Problems with caddy and docker with aio
HI,
i try to setup nextcloud AIO with docker and caddy. The server is a linux v-server with docker and AlmaLinux 9.4. Hoster ist strato.
For NC AIO i use the docker-compose file from github without caddy. The caddy container i run with this stack
services:
  caddy:
    image: caddy
    restart: unless-stopped
    ports:
      - "80:80"
      - "443:443"
      - "443:443/udp"
    volumes:
      - ./Caddyfile:/opt/containerd/caddy/Caddyfile
      - ./site:/opt/containerd/caddy/srv
      - ./certs:/opt/containerd/caddy/certs
      - ./sites:/opt/containerd/caddy/srv
      - ./data:/opt/containerd/caddy/data
      - ./config:/opt/containerd/caddy/config
The Caddyfile looks like this
https://domain.xxx:443 {
    header Strict-Transport-Security max-age=31536000;
    reverse_proxy ip.4.inter.net:11000
The problem what i got is, that i can setup the AIO Containers and the AIO Interface show me that all containers are running. Also i can access the AIO Interface via domain.xxx:8080. But i can not access the Nextcloud website via https://domain.xxx
nc -z ip.4.inter.net 11000; echo $? from inside the caddy container is working is give a 0 back.
The domain.xxx is also hosted at strato but is part of a webhosting packacke and point via A-Record to the IP of the vserver.
I guess there is a problem between caddy and nextcloud - but where to start?
Thanks and Regards
Hi, can you follow all-in-one/reverse-proxy.md at main · nextcloud/all-in-one · GitHub?
What happens when you do so?
@szaimen
I try this with the same result. Apache-Port is set to the IP of the server and not to 0.0.0.0
@jtr
This is happen (translate from german):
Website is not reachable
domain.xxx reject the connetion.
Try this:
ERR_CONNECTION_REFUSED
Can you try if 0.0.0.0 works?
Are you sure Caddy is functioning? I’d expect a timeout or something if Caddy can’t reach it’s target behind the scenes, but not an outright connection refused on the front-end. Can you check Caddy’s logs?
Also, what’s the deal with these paths? I don’t think the standard Caddy image knows to use /opt/containerd/* [1] but I might be wrong…
[1] https://hub.docker.com/_/caddy
Sorry for the late feedback, but the last couple of days i was out for holidays :beach_umbrella:
The tip from jtr was going in the writght way. There were some mismatch for the path. The path /opt/containerd/caddy/.... is the path on the host and not in the container.
In the basic setup i run caddy with a stack setup. Probably there are some wrong configuration from my site for the volumes (just c+p from somewhere on the internet). Today i sort everything out with the correct volumes and voila, everything is running :slight_smile:
Thanks for the point to the write directions
Regards
I changed it today also to 0.0.0.0 and sort my caddy out - so it´s working now.
But i will try it again with the ip of the server, i think this will work also…
