Steps to reproduce
I have one problem with email settings ( smtp )
When i fill the necessary fields ( all mail settings are correct ), then tryng to send test mail I get the error:
Beim Senden der E-Mail ist ein Problem aufgetreten. Bitte überprüfe Deine Einstellungen. (Fehler: Address in mailbox given [ Support@localhost.localdomain] does not comply with RFC 2822, 3.6.2.)
How can I fix this?
Expected behaviour
I can’t login in the Email Client on the Server
Actual behaviour
When i fill the necessary fields ( all mail settings are correct ), then tryng to send test mail.
Server configuration detail
Operating system: Linux 4.9.0-8-amd64 #1 SMP Debian 4.9.130-2 (2018-10-27) x86_64
Webserver: Apache/2.4.25 (Debian) (apache2handler)
Database: mysql 10.1.37
PHP version:
7.0.30-0+deb9u1
Modules loaded: Core, date, libxml, openssl, pcre, zlib, filter, hash, Reflection, SPL, session, standard, apache2handler, mysqlnd, PDO, xml, apcu, apc, bz2, calendar, ctype, curl, dom, mbstring, fileinfo, ftp, gd, gettext, iconv, intl, json, exif, mcrypt, mysqli, pdo_mysql, Phar, posix, readline, shmop, SimpleXML, sockets, sysvmsg, sysvsem, sysvshm, tokenizer, wddx, xmlreader, xmlwriter, xsl, zip, Zend OPcache
Nextcloud version: 14.0.4
Updated from an older Nextcloud/ownCloud or fresh install:
Where did you install Nextcloud from: unknown
Signing status
Array
List of activated apps
- accessibility: 1.0.1
- activity: 2.7.0
- admin_notifications: 1.0.2
- bookmarks_fulltextsearch: 1.0.0
- camerarawpreviews: 0.6.1
- cloud_federation_api: 0.0.1
- comments: 1.4.0
- dav: 1.6.0
- drop_account: 0.0.13
- federatedfilesharing: 1.4.0
- federation: 1.4.0
- files: 1.9.0
- files_fulltextsearch: 1.1.1
- files_fulltextsearch_tesseract: 1.0.0
- files_pdfviewer: 1.3.2
- files_rightclick: 0.8.4
- files_sharing: 1.6.2
- files_texteditor: 2.6.0
- files_trashbin: 1.4.1
- files_versions: 1.7.1
- files_videoplayer: 1.3.0
- firstrunwizard: 2.3.0
- fulltextsearch: 1.1.0
- fulltextsearch_elasticsearch: 1.0.2
- gallery: 18.1.0
- issuetemplate: 0.4.0
- logreader: 2.0.0
- lookup_server_connector: 1.2.0
- metadata: 0.8.0
- nextcloud_announcements: 1.3.0
- notifications: 2.2.1
- oauth2: 1.2.1
- password_policy: 1.4.0
- provisioning_api: 1.4.0
- quicknotes: 0.1.5
- quota_warning: 1.3.0
- registration: 0.4.5
- serverinfo: 1.4.0
- sharebymail: 1.4.0
- socialsharing_diaspora: 1.0.3
- socialsharing_email: 1.0.4
- socialsharing_facebook: 1.0.3
- socialsharing_googleplus: 1.0.3
- socialsharing_twitter: 1.0.3
- support: 1.0.0
- survey_client: 1.2.0
- systemtags: 1.4.0
- theming: 1.5.0
- twofactor_backupcodes: 1.3.1
- twofactor_totp: 1.5.0
- unsplash: 1.1.1
- updatenotification: 1.4.1
- workflowengine: 1.4.0
- admin_audit
- encryption
- files_external
- user_external
- user_ldap
Configuration (config/config.php)
"178.63.9.142",
"dragon-cloud.net",
"www.dragon-cloud.net"
"dbtype": "mysql",
"version": "14.0.4.2",
"overwrite.cli.url": "http:\/\/178.63.9.142\/nextcloud",
"dbport": "",
"mail_smtpmode": "smtp",
"mail_smtpsecure": "ssl",
"mail_smtpauth": 1,
"mail_smtpauthtype": "LOGIN",
"mail_smtpport": "587",
"theme": "",
"loglevel": 2
Are you using external storage, if yes which one: local/smb/sftp/…
Are you using encryption:
Are you using an external user-backend, if yes which one: LDAP/ActiveDirectory/Webdav/…
Client configuration
Browser: Mozilla/5.0 (Macintosh; Intel Mac OS X 10_14_1) AppleWebKit/605.1.15 (KHTML, like Gecko) Version/12.0.1 Safari/605.1.15
Operating system:
Logs
Browser log
Nextcloud log
