Hello everybody,
In our company, we are currently dealing with problems relating to access to shared folders. We don’t have an exact date since when the problem has been known, but probably since the update to version 28.0.0
This applies to all already shared folders as well as newly shared folders.
As soon as you open the link (of the shared folder) in the browser of your choice, the Nextcloud UI loads first, but shortly afterwards the page loads again and again without displaying the actual contents of the folder.
Our System configuration:
Nextcloud version: v28.0.1
Operating system: Linux 5.15.0-72-generic x86_64
Apache 2.4.25
PHP version: 8.2.14
Database: MySQL 8.0.33
Nextcloud itself runs in the Docker container, which is configured with a docker-compse.
Here is the docker-compose.yml configuration version: https://pastebin.com/DnipAdy0
Nothing was changed in the configuration itself before or after the last update. The container is automatically updated via containrrr/watchtower and this has always worked without any problems.
The following log message is noticeable which is probably responsible or partly responsible for the effect:
which appears in the log on the console as well as in the browser console. The following error messages also appear irregularly: https://ibb.co/C5bPt53
here is the problem as a video link: Nextcloud-Problem.mp4 - Google Drive
Further log from the browser console: https://i.postimg.cc/25nG7CKN/2023-12-28-17h23-44.png these messages are repeated again and again and then the page reloads.
Nextcloud runs normally with a reverse proxy, which has already been deactivated as a test to rule out a source of error there and various apps have already been deactivated. All without success so far
If you need more informations or logs are required, I will be happy to provide them.
