Nextcloud version (eg, 20.0.5): 28.0.4.1
Operating system and version (eg, Ubuntu 20.04): uname -o GNU/Linux
Apache or nginx version (eg, Apache 2.4.25): apache2 -v Server version: Apache/2.4.58 (Unix) Server built: Apr 1 2024 19:45:26
PHP version (eg, 7.4): php -v PHP 8.1.26 (cli) (built: Apr 1 2024 10:03:59) (NTS)
after a fresh install of nextcloud with provider Manitu “one-click-installation”
I encounter problems:
- I can install a user, but I cannot deactivate or delete a user
- I can activate the calendar app, however I cannot create an entry (a white box with no text spins forever)
- I can import an external calendar via an *.ics file, however none of the entires are imported
- I cannot delete a calendar, imported or locally created
- I cannot select filters in admin/logging
… several other things are not working
- use one-click-installation procedure with Manitu (fresh database, separate installation directory
- create a user
- try to delete the user (does not work)
I found similar problem here in the forum
and found a patch for it here
I added the ‘/’ by hand in the file, however, I cannot say it did help any
Fehler PHP
is_writable(): open_basedir restriction in effect. File(/data) is not within the allowed path(s): (/home/sites/site100004063/:/tmp/:/dev/:/usr/share/php/:/etc/ssl/certs/:/usr/lib64/php8.1/bin/) at /home/sites/site100004063/web/nextcloud/lib/private/Log/File.php#65
19.04.2024, 19:04:11
Fehler PHP
Fehler PHP
19.04.2024, 19:04:12
Fehler PHP
Fehler PHP
Fehler PHP
Fehler PHP
19.04.2024, 19:04:13
Fehler PHP
Fehler PHP
Fehler PHP
19.04.2024, 19:04:14
Fehler PHP
Fehler PHP
Fehler PHP
Fehler PHP
19.04.2024, 19:04:15
Fehler PHP
Fehler PHP
Fehler PHP
19.04.2024, 19:04:16
Fehler PHP
Fehler PHP
19.04.2024, 19:04:17
Fehler PHP
Fehler PHP
Fehler PHP
Fehler PHP
19.04.2024, 19:04:18
Fehler PHP
Fehler PHP
Fehler PHP
19.04.2024, 19:04:19
Fehler PHP
Fehler PHP
Fehler PHP
Fehler PHP
Fehler PHP
19.04.2024, 19:04:20
Fehler PHP
Fehler PHP
Fehler PHP
19.04.2024, 19:04:21
Fehler PHP
Fehler PHP
Fehler PHP
Fehler PHP
19.04.2024, 19:04:22
Fehler PHP
Fehler PHP
Fehler PHP
Fehler PHP
19.04.2024, 19:04:23
Fehler PHP
Fehler PHP
19.04.2024, 19:04:24
Fehler PHP
Fehler PHP
Fehler PHP
Fehler PHP
19.04.2024, 19:04:25
Fehler PHP
Fehler PHP
Fehler PHP
19.04.2024, 19:04:26
Fehler PHP
cat config/config.php
'default_language' => 'de',
'default_locale' => 'de_DE',
'enable_previews' => 'false',
'skeletondirectory' => '',
'instanceid' => 'ocej1dd5limx',
'passwordsalt' => 'xxxxxxxxxxxxxxxxxxxx',
'secret' => 'xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx',
0 => 'nextcloud.xxxxxxxxxxx.de',
'datadirectory' => '/home/sites/sitexxxxxxx/web/nextcloud/data',
'version' => '28.0.4.1',
'integrity.check.disabled' => true,
'version_retention_obligation' => 'auto, 30',
# 'log_type' => 'file',
# 'logfile' => '/dev/null',
# mnm20240419
'logfile' => '/data/nextcloud.log',
'loglevel' => '3',
'logdateformat' => 'F d, Y H:i:s',
'localstorage.umask' => 7,
'overwrite.cli.url' => 'https://nextcloud.xxxxxxx.de',
'dbname' => 'xxxxxxxx',
'dbhost' => 'mysql11.manitu.net',
'dbtableprefix' => 'nc_',
'dbuser' => 'xxxxx',
'dbpassword' => 'xxxxxxx',
'mail_domain' => 'djk-obernau.de',
'mail_smtpmode' => 'smtp',
'mail_smtpsecure' => 'ssl',
I cannot access the requested file via ssh, because I do not have the privileges
PASTE HERE
PASTE HERE
{"reqId":"ZiJOE3qzquN9RKczZGTzIQAAACk","level":3,"time":"April 19, 2024 10:57:23","remoteAddr":"95.90.217.225","user":"Nextcloud Admin","app":"PHP","method":"GET","url":"/index.php/apps/logreader/api/poll?last
ReqId=ZiJBV68qyyVZvONlR9AXrQAAACw","message":"file_exists(): open_basedir restriction in effect. File(/data/nextcloud.log) is not within the allowed path(s): (/home/sites/site100004063/:/tmp/:/dev/:/usr/share/
php/:/etc/ssl/certs/:/usr/lib64/php8.1/bin/) at /home/sites/site100004063/web/nextcloud/lib/private/Log/File.php#62","userAgent":"Mozilla/5.0 (X11; Linux x86_64; rv:109.0) Gecko/20100101 Firefox/115.0","versio
n":"28.0.4.1","data":{"app":"PHP"}}
ReqId=ZiJBV68qyyVZvONlR9AXrQAAACw","message":"is_writable(): open_basedir restriction in effect. File(/data) is not within the allowed path(s): (/home/sites/site100004063/:/tmp/:/dev/:/usr/share/php/:/etc/ssl/
certs/:/usr/lib64/php8.1/bin/) at /home/sites/site100004063/web/nextcloud/lib/private/Log/File.php#65","userAgent":"Mozilla/5.0 (X11; Linux x86_64; rv:109.0) Gecko/20100101 Firefox/115.0","version":"28.0.4.1",
{"reqId":"ZiJOHRXuEKrj3WkejuinsQAAACI","level":3,"time":"April 19, 2024 10:57:33","remoteAddr":"95.90.217.225","user":"Nextcloud Admin","app":"PHP","method":"GET","url":"/index.php/apps/logreader/api/poll?last
ReqId=ZiJOE3qzquN9RKczZGTzIQAAACk","message":"file_exists(): open_basedir restriction in effect. File(/data/nextcloud.log) is not within the allowed path(s): (/home/sites/site100004063/:/tmp/:/dev/:/usr/share/
ReqId=ZiJOE3qzquN9RKczZGTzIQAAACk","message":"is_writable(): open_basedir restriction in effect. File(/data) is not within the allowed path(s): (/home/sites/site100004063/:/tmp/:/dev/:/usr/share/php/:/etc/ssl/
{"reqId":"ZiJOHxXuEKrj3WkejuinsgAAACI","level":3,"time":"April 19, 2024 10:57:35","remoteAddr":"95.90.217.225","user":"Nextcloud Admin","app":"PHP","method":"GET","url":"/ocs/v2.php/apps/notifications/api/v2/n
otifications","message":"is_writable(): open_basedir restriction in effect. File(/data) is not within the allowed path(s): (/home/sites/site100004063/:/tmp/:/dev/:/usr/share/php/:/etc/ssl/certs/:/usr/lib64/php
8.1/bin/) at /home/sites/site100004063/web/nextcloud/lib/private/Log/File.php#65","userAgent":"Mozilla/5.0 (X11; Linux x86_64; rv:109.0) Gecko/20100101 Firefox/115.0","version":"28.0.4.1","data":{"app":"PHP"}}
{"reqId":"ZiJOKLvj9uHFwohugkRlLgAAABE","level":3,"time":"April 19, 2024 10:57:44","remoteAddr":"95.90.217.225","user":"Nextcloud Admin","app":"PHP","method":"GET","url":"/index.php/apps/logreader/api/poll?last
ReqId=ZiJOHRXuEKrj3WkejuinsQAAACI","message":"file_exists(): open_basedir restriction in effect. File(/data/nextcloud.log) is not within the allowed path(s): (/home/sites/site100004063/:/tmp/:/dev/:/usr/share/
ReqId=ZiJOHRXuEKrj3WkejuinsQAAACI","message":"is_writable(): open_basedir restriction in effect. File(/data) is not within the allowed path(s): (/home/sites/site100004063/:/tmp/:/dev/:/usr/share/php/:/etc/ssl/
{"reqId":"ZiJOMgFvPvZPVbq3ncCSbwAAACQ","level":3,"time":"April 19, 2024 10:57:54","remoteAddr":"95.90.217.225","user":"Nextcloud Admin","app":"PHP","method":"GET","url":"/index.php/apps/logreader/api/poll?last
ReqId=ZiJOKLvj9uHFwohugkRlLgAAABE","message":"file_exists(): open_basedir restriction in effect. File(/data/nextcloud.log) is not within the allowed path(s): (/home/sites/site100004063/:/tmp/:/dev/:/usr/share/
ReqId=ZiJOKLvj9uHFwohugkRlLgAAABE","message":"is_writable(): open_basedir restriction in effect. File(/data) is not within the allowed path(s): (/home/sites/site100004063/:/tmp/:/dev/:/usr/share/php/:/etc/ssl/
{"reqId":"ZiJOPBVQOCD2JxRs492vgwAAAC0","level":3,"time":"April 19, 2024 10:58:04","remoteAddr":"95.90.217.225","user":"Nextcloud Admin","app":"PHP","method":"GET","url":"/index.php/apps/logreader/api/poll?last
ReqId=ZiJOMgFvPvZPVbq3ncCSbwAAACQ","message":"file_exists(): open_basedir restriction in effect. File(/data/nextcloud.log) is not within the allowed path(s): (/home/sites/site100004063/:/tmp/:/dev/:/usr/share/
ReqId=ZiJOMgFvPvZPVbq3ncCSbwAAACQ","message":"is_writable(): open_basedir restriction in effect. File(/data) is not within the allowed path(s): (/home/sites/site100004063/:/tmp/:/dev/:/usr/share/php/:/etc/ssl/
