
"type": "->",
"args": []
"line": 391,
"function": "setupRoot",
"type": "->",
"args": []
"file": "/var/www/html/lib/private/Files/Mount/Manager.php",
"line": 95,
"function": "setupForPath",
"type": "->",
"args": ["/appdata_ochasn1ca9qh/js/core"]
"file": "/var/www/html/lib/private/Files/View.php",
"line": 1352,
"function": "find",
"class": "OC\\Files\\Mount\\Manager",
"type": "->",
"file": "/var/www/html/lib/private/Files/Node/Root.php",
"line": 202,
"function": "getFileInfo",
"class": "OC\\Files\\View",
"type": "->",
"args": ["/appdata_ochasn1ca9qh/js/core", false]
"function": "get",
"class": "OC\\Files\\Node\\Root",
"type": "->",
"file": "/var/www/html/lib/private/Files/Node/LazyFolder.php",
"line": 74,
"function": "call_user_func_array",
"args": [[["OC\\Files\\Node\\Root"], "get"], ["appdata_ochasn1ca9qh/js/core"]]
"line": 151,
"function": "__call",
"class": "OC\\Files\\Node\\LazyFolder",
"type": "->",
"args": ["get", ["appdata_ochasn1ca9qh/js/core"]]
"file": "/var/www/html/lib/private/Files/AppData/AppData.php",
"line": 132,
"function": "get",
"type": "->",
"args": ["appdata_ochasn1ca9qh/js/core"]
"file": "/var/www/html/lib/private/Template/JSCombiner.php",
"line": 87,
"function": "getFolder",
"class": "OC\\Files\\AppData\\AppData",
"type": "->",
"args": ["core"]
"file": "/var/www/html/lib/private/Template/JSResourceLocator.php",
"line": 145,
"function": "process",
"class": "OC\\Template\\JSCombiner",
"type": "->",
"args": ["/var/www/html", "core/js/merged-template-prepend.json", "core"]
"line": 75,
"function": "cacheAndAppendCombineJsonIfExist",
"class": "OC\\Template\\JSResourceLocator",
"type": "->",
"args": ["/var/www/html", "core/js/merged-template-prepend.json"]
"file": "/var/www/html/lib/private/Template/ResourceLocator.php",
"line": 73,
"function": "doFind",
"type": "->",
"args": ["core/js/merged-template-prepend"]
"file": "/var/www/html/lib/private/TemplateLayout.php",
"line": 377,
"function": "find",
"class": "OC\\Template\\ResourceLocator",
"type": "->",
"args": [
"core/js/common",
"core/js/main",
"core/l10n/pl",
"core/js/files_fileinfo",
"core/js/files_client",
"And 1 more entries, set log level to debug to see all entries"
"line": 222,
"function": "findJavascriptFiles",
"class": "OC\\TemplateLayout",
"type": "::",
"args": [
"core/js/common",
"core/js/main",
"core/l10n/pl",
"file": "/var/www/html/lib/private/legacy/OC_Template.php",
"line": 182,
"function": "__construct",
"type": "->",
"args": ["error", ""]
"file": "/var/www/html/lib/private/Template/Base.php",
"line": 132,
"function": "fetchPage",
"class": "OC_Template",
"type": "->",
"args": []
"line": 331,
"function": "printPage",
"class": "OC\\Template\\Base",
"type": "->",
"args": []
"file": "/var/www/html/remote.php",
"line": 92,
"function": "printExceptionErrorPage",
"type": "::",
"args": [["Doctrine\\DBAL\\Exception"], 500]
"line": 174,
"function": "handleException",
"args": [["Doctrine\\DBAL\\Exception"]]
"File": "/var/www/html/lib/private/AppFramework/Utility/SimpleContainer.php",
"Line": 131,
"exception": {},
"CustomMessage": "Could not boot files_trashbin: Could not resolve trashManager! Class \"trashManager\" does not exist"
"reqId": "xOeM2DwyDzMYaCj09JSr",
"level": 3,
"time": "26/10/2023 09:24:19",
"remoteAddr": "192.168.220.227",
"user": "REDACTED",
"method": "PUT",
"url": "/remote.php/webdav/Pictures/REDACTED",
"message": "Expected filesize of 3144011 bytes but read (from Nextcloud client) and wrote (to Nextcloud storage) 3137536 bytes. Could either be a network problem on the sending side or a problem writing to the storage on the server side.",
"userAgent": "Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:109.0) Gecko/20100101 Firefox/118.0",
"exception": {
"Exception": "Sabre\\DAV\\Exception\\BadRequest",
"Message": "Expected filesize of 3144011 bytes but read (from Nextcloud client) and wrote (to Nextcloud storage) 3137536 bytes. Could either be a network problem on the sending side or a problem writing to the storage on the server side.",
"Code": 0,
"Trace": [
"file": "/var/www/html/apps/dav/lib/Connector/Sabre/Directory.php",
"line": 149,
"function": "put",
"class": "OCA\\DAV\\Connector\\Sabre\\File",
"type": "->",
"file": "/var/www/html/3rdparty/sabre/dav/lib/DAV/Server.php",
"line": 1098,
"function": "createFile",
"class": "OCA\\DAV\\Connector\\Sabre\\Directory",
"type": "->",
"file": "/var/www/html/3rdparty/sabre/dav/lib/DAV/CorePlugin.php",
"line": 504,
"class": "Sabre\\DAV\\Server",
"type": "->",
"file": "/var/www/html/3rdparty/sabre/event/lib/WildcardEmitterTrait.php",
"line": 89,
"function": "httpPut",
"class": "Sabre\\DAV\\CorePlugin",
"type": "->",
"args": [["Sabre\\HTTP\\Request"], ["Sabre\\HTTP\\Response"]]
"line": 472,
"function": "emit",
"type": "->",
"args": ["method:PUT", [["Sabre\\HTTP\\Request"], ["Sabre\\HTTP\\Response"]]]
"line": 253,
"function": "invokeMethod",
"type": "->",
"line": 321,
"function": "start",
"type": "->",
"args": []
"file": "/var/www/html/apps/dav/appinfo/v1/webdav.php",
"line": 85,
"function": "exec",
"type": "->",
"args": []
"line": 172,
"args": ["/var/www/html/apps/dav/appinfo/v1/webdav.php"],
"function": "require_once"
"File": "/var/www/html/apps/dav/lib/Connector/Sabre/File.php",
"Line": 297,
"exception": {},
"CustomMessage": "Expected filesize of 3144011 bytes but read (from Nextcloud client) and wrote (to Nextcloud storage) 3137536 bytes. Could either be a network problem on the sending side or a problem writing to the storage on the server side."
"reqId": "z0tFV4bx8AG88khKzwxh",
"level": 3,
"time": "26/10/2023 11:50:24",
"user": "--",
"method": "GET",
"url": "/core/preview?fileId=571658&c=d61444f459cf416d0d8fbdf2b3a70b79&x=375&y=375&forceIcon=0&a=1",
"message": "Could not boot files_sharing: Could not resolve externalMountProvider! Class \"externalMountProvider\" does not exist",
"exception": {
"Message": "Could not resolve externalMountProvider! Class \"externalMountProvider\" does not exist",
"Code": 0,
"Trace": [
"line": 142,
"type": "->",
"args": ["externalMountProvider"]
"line": 171,
"type": "->",
"args": ["externalMountProvider", true]
"line": 469,
"type": "->",
"line": 65,
"type": "->",
"line": 56,
"function": "get",
"type": "->",
"type": "->",
"line": 45,
"args": [
["Closure"],
["ReflectionParameter", "mountProviderCollection"],
["ReflectionParameter", "mountProvider"],
"line": 50,
"type": "->",
"args": [[["OCA\\Files_Sharing\\AppInfo\\Application"], "registerMountProviders"]]
"file": "/var/www/html/apps/files_sharing/lib/AppInfo/Application.php",
"line": 117,
"type": "->",
"line": 200,
"function": "boot",
"class": "OCA\\Files_Sharing\\AppInfo\\Application",
"type": "->",
"line": 437,
"type": "->",
"args": ["files_sharing"]
"line": 216,
"type": "->",
"line": 126,
"type": "->",
"line": 132,
"class": "OC_App",
"type": "::",
"line": 351,
"type": "->",
"args": []
"line": 391,
"type": "->",
"args": []
"line": 95,
"type": "->",
"line": 1352,
"function": "find",
"type": "->",
"line": 202,
"type": "->",
"function": "get",
"type": "->",
"line": 74,
"line": 151,
"type": "->",
"line": 132,
"function": "get",
"type": "->",
"line": 87,
"type": "->",
"args": ["core"]
"line": 145,
"type": "->",
"line": 75,
"type": "->",
"line": 73,
"type": "->",
"line": 377,
"function": "find",
"type": "->",
"args": [
"core/js/common",
"core/js/main",
"core/l10n/pl",
"line": 222,
"type": "::",
"args": [
"core/js/common",
"core/js/main",
"core/l10n/pl",
"line": 182,
"type": "->",
"line": 132,
"type": "->",
"args": []
"line": 331,
"type": "->",
"args": []
"file": "/var/www/html/index.php",
"line": 74,
"type": "::",
"Line": 131,
"exception": {},
"CustomMessage": "Could not boot files_sharing: Could not resolve externalMountProvider! Class \"externalMountProvider\" does not exist"
"reqId": "eqsWZSwOyyQowOd2TXl8",
"level": 3,
"time": "26/10/2023 12:22:32",
"user": "REDACTED",
"app": "index",
"method": "GET",
"url": "/apps/files/api/v1/stats?dir=REDACTED",
"message": "",
"exception": {
"Exception": "OCP\\Files\\NotFoundException",
"Message": "",
"Code": 0,
"Trace": [
"file": "/var/www/html/apps/files/lib/Controller/ApiController.php",
"line": 267,
"function": "getStorageInfo",
"class": "OC_Helper",
"type": "::",
"args": ["/Pictures/REDACTED"]
"file": "/var/www/html/lib/private/AppFramework/Http/Dispatcher.php",
"line": 230,
"function": "getStorageStats",
"class": "OCA\\Files\\Controller\\ApiController",
"type": "->",
"line": 137,
"function": "executeController",
"class": "OC\\AppFramework\\Http\\Dispatcher",
"type": "->",
"args": [["OCA\\Files\\Controller\\ApiController"], "getStorageStats"]
"file": "/var/www/html/lib/private/AppFramework/App.php",
"line": 183,
"function": "dispatch",
"type": "->",
"file": "/var/www/html/lib/private/Route/Router.php",
"line": 315,
"function": "main",
"class": "OC\\AppFramework\\App",
"type": "::",
"args": [
"APIController",
"getStorageStats",
["OC\\AppFramework\\DependencyInjection\\DIContainer"],
["files.API.getStorageStats"]
"file": "/var/www/html/lib/base.php",
"line": 1071,
"function": "match",
"class": "OC\\Route\\Router",
"type": "->",
"args": ["/apps/files/api/v1/stats"]
"line": 36,
"function": "handleRequest",
"class": "OC",
"type": "::",
"args": []
"File": "/var/www/html/lib/private/legacy/OC_Helper.php",
"Line": 490,
"CustomMessage": "--"
'apps_paths' =>
0 =>
'url' => '/apps',
'writable' => false,
1 =>
'url' => '/custom_apps',
'writable' => true,
'passwordsalt' => REDACTED,
'secret' => REDACTED,
'dbtype' => 'pgsql',
'version' => '27.1.3.2',
'overwrite.cli.url' => REDACTED,
'dbname' => 'nextcloud',
'dbhost' => 'nextcloud-cnpg-main-rw',
'dbuser' => 'nextcloud',
'dbpassword' => REDACTED,
'instanceid' => REDACTED,
'redis' =>
'host' => 'nextcloud-redis',
'password' => REDACTED,
'port' => '6379',
'default_phone_region' => 'PL',
'share_folder' => 'Shared',
'log_type' => 'file',
'log_type_audit' => 'file',
'loglevel' => '2',
'logfile' => '/var/www/html/data/logs/nextcloud.log',
'logfile_audit' => '/var/www/html/data/logs/audit.log',
'logdateformat' => 'd/m/Y H:i:s',
'logtimezone' => 'Europe/Warsaw',
'overwritehost' => REDACTED,
'activity_expire_days' => '30',
'trashbin_retention_obligation' => 'auto',
'versions_retention_obligation' => 'auto',
'preview_imaginary_url' => 'http://nextcloud-imaginary:9090',
'enable_previews' => 'true',
'jpeg_quality' => '60',
'preview_max_x' => '2048',
'preview_max_y' => '2048',
'preview_max_memory' => '2048',
'preview_max_filesize_image' => '50',
'onlyoffice' => '',
0 => '127.0.0.1',
1 => 'localhost',
2 => 'nextcloud',
3 => 'nextcloud-*',
4 => 'kube.internal.healthcheck',
5 => 'https',
6 => '192.168.X.X',
'trusted_proxies' =>
0 => '172.16.0.0/16',
1 => '172.17.0.0/16',
'enabledPreviewProviders' =>
0 => 'OC\\Preview\\Imaginary',
1 => 'OC\\Preview\\BMP',
2 => 'OC\\Preview\\GIF',
3 => 'OC\\Preview\\JPEG',
4 => 'OC\\Preview\\MarkDown',
5 => 'OC\\Preview\\MP3',
6 => 'OC\\Preview\\OpenDocument',
7 => 'OC\\Preview\\PNG',
8 => 'OC\\Preview\\TXT',
