Problems with Dashboard
    • 34.0.1
    • Debian 12
    • Apache/2.4.68
    • 8.5
    • No, about 4–6 weeks.
    • no idea
    • Installation from a zip file about 5 years ago
Issues with the dashboard and the display of upcoming appointments or activities. It appears as though the display is frozen. The dashboard shows 4 appointments, even though there are several in the calendar. For Monday, 1 appointment is displayed instead of 2, and for Tuesday, for example, none are shown even though one exists.
Debian 12, MariaDB 11.8.8, PHP 8.5, Nextcloud 34.0.1
No entries
Chrome, Safari, Brave
no relevant entries
PASTE HERE{
        "serverid": 1,
            "cloudy.boris-nbg.de",
            "46.4.32.8"
        "version": "34.0.1.2",
        "dbtype": "mysql",
        "mail_smtpdebug": false,
        "mail_smtpmode": "smtp",
        "mail_smtpport": "587",
        "mail_smtptimeout": 10,
        "mail_smtpsecure": "tls",
        "mail_smtpauth": 1,
        "mail_smtpauthtype": "LOGIN",
        "mail_send_plaintext_only": false,
        "mail_sendmailmode": "smtp",
        "overwriteprotocol": "https",
        "overwritehost": "cloudy.boris-nbg.de",
        "updater.server.url": "***REMOVED SENSITIVE VALUE***",
        "check_for_working_wellknown_setup": true,
        "check_for_working_htaccess": true,
        "check_data_directory_permissions": true,
        "config_is_read_only": false,
        "log_type": "file",
        "logfile": "\/var\/customers\/webs\/borisuwe\/clouddata\/logs\/nextcloud.log",
        "logfilemode": 416,
        "loglevel": 3,
        "syslog_tag": "Nextcloud",
        "logdateformat": "l d.M Y H:i:s",
        "logtimezone": "Europe\/Berlin",
        "log_query": false,
        "log_rotate_size": 300000,
        "enable_previews": true,
        "preview_max_x": 2048,
        "preview_max_y": 2048,
        "preview_max_filesize_image": 50,
        "enabledPreviewProviders": [
            "OC\\Preview\\PNG",
            "OC\\Preview\\JPEG",
            "OC\\Preview\\GIF",
            "OC\\Preview\\HEIC",
            "OC\\Preview\\BMP",
            "OC\\Preview\\XBitmap",
            "OC\\Preview\\MP3",
            "OC\\Preview\\TXT",
            "OC\\Preview\\MarkDown",
            "OC\\Preview\\PDF",
            "OC\\Preview\\Movie"
        "redis": {
            "port": 0,
            "timeout": 0,
            "dbindex": 1
        "cache_path": "",
        "cache_chunk_gc_ttl": 86400,
        "hashingCost": 10,
        "blacklisted_files": [
            ".htaccess"
        "theme": "",
        "part_file_in_storage": true,
        "forwarded_for_headers": [
            "HTTP_X_FORWARDED",
            "HTTP_FORWARDED_FOR",
            "HTTP_X_FORWARDED_FOR"
        "filelocking.enabled": true,
        "filelocking.ttl": 3600,
        "filelocking.debug": false,
        "debug": false,
        "login_form_autocomplete": true,
        "appstore.experimental.enabled": true,
        "overwrite.cli.url": "https:\/\/cloudy.boris-nbg.de",
        "mysql.utf8mb4": true,
        "default_phone_region": "DE",
        "maintenance_window_start": "1",
        "twofactor_enforced": "false",
        "twofactor_enforced_groups": [],
        "davstorage.request_timeout": "120",
        "app_install_overwrite": {
            "2": "snappymail",
            "3": "dashboard"
        "locale": "de",
        "richdocuments_verify_peer_off": true,
        "defaultapp": "dashboard",
        "memories.exiftool": "\/var\/customers\/webs\/borisuwe\/boris-nbg.de_cloudy\/apps\/memories\/bin-ext\/exiftool-amd64-glibc",
        "memories.vod.path": "\/var\/customers\/webs\/borisuwe\/boris-nbg.de_cloudy\/apps\/memories\/bin-ext\/go-vod-amd64"
  • activity: 7.0.0
  • admin_audit: 1.24.0
  • admincockpit: 1.3.1
  • appstore: 1.0.0
  • bookmarks: 16.2.2
  • calendar: 6.5.0
  • circles: 34.0.0
  • cloud_federation_api: 1.18.0
  • comments: 1.24.0
  • contacts: 8.7.3
  • dashboard: 7.14.0
  • dav: 1.39.0
  • event_update_notification: 2.9.0
  • federatedfilesharing: 1.24.0
  • federation: 1.24.0
  • files: 2.6.0
  • files_downloadlimit: 5.2.0-dev.0
  • files_lock: 34.0.0
  • files_pdfviewer: 7.0.0-dev.0
  • files_reminders: 1.7.0
  • files_sharing: 1.26.0
  • files_trashbin: 1.24.0
  • files_versions: 1.27.0
  • firstrunwizard: 7.0.0-dev.0
  • geoblocker: 0.5.21
  • groupfolders: 22.0.2
  • logcleaner: 1.5.5
  • logreader: 7.0.0
  • lookup_server_connector: 1.22.0
  • mail: 5.10.7
  • memories: 8.1.0
  • nextcloud_announcements: 6.0.0
  • notes: 6.0.1
  • notifications: 7.0.0-dev.1
  • notify_push: 1.3.3
  • oauth2: 1.22.0
  • office: 1.0.0
  • password_policy: 6.0.0-dev.0
  • photos: 7.0.0
  • previewgenerator: 5.14.0
  • privacy: 6.0.0-dev.1
  • profile: 1.3.0
  • provisioning_api: 1.24.0
  • recommendations: 7.0.0
  • related_resources: 5.0.0-dev.0
  • richdocuments: 11.0.1
  • serverinfo: 6.0.0
  • settings: 1.17.0
  • sharebymail: 1.24.0
  • support: 6.0.0
  • survey_client: 6.0.0-dev.0
  • systemtags: 1.24.0
  • tasks: 0.18.1
  • text: 8.0.0
  • theming: 2.9.0
  • twofactor_backupcodes: 1.23.0
  • twofactor_totp: 16.0.0
  • updatenotification: 1.24.0
  • user_status: 1.14.0
  • viewer: 7.0.0-dev.0
  • weather_status: 1.14.0
  • webhook_listeners: 1.6.0
  • workflowengine: 2.16.0
  • app_api: 34.0.0 (installed 32.0.0)
  • bruteforcesettings: 7.0.0 (installed 1.2.0)
  • contactsinteraction: 1.15.0 (installed 1.8.0)
  • encryption: 2.22.0
  • files_external: 1.26.0
  • snappymail: 2.38.2 (installed 2.38.2)
  • suspicious_login: 12.0.0-dev.0
  • testing: 1.23.0
  • twofactor_nextcloud_notification: 8.0.0
  • user_ldap: 1.25.0
Regards Uwe
