Yesterday I installed successfully NextCloud on my Synology ds418 with the following manual: How to Install Nextcloud on Your Synology NAS – Marius Hosting.
But after I tried to create the first admin account, I got the following error:
Error while trying to create admin user: Failed to connect to the database: An exception occurred in driver: SQLSTATE[HY000] [1045] Access denied for user ‘oc_admin’@‘localhost’ (using password: YES)
My knowledge about databases is very bad and after a lot of Googling I couldn’t find an answer. I get a lot of errors about wrong SQL syntaxes: {“reqId”:“QrPSYs4wO8TEQ5OJ6GMe”,“level”:3,“time”:“2020-01-06T17:47:40+00:00”,“remoteAddr”:“…”,“user”:“–”,“app”:“mysql.setup”,“method”:“POST”,“url”:“/index.php”,“message”:{“Exception”:“Doctrine\DBAL\Exception\SyntaxErrorException”,“Message”:“An exception occurred while executing ‘CREATE USER ‘oc_admin’@‘localhost’ IDENTIFIED WITH mysql_native_password BY ‘…’’:\n\nSQLSTATE[42000]: Syntax error or access violation: 1064 You have an error in your SQL syntax; check the manual that corresponds to your MariaDB server version for the right syntax to use near ‘BY ‘…’’ at line 1”,“Code”:0,“Trace”:[{“file”:“/volume1/web/nextcloud/3rdparty/doctrine/dbal/lib/Doctrine/DBAL/DBALException.php”,“line”:169,“function”:“convertException”,“class”:“Doctrine\DBAL\Driver\AbstractMySQLDriver”,“type”:“->”,“args”:[“An exception occurred while executing ‘CREATE USER ‘oc_admin’@‘localhost’ IDENTIFIED WITH mysql_native_password BY ‘…’’:\n\nSQLSTATE[42000]: Syntax error or access violation: 1064 You have an error in your SQL syntax; check the manual that corresponds to your MariaDB server version for the right syntax to use near ‘BY ‘…’’ at line 1”,{“errorInfo”:[“42000”,1064,“You have an error in your SQL syntax; check the manual that corresponds to your MariaDB server version for the right syntax to use near ‘BY ‘…’’ at line 1”],“class”:“Doctrine\DBAL\Driver\PDOException”}]},{“file”:“/volume1/web/nextcloud/3rdparty/doctrine/dbal/lib/Doctrine/DBAL/DBALException.php”,“line”:145,“function”:“wrapException”,“class”:“Doctrine\DBAL\DBALException”,“type”:“::”,“args”:[{“class”:“Doctrine\DBAL\Driver\PDOMySql\Driver”},{“errorInfo”:[“42000”,1064,“You have an error in your SQL syntax; check the manual that corresponds to your MariaDB server version for the right syntax to use near ‘BY ‘…’’ at line 1”],“class”:“Doctrine\DBAL\Driver\PDOException”},“An exception occurred while executing ‘CREATE USER ‘oc_admin’@‘localhost’ IDENTIFIED WITH mysql_native_password BY ‘…’’:\n\nSQLSTATE[42000]: Syntax error or access violation: 1064 You have an error in your SQL syntax; check the manual that corresponds to your MariaDB server version for the right syntax to use near ‘BY ‘…’’ at line 1”]},{“file”:“/volume1/web/nextcloud/3rdparty/doctrine/dbal/lib/Doctrine/DBAL/Connection.php”,“line”:1063,“function”:“driverExceptionDuringQuery”,“class”:“Doctrine\DBAL\DBALException”,“type”:“::”,“args”:[{“class”:“Doctrine\DBAL\Driver\PDOMySql\Driver”},{“errorInfo”:[“42000”,1064,“You have an error in your SQL syntax; check the manual that corresponds to your MariaDB server version for the right syntax to use near ‘BY ‘…’’ at line 1”],“class”:“Doctrine\DBAL\Driver\PDOException”},“CREATE USER ‘oc_admin’@‘localhost’ IDENTIFIED WITH mysql_native_password BY ‘…’”,]},{“file”:“/volume1/web/nextcloud/lib/private/DB/Connection.php”,“line”:216,“function”:“executeUpdate”,“class”:“Doctrine\DBAL\Connection”,“type”:“->”,“args”:[“CREATE USER ‘oc_admin’@‘localhost’ IDENTIFIED WITH mysql_native_password BY ‘…’”,,]},{“file”:“/volume1/web/nextcloud/lib/private/Setup/MySQL.php”,“line”:104,“function”:“executeUpdate”,“class”:“OC\DB\Connection”,“type”:“->”,“args”:[“CREATE USER ‘oc_admin’@‘localhost’ IDENTIFIED WITH mysql_native_password BY ‘…’”]},{“file”:“/volume1/web/nextcloud/lib/private/Setup/MySQL.php”,“line”:149,“function”:“createDBUser”,“class”:“OC\Setup\MySQL”,“type”:“->”,“args”:[{“class”:“OC\DB\Connection”}]},{“file”:“/volume1/web/nextcloud/lib/private/Setup/MySQL.php”,“line”:50,“function”:“createSpecificUser”,“class”:“OC\Setup\MySQL”,“type”:“->”,“args”:[“admin”,{“class”:“OC\DB\Connection”}]},{“file”:“/volume1/web/nextcloud/lib/private/Setup.php”,“line”:348,“function”:“setupDatabase”,“class”:“OC\Setup\MySQL”,“type”:“->”,“args”:[“admin”]},{“file”:“/volume1/web/nextcloud/core/Controller/SetupController.php”,“line”:72,“function”:“install”,“class”:“OC\Setup”,“type”:“->”,“args”:[“*** sensitive parameters replaced “]},{“file”:”/volume1/web/nextcloud/lib/base.php",“line”:935,“function”:“run”,“class”:“OC\Core\Controller\SetupController”,“type”:“->”,“args”:[" sensitive parameters replaced “]},{“file”:”/volume1/web/nextcloud/index.php",“line”:42,“function”:“handleRequest”,“class”:“OC”,“type”:“::”,“args”:[]}],“File”:“/volume1/web/nextcloud/3rdparty/doctrine/dbal/lib/Doctrine/DBAL/Driver/AbstractMySQLDriver.php”,“Line”:79,“Previous”:{“Exception”:“Doctrine\DBAL\Driver\PDOException”,“Message”:“SQLSTATE[42000]: Syntax error or access violation: 1064 You have an error in your SQL syntax; check the manual that corresponds to your MariaDB server version for the right syntax to use near ‘BY ‘…’’ at line 1”,“Code”:“42000”,“Trace”:[{“file”:“/volume1/web/nextcloud/3rdparty/doctrine/dbal/lib/Doctrine/DBAL/Connection.php”,“line”:1060,“function”:“exec”,“class”:“Doctrine\DBAL\Driver\PDOConnection”,“type”:“->”,“args”:[“CREATE USER ‘oc_admin’@‘localhost’ IDENTIFIED WITH mysql_native_password BY ‘…’”]},{“file”:“/volume1/web/nextcloud/lib/private/DB/Connection.php”,“line”:216,“function”:“executeUpdate”,“class”:“Doctrine\DBAL\Connection”,“type”:“->”,“args”:[“CREATE USER ‘oc_admin’@‘localhost’ IDENTIFIED WITH mysql_native_password BY ‘…’”,[],[]]},{“file”:“/volume1/web/nextcloud/lib/private/Setup/MySQL.php”,“line”:104,“function”:“executeUpdate”,“class”:“OC\DB\Connection”,“type”:“->”,“args”:[“CREATE USER ‘oc_admin’@‘localhost’ IDENTIFIED WITH mysql_native_password BY ‘…’”]},{“file”:“/volume1/web/nextcloud/lib/private/Setup/MySQL.php”,“line”:149,“function”:“createDBUser”,“class”:“OC\Setup\MySQL”,“type”:“->”,“args”:[{“class”:“OC\DB\Connection”}]},{“file”:“/volume1/web/nextcloud/lib/private/Setup/MySQL.php”,“line”:50,“function”:“createSpecificUser”,“class”:“OC\Setup\MySQL”,“type”:“->”,“args”:[“admin”,{“class”:“OC\DB\Connection”}]},{“file”:“/volume1/web/nextcloud/lib/private/Setup.php”,“line”:348,“function”:“setupDatabase”,“class”:“OC\Setup\MySQL”,“type”:“->”,“args”:[“admin”]},{“file”:“/volume1/web/nextcloud/core/Controller/SetupController.php”,“line”:72,“function”:“install”,“class”:“OC\Setup”,“type”:“->”,“args”:[" sensitive parameters replaced “]},{“file”:”/volume1/web/nextcloud/lib/base.php",“line”:935,“function”:“run”,“class”:“OC\Core\Controller\SetupController”,“type”:“->”,“args”:[" sensitive parameters replaced “]},{“file”:”/volume1/web/nextcloud/index.php",“line”:42,“function”:“handleRequest”,“class”:“OC”,“type”:“::”,“args”:[]}],“File”:“/volume1/web/nextcloud/3rdparty/doctrine/dbal/lib/Doctrine/DBAL/Driver/PDOConnection.php”,“Line”:43,“Previous”:{“Exception”:“PDOException”,“Message”:“SQLSTATE[42000]: Syntax error or access violation: 1064 You have an error in your SQL syntax; check the manual that corresponds to your MariaDB server version for the right syntax to use near ‘BY ‘…’’ at line 1”,“Code”:“42000”,“Trace”:[{“file”:“/volume1/web/nextcloud/3rdparty/doctrine/dbal/lib/Doctrine/DBAL/Driver/PDOConnection.php”,“line”:41,“function”:“exec”,“class”:“PDO”,“type”:“->”,“args”:[“CREATE USER ‘oc_admin’@‘localhost’ IDENTIFIED WITH mysql_native_password BY ‘…’”]},{“file”:“/volume1/web/nextcloud/3rdparty/doctrine/dbal/lib/Doctrine/DBAL/Connection.php”,“line”:1060,“function”:“exec”,“class”:“Doctrine\DBAL\Driver\PDOConnection”,“type”:“->”,“args”:[“CREATE USER ‘oc_admin’@‘localhost’ IDENTIFIED WITH mysql_native_password BY ‘…’”]},{“file”:“/volume1/web/nextcloud/lib/private/DB/Connection.php”,“line”:216,“function”:“executeUpdate”,“class”:“Doctrine\DBAL\Connection”,“type”:“->”,“args”:[“CREATE USER ‘oc_admin’@‘localhost’ IDENTIFIED WITH mysql_native_password BY ‘…’”,[],[]]},{“file”:“/volume1/web/nextcloud/lib/private/Setup/MySQL.php”,“line”:104,“function”:“executeUpdate”,“class”:“OC\DB\Connection”,“type”:“->”,“args”:[“CREATE USER ‘oc_admin’@‘localhost’ IDENTIFIED WITH mysql_native_password BY ‘…’”]},{“file”:“/volume1/web/nextcloud/lib/private/Setup/MySQL.php”,“line”:149,“function”:“createDBUser”,“class”:“OC\Setup\MySQL”,“type”:“->”,“args”:[{“class”:“OC\DB\Connection”}]},{“file”:“/volume1/web/nextcloud/lib/private/Setup/MySQL.php”,“line”:50,“function”:“createSpecificUser”,“class”:“OC\Setup\MySQL”,“type”:“->”,“args”:[“admin”,{“class”:“OC\DB\Connection”}]},{“file”:“/volume1/web/nextcloud/lib/private/Setup.php”,“line”:348,“function”:“setupDatabase”,“class”:“OC\Setup\MySQL”,“type”:“->”,“args”:[“admin”]},{“file”:“/volume1/web/nextcloud/core/Controller/SetupController.php”,“line”:72,“function”:“install”,“class”:“OC\Setup”,“type”:“->”,“args”:[" sensitive parameters replaced “]},{“file”:”/volume1/web/nextcloud/lib/base.php",“line”:935,“function”:“run”,“class”:“OC\Core\Controller\SetupController”,“type”:“->”,“args”:[" sensitive parameters replaced ***”]},{“file”:“/volume1/web/nextcloud/index.php”,“line”:42,“function”:“handleRequest”,“class”:“OC”,“type”:“::”,“args”:}],“File”:“/volume1/web/nextcloud/3rdparty/doctrine/dbal/lib/Doctrine/DBAL/Driver/PDOConnection.php”,“Line”:41}},“CustomMessage”:“Database user creation failed.”},“userAgent”:“Mozilla/5.0 (X11; Ubuntu; Linux x86_64; rv:71.0) Gecko/20100101 Firefox/71.0”,“version”:“17.0.2.1”}
How can I solve these errors?
I use PHP 7.3, MariaDB 10 and Apache 2.4.
